[PATCH 07/12] bsps/sparc: Revert most SMP related changes
Mon Aug 5 14:08:14 UTC 2013
As a side-effect the PR2082 is fixed with this and later changes.
The commit restores the _ISR_Handler code to the original version in
"cpukit/score/sparc/cpu_asm.S" in commit
6d42b4c60a4ac686489b793d5df2047c735c7c94.  A list of reverted changes
follows.
commit c236082873cb4a2fd42af4ca0868106e1dd65422
Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
Date:   Tue Jul 30 15:54:53 2013 +0200
    smp: Provide cache optimized Per_CPU_Control
    Delete _Per_CPU_Information_p.
This commit was completely reverted.
commit e517714b7cd28807aad4c1afd8c97df72dadb4c1
Author: Jennifer Averett <jennifer.averett at oarcorp.com>
Date:   Tue Feb 26 12:31:23 2013 -0600
    sparc: Remove dead code that was leftover from SMP development.
commit 47a61aa16f81588f8ffb8ea5cfd1ceba3e9a867a
Author: Joel Sherrill <joel.sherrill at OARcorp.com>
Date:   Fri Oct 7 14:35:03 2011 +0000
    2011-10-07	Daniel Hellstrom <daniel at gaisler.com>
    	PR 1933/cpukit
    	* shared/irq_asm.S: From code inspection I have found the following
    	issues (most SMP), and some improvements in irq_asm.S. I would need a
    	long test with interrupts to verify the interrupt handler better,
    	however I can not see that these patches hurt. Please see comment per
    	hunk below, One should go through the file to indent delay-slots
    	correctly, I have fixed some in the patch areas. An extra space is
    	added in front of delay slots to indicate a delay slot.
commit 0bd3f7e5d12fdbfb5bf4aa4a4169c67bfd92c988
Author: Jennifer Averett <Jennifer.Averett at OARcorp.com>
Date:   Thu Jul 28 17:33:07 2011 +0000
    2011-07-28	Jennifer Averett <Jennifer.Averett at OARcorp.com>
    	PR 1801
    	* shared/irq_asm.S: Modifications to synch the sparc with the smp
    	working tree.
commit 5d69cd33e9a72cf8c1a24fc9eda7f64d61f10fd1
Date:   Wed Mar 16 20:05:30 2011 +0000
    2011-03-16	Jennifer Averett <jennifer.averett at OARcorp.com>
    	PR 1729/cpukit
    	* shared/irq_asm.S: New file.
The parts modifying the original code of _ISR_Handler were reverted.
Only the content move remains.
 c/src/lib/libbsp/sparc/shared/irq_asm.S |  170 ++----
 cpu_asm.S                               |  858 +++++++++++++++++++++++++++++++
 2 files changed, 916 insertions(+), 112 deletions(-)
 create mode 100644 cpu_asm.S
diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
index eb2f9c5..f025005 100644
--- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
+++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
@@ -21,7 +21,6 @@
 #include <rtems/asm.h>
-#include <bspopts.h>
  *  void _ISR_Handler()
@@ -162,6 +161,52 @@ save_isf:
         mov     %sp, %o1                       ! 2nd arg to ISR Handler
+         *  Increment ISR nest level and Thread dispatch disable level.
+         *  Register usage for this section:
+         *    l4 = _Thread_Dispatch_disable_level pointer
+         *    l5 = per cpu info pointer
+         *    l6 = _Thread_Dispatch_disable_level value
+         *    l7 = _ISR_Nest_level value
+         *  NOTE: It is assumed that l4 - l7 will be preserved until the ISR
+         *        nest and thread dispatch disable levels are unnested.
+        sethi    %hi(_Per_CPU_Information), %l5
+        add      %l5, %lo(_Per_CPU_Information), %l5
+	ld       [%l5 + PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL], %l6
+	ld       [%l5 + PER_CPU_ISR_NEST_LEVEL], %l7
+        add      %l6, 1, %l6
+        st       %l6, [%l5 + PER_CPU_THREAD_DISPATCH_DISABLE_LEVEL]
+        add      %l7, 1, %l7
+        st       %l7, [%l5 + PER_CPU_ISR_NEST_LEVEL]
+         *  If ISR nest level was zero (now 1), then switch stack.
+        mov      %sp, %fp
+        subcc    %l7, 1, %l7             ! outermost interrupt handler?
+        bnz      dont_switch_stacks      ! No, then do not switch stacks
+        nop
+	ld       [%l5 + PER_CPU_INTERRUPT_STACK_HIGH], %sp
+dont_switch_stacks:
+         *  Make sure we have a place on the stack for the window overflow
+         *  trap handler to write into.  At this point it is safe to
+         *  enable traps again.
+        sub      %sp, CPU_MINIMUM_STACK_FRAME_SIZE, %sp
          *  Check if we have an external interrupt (trap 0x11 - 0x1f). If so,
          *  set the PIL in the %psr to mask off interrupts with lower priority.
