[PATCH 06/12] arm: Per-CPU thread dispatch disable
Sebastian Huber
Mon Aug 5 14:08:13 UTC 2013
Interrupt support for per-CPU thread dispatch disable level.
cpukit/score/cpu/arm/arm_exc_interrupt.S | 76 ++++++++++--------------------
1 files changed, 25 insertions(+), 51 deletions(-)
diff --git a/cpukit/score/cpu/arm/arm_exc_interrupt.S b/cpukit/score/cpu/arm/arm_exc_interrupt.S
index 8bcd03e..3789309 100644
--- a/cpukit/score/cpu/arm/arm_exc_interrupt.S
+++ b/cpukit/score/cpu/arm/arm_exc_interrupt.S
@@ -38,21 +38,30 @@
#define EXCHANGE_LR r4
#define EXCHANGE_SPSR r5
#define EXCHANGE_CPSR r6
-#define EXCHANGE_INT_SP r7
+#define EXCHANGE_INT_SP r8
#define EXCHANGE_LIST {EXCHANGE_LR, EXCHANGE_SPSR, EXCHANGE_CPSR, EXCHANGE_INT_SP}
#define EXCHANGE_SIZE 16
-#define CONTEXT_LIST {r0, r1, r2, r3, EXCHANGE_LR, EXCHANGE_SPSR, r12}
-#define CONTEXT_SIZE 28
+#define SELF_CPU_CONTROL r7
+#define CONTEXT_LIST {r0, r1, r2, r3, EXCHANGE_LR, EXCHANGE_SPSR, SELF_CPU_CONTROL, r12}
+#define CONTEXT_SIZE 32
#ifdef ARM_MULTILIB_VFP_D32
#define VFP_CONTEXT_WITH_ALIGNMENT_SPACE (24 * 8 + 4 + 4)
#endif
-.extern _Thread_Dispatch_disable_level
+.macro GET_SELF_CPU_CONTROL REG, TMP
+ ldr \REG, =_Per_CPU_Information
+#ifdef RTEMS_SMP
+ /* Use ARMv7 Multiprocessor Affinity Register (MPIDR) */
+ mrc p15, 0, \TMP, c0, c0, 5
-.extern bsp_interrupt_dispatch
+ and \TMP, \TMP, #0xff
+ add \REG, \REG, \TMP, asl #PER_CPU_CONTROL_SIZE_LOG2
+#endif
+.endm
.arm
.globl _ARMV4_Exception_interrupt
@@ -90,38 +99,9 @@ _ARMV4_Exception_interrupt:
str r0, [r1]
#endif
-#ifdef RTEMS_SMP
- /* ISR enter */
- blx _ISR_SMP_Enter
- /* Remember INT stack pointer */
- mov r1, EXCHANGE_INT_SP
- /* Restore exchange registers from exchange area */
- ldmia r1, EXCHANGE_LIST
+ /* Get per-CPU control of current processor */
+ GET_SELF_CPU_CONTROL SELF_CPU_CONTROL, r1
- /* Switch stack if necessary and save original stack pointer */
- mov r2, sp
- cmp r0, #0
- moveq sp, r1
- stmdb sp!, {r2}
- /* Call BSP dependent interrupt dispatcher */
- blx bsp_interrupt_dispatch
- /* Restore stack pointer */
- ldr sp, [sp]
- /* ISR exit */
- blx _ISR_SMP_Exit
- cmp r0, #0
- beq thread_dispatch_done
- /* Thread dispatch */
- blx _Thread_Dispatch
-thread_dispatch_done:
-#else /* RTEMS_SMP */
@@ -129,8 +109,7 @@ thread_dispatch_done:
/* Get interrupt nest level */
- ldr r0, =ISR_NEST_LEVEL
- ldr r2, [r0]
+ ldr r2, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
mov r3, sp
@@ -142,25 +121,22 @@ thread_dispatch_done:
SWITCH_FROM_ARM_TO_THUMB r1
/* Increment interrupt nest and thread dispatch disable level */
- ldr r1, =_Thread_Dispatch_disable_level
- ldr r3, [r1]
+ ldr r3, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
add r2, #1
add r3, #1
- str r2, [r0]
- str r3, [r1]
+ str r2, [SELF_CPU_CONTROL, #PER_CPU_ISR_NEST_LEVEL]
+ str r3, [SELF_CPU_CONTROL, #PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
bl bsp_interrupt_dispatch
/* Decrement interrupt nest and thread dispatch disable level */
- ldr r2, [r0]
- ldr r3, [r1]
sub r2, #1
sub r3, #1
- str r2, [r0]
- str r3, [r1]
SWITCH_FROM_THUMB_TO_ARM
@@ -172,8 +148,7 @@ thread_dispatch_done:
bne thread_dispatch_done
/* Check context switch necessary */
- ldr r0, =DISPATCH_NEEDED
- ldrb r1, [r0]
+ ldrb r1, [SELF_CPU_CONTROL, #PER_CPU_DISPATCH_NEEDED]
cmp r1, #0
@@ -189,7 +164,6 @@ thread_dispatch_done:
/* Switch to ARM instructions if necessary */
-#endif /* RTEMS_SMP */
/* Restore VFP context */
1.7.7
