[PATCH 1/5] libmm score API
Hesham Moustafa
heshamelmatary at gmail.com
Mon Aug 26 18:24:58 UTC 2013
On Mon, Aug 26, 2013 at 8:21 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Aug 26, 2013 at 2:15 PM, Hesham Moustafa
> <heshamelmatary at gmail.com> wrote:
> > On Mon, Aug 26, 2013 at 5:22 PM, Sebastian Huber
> > <sebastian.huber at embedded-brains.de> wrote:
> >> On 2013-08-26 02:14, Hesham AL-Matary wrote:
> >>> + * @brief _Memory_management_Region Flags defs
> >>> +#define RTEMS_MM_REGION_NO_PROTECTION 0x0
> >>> +#define RTEMS_MM_REGION_PROTECTION_READ_ONLY 0x1
> >>> +#define RTEMS_MM_REGION_PROTECTION_WRITE 0x2
> >>> +#define RTEMS_MM_REGION_NO_ACCESS 0x3
> >>> +//#define RTEMS_MM_REGION_PROTECTION_EXEC 0x4
> >> I prefer to actually have flags here and not a single integer value.
> >> So I would use this:
> >> #define RTEMS_MM_REGION_BIT_READ 0
> >> #define RTEMS_MM_REGION_BIT_WRITE 1
> >> #define RTEMS_MM_REGION_BIT_EXECUTE 2
> >> #define RTEMS_MM_REGION_BIT_CACHE 3
> >> #define RTEMS_MM_REGION_BIT_DEVICE 4
> >> #define RTEMS_MM_REGION_BIT_SHARED 5
> > Some of these flags are not supported on some architectures like
> > RTEMS_MM_REGION_BIT_SHARED, or targets that do not have
> > Cache Unit. How should we handle some of these flags for such
> > targets that do not support these features in hardware ?
> I would think the BSP will have to handle / ignore the attributes that
> do not make sense for it?
> I think of that solution too. But the developer may expect to apply this
attribute and wonder why it does not work as expected.
> >> #define RTEMS_MM_REGION_READ (1U << RTEMS_MM_REGION_BIT_WRITE)
> >> etc.
> >> This can be used to get architecture specific values easily:
> >> ((flags >> RTEMS_MM_REGION_BIT_READ) & 0x1U) << ARCH_READ_SHIFT
> > That make sense.
> >> Sebastian Huber, embedded brains GmbH
> >> Address : Dornierstr. 4, D-82178 Puchheim, Germany
> >> Phone : +49 89 189 47 41-16
> >> Fax : +49 89 189 47 41-09
> >> E-Mail : sebastian.huber at embedded-brains.de
> >> PGP : Public key available on request.
> >> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> >> _______________________________________________
> >> rtems-devel mailing list
> >> rtems-devel at rtems.org
> >> http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130826/85fa430a/attachment.html>