          *  The original %psr in %l0 is not modified since it will be restored
@@ -251,85 +296,6 @@ pil_fixed:
         wr       %g5, SPARC_PSR_ET_MASK, %psr ! **** ENABLE TRAPS ****
 dont_fix_pil2:
-        PUBLIC(_ISR_PER_CPU)
-SYM(_ISR_PER_CPU):
-#if defined(RTEMS_SMP)
-        sethi    %hi(_Per_CPU_Information), %l5
-        add      %l5, %lo(_Per_CPU_Information), %l5
-    #if BSP_LEON3_SMP
-	/* LEON3 SMP support */
-	rd	%asr17, %l7
-	srl	%l7, 28, %l7	/* CPU number is upper 4 bits so shift */
-    #else
-        mov	0, %l7
-        nop
-    #endif
-	sll	%l7, PER_CPU_CONTROL_SIZE_LOG2, %l7	/* l7 = offset */
-	add	%l5, %l7, %l5	/* l5 = pointer to per CPU */
-         *  On multi-core system, we need to use SMP safe versions
-         *  of ISR and Thread Dispatch critical sections.
-         *  _ISR_SMP_Enter returns the interrupt nest level.  If we are
-         *  outermost interrupt, then we need to switch stacks.
-        call    SYM(_ISR_SMP_Enter), 0
-         mov      %sp, %fp              ! delay slot
-	cmp	%o0, 0
-#else
-         *  On single core system, we can directly use variables.
-         *  Increment ISR nest level and Thread dispatch disable level.
-         *  Register usage for this section:
-         *    l4 = _Thread_Dispatch_disable_level pointer
-         *    l5 = _ISR_Nest_level pointer
-         *    l6 = _Thread_Dispatch_disable_level value
-         *    l7 = _ISR_Nest_level value
-         *  NOTE: It is assumed that l4 - l7 will be preserved until the ISR
-         *        nest and thread dispatch disable levels are unnested.
-        sethi    %hi(SYM(_Thread_Dispatch_disable_level)), %l4
-        ld       [%l4 + %lo(SYM(_Thread_Dispatch_disable_level))], %l6
-        ld       [%l5 + PER_CPU_ISR_NEST_LEVEL], %l7
-        add      %l6, 1, %l6
-        st       %l6, [%l4 + %lo(SYM(_Thread_Dispatch_disable_level))]
-        add      %l7, 1, %l7
-        st       %l7, [%l5 + PER_CPU_ISR_NEST_LEVEL]
-         *  If ISR nest level was zero (now 1), then switch stack.
-        mov      %sp, %fp
-        subcc    %l7, 1, %l7             ! outermost interrupt handler?
-#endif
-         *  Do we need to switch to the interrupt stack?
-        beq,a    dont_switch_stacks      ! No, then do not switch stacks
-         ld      [%l5 + PER_CPU_INTERRUPT_STACK_HIGH], %sp
-dont_switch_stacks:
-         *  Make sure we have a place on the stack for the window overflow
-         *  trap handler to write into.  At this point it is safe to
-         *  enable traps again.
-        sub      %sp, CPU_MINIMUM_STACK_FRAME_SIZE, %sp
          *  Vector to user's handler.
@@ -350,14 +316,6 @@ dont_switch_stacks:
         call     %g4, 0
         nop                             ! delay slot
-        call    SYM(_ISR_SMP_Exit), 0
-        nop                             ! delay slot
-	cmp	%o0, 0
-	bz	simple_return
-	 nop
-#endif
          *  Redisable traps so we can finish up the interrupt processing.
          *  This is a VERY conservative place to do this.
@@ -368,7 +326,6 @@ dont_switch_stacks:
         mov      %l0, %psr             ! **** DISABLE TRAPS ****
         nop; nop; nop
-#if !defined(RTEMS_SMP)
          *  Decrement ISR nest level and Thread dispatch disable level.
@@ -381,7 +338,7 @@ dont_switch_stacks:
         sub      %l6, 1, %l6
@@ -399,7 +356,8 @@ dont_switch_stacks:
         ld       [%l6 + %lo(SYM(_CPU_ISR_Dispatch_disable))], %l7
         orcc     %l7, %g0, %g0   ! Is this thread already doing an ISR?
         bnz      simple_return   ! Yes, then do a "simple" exit
-         nop
+        nop
          *  If a context switch is necessary, then do fudge stack to
@@ -407,10 +365,11 @@ dont_switch_stacks:
         ldub     [%l5 + PER_CPU_DISPATCH_NEEDED], %l5
         orcc     %l5, %g0, %g0   ! Is thread switch necessary?
-        bz       simple_return   ! No, then return
-         nop
-#endif
+        bz       simple_return   ! no, then do a simple return
+        nop
          *  Invoke interrupt dispatcher.
@@ -457,26 +416,13 @@ isr_dispatch:
          *  _Thread_Dispatch before leaving this ISR Dispatch context.
-    #if BSP_LEON3_SMP
-	rd	%asr17, %l7
-    #else
-        mov	0, %l7
-        nop
-    #endif
-#else
-#endif
-        ldub     [%l5 + PER_CPU_DISPATCH_NEEDED], %l5
-        orcc     %l5, %g0, %g0   ! Is thread switch necessary?
