[PATCH] posix: Reimplement POSIX Key manager to use a red-black tree.
Ashi
ashi08104 at gmail.com
Mon Aug 5 01:23:59 UTC 2013
Here is the patch created by git format-patch.
Cheers,
Zhongwei
On Sun, Aug 4, 2013 at 2:24 PM, Ashi <ashi08104 at gmail.com> wrote:
> Hi, All. The patch is updated according to Sebastian's comments.
> Cheers,
> Zhongwei
> On Fri, Aug 2, 2013 at 7:01 PM, Ashi <ashi08104 at gmail.com> wrote:
>> On Fri, Aug 2, 2013 at 2:38 PM, Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>>> On 2013-08-02 03:03, Ashi wrote:
>>>> + /** This field points to parent freechain node */
>>>> + POSIX_Keys_Freechain_node *fc_node_ptr;
>>>> I don't think we need this fc_node_ptr.
>>>> Do you mean use a 'Container' macro instead?
>>> Not necessarily, see below.
>>>> + /** This field is the POSIX key used as an rbtree key */
>>>> + pthread_key_t key;
>>>> + /** This field is the Thread id also used as an rbtree key */
>>>> + Objects_Id thread_id;
>>>> + /** This field points to the POSIX key value of specific
>>>> thread */
>>>> + void *value;
>>>> +} POSIX_Keys_Rbtree_node;
>>>> I would call this POSIX_Keys_Key_value_pair.
>>>> + * @brief POSIX_Keys_Freechain is used in Freechain structure
>>>> +typedef struct {
>>>> + Freechain_Control super_fc;
>>>> + size_t bump_count;
>>>> +} POSIX_Keys_Freechain;
>>>> + * @brief POSIX_Keys_Freechain_node is freechain node
>>>> +struct POSIX_Keys_Freechain_node___**struct {
>>>> + Chain_Node ch_node;
>>>> + POSIX_Keys_Rbtree_node rb_node;
>>>> Why not use POSIX_Keys_Rbtree_node directly?
>>>> Since every freechain node needs a Chain_Node in its first field. There
>>>> is a
>>>> Chain_Node in POSIX_Keys_Rbtree_node, but it is used in each thread's
>>>> key
>>>> value chain. So I add a Chain_Node to POSIX_Keys_Rbtree_node.
>>> The key value pairs on the free chain are unused, thus not part of other
>>> data structures. So basically you can cast an unused object to any type
>>> provided it has enough storage.
>> Cool! I see. I didn't realise the whole key value pairs is actually
>> unused until it moves from Freechain to POSIX key value pair.
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> Phone : +49 89 189 47 41-16
>>> Fax : +49 89 189 47 41-09
>>> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
>>> PGP : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130805/b7e7730c/attachment-0001.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130805/b7e7730c/attachment-0001.obj>