-        bz       allow_nest_again
+        ldub     [%l5 + PER_CPU_DISPATCH_NEEDED], %l7
+        orcc     %l7, %g0, %g0    ! Is thread switch necesary?
+        bz       allow_nest_again ! No, then clear out and return
         nop
         ! Yes, then invoke the dispatcher
diff --git a/cpu_asm.S b/cpu_asm.S
new file mode 100644
index 0000000..363ce80
--- /dev/null
+++ b/cpu_asm.S
@@ -0,0 +1,858 @@
+/*  cpu_asm.s
+ *  This file contains the basic algorithms for all assembly code used
+ *  in an specific CPU port of RTEMS.  These algorithms must be implemented
+ *  in assembly language.
+ *  COPYRIGHT (c) 1989-2010.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+ *  Ported to ERC32 implementation of the SPARC by On-Line Applications
+ *  Research Corporation (OAR) under contract to the European Space
+ *  Agency (ESA).
+ *  ERC32 modifications of respective RTEMS file: COPYRIGHT (c) 1995.
+ *  European Space Agency.
+ *  $Id$
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/asm.h>
+#include <rtems/system.h>
+#if (SPARC_HAS_FPU == 1)
+ *  void _CPU_Context_save_fp(
+ *    void **fp_context_ptr
+ *  This routine is responsible for saving the FP context
+ *  at *fp_context_ptr.  If the point to load the FP context
+ *  from is changed then the pointer is modified by this routine.
+ *  NOTE: See the README in this directory for information on the
+ *        management of the "EF" bit in the PSR.
+        .align 4
+        PUBLIC(_CPU_Context_save_fp)
+SYM(_CPU_Context_save_fp):
+        save    %sp, -CPU_MINIMUM_STACK_FRAME_SIZE, %sp
+         *  The following enables the floating point unit.
+        mov     %psr, %l0
+        sethi   %hi(SPARC_PSR_EF_MASK), %l1
+        or      %l1, %lo(SPARC_PSR_EF_MASK), %l1
+        or      %l0, %l1, %l0
+        mov     %l0, %psr                  ! **** ENABLE FLOAT ACCESS ****
+	nop; nop; nop;			   ! Need three nops before EF is
+        ld      [%i0], %l0		   ! active due to pipeline delay!!!
+        std     %f0, [%l0 + FO_F1_OFFSET]
+        std     %f2, [%l0 + F2_F3_OFFSET]
+        std     %f4, [%l0 + F4_F5_OFFSET]
+        std     %f6, [%l0 + F6_F7_OFFSET]
+        std     %f8, [%l0 + F8_F9_OFFSET]
+        std     %f10, [%l0 + F1O_F11_OFFSET]
+        std     %f12, [%l0 + F12_F13_OFFSET]
+        std     %f14, [%l0 + F14_F15_OFFSET]
+        std     %f16, [%l0 + F16_F17_OFFSET]
+        std     %f18, [%l0 + F18_F19_OFFSET]
+        std     %f20, [%l0 + F2O_F21_OFFSET]
+        std     %f22, [%l0 + F22_F23_OFFSET]
+        std     %f24, [%l0 + F24_F25_OFFSET]
+        std     %f26, [%l0 + F26_F27_OFFSET]
+        std     %f28, [%l0 + F28_F29_OFFSET]
+        std     %f30, [%l0 + F3O_F31_OFFSET]
+        st      %fsr, [%l0 + FSR_OFFSET]
+        ret
+        restore
+ *  void _CPU_Context_restore_fp(
+ *  This routine is responsible for restoring the FP context
+        .align 4
+        PUBLIC(_CPU_Context_restore_fp)
+SYM(_CPU_Context_restore_fp):
+        save    %sp, -CPU_MINIMUM_STACK_FRAME_SIZE , %sp
+        mov     %psr, %l0
+        or      %l0, %l1, %l0
+        ldd     [%l0 + FO_F1_OFFSET], %f0
+        ldd     [%l0 + F2_F3_OFFSET], %f2
+        ldd     [%l0 + F4_F5_OFFSET], %f4
+        ldd     [%l0 + F6_F7_OFFSET], %f6
+        ldd     [%l0 + F8_F9_OFFSET], %f8
+        ldd     [%l0 + F1O_F11_OFFSET], %f10
+        ldd     [%l0 + F12_F13_OFFSET], %f12
+        ldd     [%l0 + F14_F15_OFFSET], %f14
+        ldd     [%l0 + F16_F17_OFFSET], %f16
+        ldd     [%l0 + F18_F19_OFFSET], %f18
+        ldd     [%l0 + F2O_F21_OFFSET], %f20
+        ldd     [%l0 + F22_F23_OFFSET], %f22
+        ldd     [%l0 + F24_F25_OFFSET], %f24
+        ldd     [%l0 + F26_F27_OFFSET], %f26
+        ldd     [%l0 + F28_F29_OFFSET], %f28
+        ldd     [%l0 + F3O_F31_OFFSET], %f30
+        ld      [%l0 + FSR_OFFSET], %fsr
+        ret
+        restore
+#endif /* SPARC_HAS_FPU */
+ *  void _CPU_Context_switch(
+ *    Context_Control  *run,
+ *    Context_Control  *heir
+ *  This routine performs a normal non-FP context switch.
+        .align 4
+        PUBLIC(_CPU_Context_switch)
+SYM(_CPU_Context_switch):
+        ! skip g0
+        st      %g1, [%o0 + G1_OFFSET]       ! save the global registers
+        std     %g2, [%o0 + G2_OFFSET]
+        std     %g4, [%o0 + G4_OFFSET]
+        std     %g6, [%o0 + G6_OFFSET]
+        ! load the address of the ISR stack nesting prevention flag
+        sethi    %hi(SYM(_CPU_ISR_Dispatch_disable)), %g2
+        ld       [%g2 + %lo(SYM(_CPU_ISR_Dispatch_disable))], %g2
+        ! save it a bit later so we do not waste a couple of cycles
+        std     %l0, [%o0 + L0_OFFSET]       ! save the local registers
+        std     %l2, [%o0 + L2_OFFSET]
+        std     %l4, [%o0 + L4_OFFSET]
+        std     %l6, [%o0 + L6_OFFSET]
+        ! Now actually save ISR stack nesting prevention flag
+        st       %g2, [%o0 + ISR_DISPATCH_DISABLE_STACK_OFFSET]
+        std     %i0, [%o0 + I0_OFFSET]       ! save the input registers
+        std     %i2, [%o0 + I2_OFFSET]
+        std     %i4, [%o0 + I4_OFFSET]
+        std     %i6, [%o0 + I6_FP_OFFSET]
+        std     %o0, [%o0 + O0_OFFSET]       ! save the output registers
+        std     %o2, [%o0 + O2_OFFSET]
+        std     %o4, [%o0 + O4_OFFSET]
+        std     %o6, [%o0 + O6_SP_OFFSET]
+        rd      %psr, %o2
+        st      %o2, [%o0 + PSR_OFFSET]      ! save status register
+         *  This is entered from _CPU_Context_restore with:
+         *    o1 = context to restore
+         *    o2 = psr
+        PUBLIC(_CPU_Context_restore_heir)
+SYM(_CPU_Context_restore_heir):
+         *  Flush all windows with valid contents except the current one.
+         *  In examining the set register windows, one may logically divide
+         *  the windows into sets (some of which may be empty) based on their
+         *  current status:
+         *    + current (i.e. in use),
+         *    + used (i.e. a restore would not trap)
+         *    + invalid (i.e. 1 in corresponding bit in WIM)
+         *    + unused
+         *  Either the used or unused set of windows may be empty.
+         *  NOTE: We assume only one bit is set in the WIM at a time.
+         *  Given a CWP of 5 and a WIM of 0x1, the registers are divided
+         *  into sets as follows:
+         *    + 0   - invalid
+         *    + 1-4 - unused
+         *    + 5   - current
+         *    + 6-7 - used
+         *  In this case, we only would save the used windows -- 6 and 7.
+         *   Traps are disabled for the same logical period as in a
+         *     flush all windows trap handler.
+         *    Register Usage while saving the windows:
+         *      g1 = current PSR
+         *      g2 = current wim
+         *      g3 = CWP
+         *      g4 = wim scratch
+         *      g5 = scratch
+        ld      [%o1 + PSR_OFFSET], %g1       ! g1 = saved psr
+        and     %o2, SPARC_PSR_CWP_MASK, %g3  ! g3 = CWP
+                                              ! g1 = psr w/o cwp
+        andn    %g1, SPARC_PSR_ET_MASK | SPARC_PSR_CWP_MASK, %g1
+        or      %g1, %g3, %g1                 ! g1 = heirs psr
+        mov     %g1, %psr                     ! restore status register and
+                                              ! **** DISABLE TRAPS ****
+        mov     %wim, %g2                     ! g2 = wim
+        mov     1, %g4
+        sll     %g4, %g3, %g4                 ! g4 = WIM mask for CW invalid
+save_frame_loop:
+        sll     %g4, 1, %g5                   ! rotate the "wim" left 1
+        srl     %g4, SPARC_NUMBER_OF_REGISTER_WINDOWS - 1, %g4
+        or      %g4, %g5, %g4                 ! g4 = wim if we do one restore
+         *  If a restore would not underflow, then continue.
+        andcc   %g4, %g2, %g0                 ! Any windows to flush?
+        bnz     done_flushing                 ! No, then continue
+        nop
+        restore                               ! back one window
+         *  Now save the window just as if we overflowed to it.
+        std     %l0, [%sp + CPU_STACK_FRAME_L0_OFFSET]
+        std     %l2, [%sp + CPU_STACK_FRAME_L2_OFFSET]
+        std     %l4, [%sp + CPU_STACK_FRAME_L4_OFFSET]
+        std     %l6, [%sp + CPU_STACK_FRAME_L6_OFFSET]
+        std     %i0, [%sp + CPU_STACK_FRAME_I0_OFFSET]
+        std     %i2, [%sp + CPU_STACK_FRAME_I2_OFFSET]
+        std     %i4, [%sp + CPU_STACK_FRAME_I4_OFFSET]
+        std     %i6, [%sp + CPU_STACK_FRAME_I6_FP_OFFSET]
+        ba      save_frame_loop
+        nop
+done_flushing:
+        add     %g3, 1, %g3                   ! calculate desired WIM
+        and     %g3, SPARC_NUMBER_OF_REGISTER_WINDOWS - 1, %g3
+        mov     1, %g4
+        sll     %g4, %g3, %g4                 ! g4 = new WIM
+        mov     %g4, %wim
+        or      %g1, SPARC_PSR_ET_MASK, %g1
+        mov     %g1, %psr                     ! **** ENABLE TRAPS ****
+                                              !   and restore CWP
+        nop
+        nop
+        nop
+        ! skip g0
+        ld      [%o1 + G1_OFFSET], %g1        ! restore the global registers
+        ldd     [%o1 + G2_OFFSET], %g2
+        ldd     [%o1 + G4_OFFSET], %g4
+        ldd     [%o1 + G6_OFFSET], %g6
+        ! Load thread specific ISR dispatch prevention flag
+        ld      [%o1 + ISR_DISPATCH_DISABLE_STACK_OFFSET], %o2
+        sethi    %hi(SYM(_CPU_ISR_Dispatch_disable)), %o3
+        ! Store it to memory later to use the cycles
+        ldd     [%o1 + L0_OFFSET], %l0        ! restore the local registers
+        ldd     [%o1 + L2_OFFSET], %l2
+        ldd     [%o1 + L4_OFFSET], %l4
+        ldd     [%o1 + L6_OFFSET], %l6
+        ! Now restore thread specific ISR dispatch prevention flag
+        st       %o2,[%o3 + %lo(SYM(_CPU_ISR_Dispatch_disable))]
+        ldd     [%o1 + I0_OFFSET], %i0        ! restore the output registers
+        ldd     [%o1 + I2_OFFSET], %i2
+        ldd     [%o1 + I4_OFFSET], %i4
+        ldd     [%o1 + I6_FP_OFFSET], %i6
+        ldd     [%o1 + O2_OFFSET], %o2        ! restore the output registers
+        ldd     [%o1 + O4_OFFSET], %o4
+        ldd     [%o1 + O6_SP_OFFSET], %o6
+        ! do o0/o1 last to avoid destroying heir context pointer
+        ldd     [%o1 + O0_OFFSET], %o0        ! overwrite heir pointer
+        jmp     %o7 + 8                       ! return
+        nop                                   ! delay slot
+ *  void _CPU_Context_restore(
+ *    Context_Control *new_context
+ *  This routine is generally used only to perform restart self.
+ *  NOTE: It is unnecessary to reload some registers.
+        .align 4
+        PUBLIC(_CPU_Context_restore)
+SYM(_CPU_Context_restore):
+        rd      %psr, %o2
+        ba      SYM(_CPU_Context_restore_heir)
+        mov     %i0, %o1                      ! in the delay slot
+ *  void _ISR_Handler()
+ *  This routine provides the RTEMS interrupt management.
+ *  We enter this handler from the 4 instructions in the trap table with
+ *  the following registers assumed to be set as shown:
+ *    l0 = PSR
+ *    l1 = PC
+ *    l2 = nPC
+ *    l3 = trap type
+ *  NOTE: By an executive defined convention, trap type is between 0 and 255 if
+ *        it is an asynchonous trap and 256 and 511 if it is synchronous.
+        .align 4
+        PUBLIC(_ISR_Handler)
+SYM(_ISR_Handler):
+         *  Fix the return address for synchronous traps.
+        andcc   %l3, SPARC_SYNCHRONOUS_TRAP_BIT_MASK, %g0
+                                      ! Is this a synchronous trap?
+        be,a    win_ovflow            ! No, then skip the adjustment
+        nop                           ! DELAY
+        mov     %l1, %l6              ! save trapped pc for debug info
+        mov     %l2, %l1              ! do not return to the instruction
+        add     %l2, 4, %l2           ! indicated
+win_ovflow:
+         *  Save the globals this block uses.
+         *  These registers are not restored from the locals.  Their contents
+         *  are saved directly from the locals into the ISF below.
+        mov     %g4, %l4                 ! save the globals this block uses
+        mov     %g5, %l5
+         *  When at a "window overflow" trap, (wim == (1 << cwp)).
+         *  If we get here like that, then process a window overflow.
+        rd      %wim, %g4
+        srl     %g4, %l0, %g5            ! g5 = win >> cwp ; shift count and CWP
+                                         !   are LS 5 bits ; how convenient :)
+        cmp     %g5, 1                   ! Is this an invalid window?
+        bne     dont_do_the_window       ! No, then skip all this stuff
+        ! we are using the delay slot
+         *  The following is same as a 1 position right rotate of WIM
+        srl     %g4, 1, %g5              ! g5 = WIM >> 1
+        sll     %g4, SPARC_NUMBER_OF_REGISTER_WINDOWS-1 , %g4
+                                         ! g4 = WIM << (Number Windows - 1)
+        or      %g4, %g5, %g4            ! g4 = (WIM >> 1) |
+                                         !      (WIM << (Number Windows - 1))
+         *  At this point:
+         *    g4 = the new WIM
+         *    g5 is free
+         *  Since we are tinkering with the register windows, we need to
+         *  make sure that all the required information is in global registers.
+        save                          ! Save into the window
+        wr      %g4, 0, %wim          ! WIM = new WIM
+        nop                           ! delay slots
+        nop
+        nop
+        restore
+        nop
+dont_do_the_window:
+         *  Global registers %g4 and %g5 are saved directly from %l4 and
+         *  %l5 directly into the ISF below.
+save_isf:
+         *  Save the state of the interrupted task -- especially the global
+         *  registers -- in the Interrupt Stack Frame.  Note that the ISF
+         *  includes a regular minimum stack frame which will be used if
+         *  needed by register window overflow and underflow handlers.
+         *  REGISTERS SAME AS AT _ISR_Handler
+        sub     %fp, CONTEXT_CONTROL_INTERRUPT_FRAME_SIZE, %sp
+                                               ! make space for ISF
+        std     %l0, [%sp + ISF_PSR_OFFSET]    ! save psr, PC
+        st      %l2, [%sp + ISF_NPC_OFFSET]    ! save nPC
+        st      %g1, [%sp + ISF_G1_OFFSET]     ! save g1
+        std     %g2, [%sp + ISF_G2_OFFSET]     ! save g2, g3
+        std     %l4, [%sp + ISF_G4_OFFSET]     ! save g4, g5 -- see above
+        std     %g6, [%sp + ISF_G6_OFFSET]     ! save g6, g7
+        std     %i0, [%sp + ISF_I0_OFFSET]     ! save i0, i1
+        std     %i2, [%sp + ISF_I2_OFFSET]     ! save i2, i3
+        std     %i4, [%sp + ISF_I4_OFFSET]     ! save i4, i5
+        std     %i6, [%sp + ISF_I6_FP_OFFSET]  ! save i6/fp, i7
+        rd      %y, %g1
+        st      %g1, [%sp + ISF_Y_OFFSET]      ! save y
+        st      %l6, [%sp + ISF_TPC_OFFSET]    ! save real trapped pc
+        mov     %sp, %o1                       ! 2nd arg to ISR Handler
+        sethi    %hi(SYM(_Thread_Dispatch_disable_level)), %l4
+        ld       [%l4 + %lo(SYM(_Thread_Dispatch_disable_level))], %l6
+        add      %l6, 1, %l6
+        st       %l6, [%l4 + %lo(SYM(_Thread_Dispatch_disable_level))]
+        add      %l7, 1, %l7
+        mov      %sp, %fp
+        nop
+         *  Check if we have an external interrupt (trap 0x11 - 0x1f). If so,
+         *  set the PIL in the %psr to mask off interrupts with lower priority.
+         *  The original %psr in %l0 is not modified since it will be restored
+         *  when the interrupt handler returns.
+        mov      %l0, %g5
+	and	 %l3, 0x0ff, %g4
+/* This is a fix for ERC32 with FPU rev.B or rev.C */
+#if defined(FPU_REVB)
+        subcc    %g4, 0x08, %g0
+	be	 fpu_revb
+        subcc    %g4, 0x11, %g0
+        bl       dont_fix_pil
+        subcc    %g4, 0x1f, %g0
+        bg       dont_fix_pil
+        sll      %g4, 8, %g4
+        and      %g4, SPARC_PSR_PIL_MASK, %g4
+        andn     %l0, SPARC_PSR_PIL_MASK, %g5
+        or       %g4, %g5, %g5
+	srl	 %l0, 12, %g4
+	andcc	 %g4, 1, %g0
+        be       dont_fix_pil
+	nop
+	ba,a	 enable_irq
+fpu_revb:
+	srl	 %l0, 12, %g4	! check if EF is set in %psr
+	andcc	 %g4, 1, %g0
+	be	 dont_fix_pil	! if FPU disabled than continue as normal
+	and	 %l3, 0xff, %g4
+        bne      enable_irq	! if not a FPU exception then do two fmovs
+	set	 __sparc_fq, %g4
+	st	 %fsr, [%g4]	! if FQ is not empty and FQ[1] = fmovs
+	ld	 [%g4], %g4	! than this is bug 3.14
+	srl 	 %g4, 13, %g4
+	andcc 	 %g4, 1, %g0
+        be       dont_fix_pil
+	std	 %fq, [%g4]
+	ld	 [%g4+4], %g4
+	set	 0x81a00020, %g5
+	subcc	 %g4, %g5, %g0
+	bne,a	 dont_fix_pil2
+        wr       %l0, SPARC_PSR_ET_MASK, %psr ! **** ENABLE TRAPS ****
+	ba,a	 simple_return
+enable_irq:
+        or       %g5, SPARC_PSR_PIL_MASK, %g4
+        wr       %g4, SPARC_PSR_ET_MASK, %psr ! **** ENABLE TRAPS ****
+	nop; nop; nop
+	fmovs	 %f0, %f0
+	ba	 dont_fix_pil
+	fmovs	 %f0, %f0
+	.data
+	.global	__sparc_fq
+	.align 8
+__sparc_fq:
+	.word 0,0
+	.text
+/* end of ERC32 FPU rev.B/C fix */
+#else
+        bl       dont_fix_pil
+        bg       dont_fix_pil
+        sll      %g4, 8, %g4
+        ba       pil_fixed
+        or       %g4, %g5, %g5
+#endif
+dont_fix_pil:
+        or       %g5, SPARC_PSR_PIL_MASK, %g5
+pil_fixed:
+        wr       %g5, SPARC_PSR_ET_MASK, %psr ! **** ENABLE TRAPS ****
+dont_fix_pil2:
+         *  Vector to user's handler.
+         *  NOTE: TBR may no longer have vector number in it since
+         *        we just enabled traps.  It is definitely in l3.
+        sethi    %hi(SYM(_ISR_Vector_table)), %g4
+        ld       [%g4+%lo(SYM(_ISR_Vector_table))], %g4
+        and      %l3, 0xFF, %g5         ! remove synchronous trap indicator
+        sll      %g5, 2, %g5            ! g5 = offset into table
+        ld       [%g4 + %g5], %g4       ! g4 = _ISR_Vector_table[ vector ]
+                                        ! o1 = 2nd arg = address of the ISF
+                                        !   WAS LOADED WHEN ISF WAS SAVED!!!
+        mov      %l3, %o0               ! o0 = 1st arg = vector number
+        call     %g4, 0
+        nop                             ! delay slot
+         *  Redisable traps so we can finish up the interrupt processing.
+         *  This is a VERY conservative place to do this.
+         *  NOTE: %l0 has the PSR which was in place when we took the trap.
+        mov      %l0, %psr             ! **** DISABLE TRAPS ****
+        nop; nop; nop
+         *  Decrement ISR nest level and Thread dispatch disable level.
+         *    l5 = _ISR_Nest_level pointer
+        sub      %l6, 1, %l6
+         *  If dispatching is disabled (includes nested interrupt case),
+         *  then do a "simple" exit.
+        orcc     %l6, %g0, %g0   ! Is dispatching disabled?
+        bnz      simple_return   ! Yes, then do a "simple" exit
+        ! NOTE: Use the delay slot
+        sethi    %hi(SYM(_CPU_ISR_Dispatch_disable)), %l6
+        ! Are we dispatching from a previous ISR in the interrupted thread?
+        ld       [%l6 + %lo(SYM(_CPU_ISR_Dispatch_disable))], %l7
+        orcc     %l7, %g0, %g0   ! Is this thread already doing an ISR?
+        nop
+         *  If a context switch is necessary, then do fudge stack to
+         *  return to the interrupt dispatcher.
+        ldub     [%l5 + PER_CPU_DISPATCH_NEEDED], %l5
+        orcc     %l5, %g0, %g0   ! Is thread switch necessary?
+        nop
+         *  Invoke interrupt dispatcher.
+        PUBLIC(_ISR_Dispatch)
+SYM(_ISR_Dispatch):
+        ! Set ISR dispatch nesting prevention flag
+        mov      1,%l6
+        sethi    %hi(SYM(_CPU_ISR_Dispatch_disable)), %l5
+        st       %l6,[%l5 + %lo(SYM(_CPU_ISR_Dispatch_disable))]
+         *  The following subtract should get us back on the interrupted
+         *  tasks stack and add enough room to invoke the dispatcher.
+         *  When we enable traps, we are mostly back in the context
+         *  of the task and subsequent interrupts can operate normally.
+        sub      %fp, CPU_MINIMUM_STACK_FRAME_SIZE, %sp
+        or      %l0, SPARC_PSR_ET_MASK, %l7    ! l7 = PSR with ET=1
+        mov     %l7, %psr                      !  **** ENABLE TRAPS ****
+        nop
+        nop
+        nop
+isr_dispatch:
+        call    SYM(_Thread_Dispatch), 0
+        nop
+	 *  We invoked _Thread_Dispatch in a state similar to the interrupted
+	 *  task.  In order to safely be able to tinker with the register
+	 *  windows and get the task back to its pre-interrupt state,
+	 *  we need to disable interrupts disabled so we can safely tinker
+	 *  with the register windowing.  In particular, the CWP in the PSR
+	 *  is fragile during this period. (See PR578.)
+	mov	2,%g1				! syscall (disable interrupts)
+	ta	0				! syscall (disable interrupts)
+         *  While we had ISR dispatching disabled in this thread,
+         *  did we miss anything.  If so, then we need to do another
+         *  _Thread_Dispatch before leaving this ISR Dispatch context.
+        nop
+        ! Yes, then invoke the dispatcher
+dispatchAgain:
+	mov	3,%g1				! syscall (enable interrupts)
+	ta	0				! syscall (enable interrupts)
+        ba      isr_dispatch
+        nop
+allow_nest_again:
+        ! Zero out ISR stack nesting prevention flag
+        st       %g0,[%l5 + %lo(SYM(_CPU_ISR_Dispatch_disable))]
+         *  The CWP in place at this point may be different from
+         *  that which was in effect at the beginning of the ISR if we
+         *  have been context switched between the beginning of this invocation
+         *  of _ISR_Handler and this point.  Thus the CWP and WIM should
+         *  not be changed back to their values at ISR entry time.  Any
+         *  changes to the PSR must preserve the CWP.
+simple_return:
+        ld      [%fp + ISF_Y_OFFSET], %l5      ! restore y
+        wr      %l5, 0, %y
+        ldd     [%fp + ISF_PSR_OFFSET], %l0    ! restore psr, PC
+        ld      [%fp + ISF_NPC_OFFSET], %l2    ! restore nPC
+        rd      %psr, %l3
+        and     %l3, SPARC_PSR_CWP_MASK, %l3   ! want "current" CWP
+        andn    %l0, SPARC_PSR_CWP_MASK, %l0   ! want rest from task
+        or      %l3, %l0, %l0                  ! install it later...
+        andn    %l0, SPARC_PSR_ET_MASK, %l0
+         *  Restore tasks global and out registers
+        mov    %fp, %g1
+                                              ! g1 is restored later
+        ldd     [%fp + ISF_G2_OFFSET], %g2    ! restore g2, g3
+        ldd     [%fp + ISF_G4_OFFSET], %g4    ! restore g4, g5
+        ldd     [%fp + ISF_G6_OFFSET], %g6    ! restore g6, g7
+        ldd     [%fp + ISF_I0_OFFSET], %i0    ! restore i0, i1
+        ldd     [%fp + ISF_I2_OFFSET], %i2    ! restore i2, i3
+        ldd     [%fp + ISF_I4_OFFSET], %i4    ! restore i4, i5
+        ldd     [%fp + ISF_I6_FP_OFFSET], %i6 ! restore i6/fp, i7
+         *  Registers:
+         *   ALL global registers EXCEPT G1 and the input registers have
+         *   already been restored and thuse off limits.
+         *   The following is the contents of the local registers:
+         *     l0 = original psr
+         *     l1 = return address (i.e. PC)
+         *     l2 = nPC
+         *     l3 = CWP
+         *  if (CWP + 1) is an invalid window then we need to reload it.
+         *  WARNING: Traps should now be disabled
+        nop
+        nop
+        nop
+        rd      %wim, %l4
+        add     %l0, 1, %l6                ! l6 = cwp + 1
+        and     %l6, SPARC_PSR_CWP_MASK, %l6 ! do the modulo on it
+        srl     %l4, %l6, %l5              ! l5 = win >> cwp + 1 ; shift count
+                                           !  and CWP are conveniently LS 5 bits
+        cmp     %l5, 1                     ! Is tasks window invalid?
+        bne     good_task_window
+         *  The following code is the same as a 1 position left rotate of WIM.
+        sll     %l4, 1, %l5                ! l5 = WIM << 1
+        srl     %l4, SPARC_NUMBER_OF_REGISTER_WINDOWS-1 , %l4
+                                           ! l4 = WIM >> (Number Windows - 1)
+        or      %l4, %l5, %l4              ! l4 = (WIM << 1) |
+                                           !      (WIM >> (Number Windows - 1))
+         *  Now restore the window just as if we underflowed to it.
+        wr      %l4, 0, %wim               ! WIM = new WIM
+        nop                                ! must delay after writing WIM
+        nop
+        nop
+        restore                            ! now into the tasks window
+        ldd     [%g1 + CPU_STACK_FRAME_L0_OFFSET], %l0
+        ldd     [%g1 + CPU_STACK_FRAME_L2_OFFSET], %l2
+        ldd     [%g1 + CPU_STACK_FRAME_L4_OFFSET], %l4
+        ldd     [%g1 + CPU_STACK_FRAME_L6_OFFSET], %l6
+        ldd     [%g1 + CPU_STACK_FRAME_I0_OFFSET], %i0
+        ldd     [%g1 + CPU_STACK_FRAME_I2_OFFSET], %i2
+        ldd     [%g1 + CPU_STACK_FRAME_I4_OFFSET], %i4
+        ldd     [%g1 + CPU_STACK_FRAME_I6_FP_OFFSET], %i6
+                                           ! reload of sp clobbers ISF
+        save                               ! Back to ISR dispatch window
+good_task_window:
+	nop; nop; nop
+                                           !  and restore condition codes.
+        ld      [%g1 + ISF_G1_OFFSET], %g1 ! restore g1
+        jmp     %l1                        ! transfer control and
+        rett    %l2                        ! go back to tasks window
+/* end of file */
1.7.7
