[PATCH 10/12] sparc: Make _CPU_ISR_Dispatch_disable per-CPU
Mon Aug 5 14:08:17 UTC 2013
This variable must be available for each processor in the system.
 c/src/lib/libbsp/sparc/shared/irq_asm.S  |   42 ++++++++++++++---------------
 cpukit/score/cpu/sparc/cpu.c             |   14 +++++-----
 cpukit/score/cpu/sparc/rtems/score/cpu.h |   24 ++++++++++-------
 3 files changed, 41 insertions(+), 39 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
index d0550df..ce276cd 100644
--- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
+++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
@@ -20,7 +20,7 @@
 #include <rtems/asm.h>
-#include <rtems/system.h>
+#include <rtems/score/percpu.h>
 #include <bspopts.h>
 .macro GET_SELF_CPU_CONTROL REG, TMP
@@ -59,19 +59,11 @@ SYM(_CPU_Context_switch):
         std     %g4, [%o0 + G4_OFFSET]
         std     %g6, [%o0 + G6_OFFSET]
-        ! load the address of the ISR stack nesting prevention flag
-        sethi    %hi(SYM(_CPU_ISR_Dispatch_disable)), %g2
-        ld       [%g2 + %lo(SYM(_CPU_ISR_Dispatch_disable))], %g2
-        ! save it a bit later so we do not waste a couple of cycles
         std     %l0, [%o0 + L0_OFFSET]       ! save the local registers
         std     %l2, [%o0 + L2_OFFSET]
         std     %l4, [%o0 + L4_OFFSET]
         std     %l6, [%o0 + L6_OFFSET]
-        ! Now actually save ISR stack nesting prevention flag
-        st       %g2, [%o0 + ISR_DISPATCH_DISABLE_STACK_OFFSET]
         std     %i0, [%o0 + I0_OFFSET]       ! save the input registers
         std     %i2, [%o0 + I2_OFFSET]
         std     %i4, [%o0 + I4_OFFSET]
@@ -82,13 +74,24 @@ SYM(_CPU_Context_switch):
         std     %o4, [%o0 + O4_OFFSET]
         std     %o6, [%o0 + O6_SP_OFFSET]
+        ! o3 = self per-CPU control
+        GET_SELF_CPU_CONTROL %o3, %o4
+        ! load the ISR stack nesting prevention flag
+        ld      [%o3 + SPARC_PER_CPU_ISR_DISPATCH_DISABLE], %o4
+        ! save it a bit later so we do not waste a couple of cycles
         rd      %psr, %o2
         st      %o2, [%o0 + PSR_OFFSET]      ! save status register
+        ! Now actually save ISR stack nesting prevention flag
+        st       %o4, [%o0 + ISR_DISPATCH_DISABLE_STACK_OFFSET]
          *  This is entered from _CPU_Context_restore with:
          *    o1 = context to restore
          *    o2 = psr
+         *    o3 = self per-CPU control
         PUBLIC(_CPU_Context_restore_heir)
@@ -196,7 +199,6 @@ done_flushing:
         ! Load thread specific ISR dispatch prevention flag
         ld      [%o1 + ISR_DISPATCH_DISABLE_STACK_OFFSET], %o2
-        sethi    %hi(SYM(_CPU_ISR_Dispatch_disable)), %o3
         ! Store it to memory later to use the cycles
         ldd     [%o1 + L0_OFFSET], %l0        ! restore the local registers
@@ -205,7 +207,7 @@ done_flushing:
         ldd     [%o1 + L6_OFFSET], %l6
         ! Now restore thread specific ISR dispatch prevention flag
-        st       %o2,[%o3 + %lo(SYM(_CPU_ISR_Dispatch_disable))]
+        st      %o2, [%o3 + SPARC_PER_CPU_ISR_DISPATCH_DISABLE]
         ldd     [%o1 + I0_OFFSET], %i0        ! restore the output registers
         ldd     [%o1 + I2_OFFSET], %i2
@@ -235,6 +237,7 @@ done_flushing:
 SYM(_CPU_Context_restore):
         save    %sp, -CPU_MINIMUM_STACK_FRAME_SIZE, %sp
         rd      %psr, %o2
         ba      SYM(_CPU_Context_restore_heir)
         mov     %i0, %o1                      ! in the delay slot
         .align 4
@@ -591,11 +594,10 @@ dont_fix_pil2:
         orcc     %l6, %g0, %g0   ! Is dispatching disabled?
         bnz      simple_return   ! Yes, then do a "simple" exit
-        ! NOTE: Use the delay slot
-        sethi    %hi(SYM(_CPU_ISR_Dispatch_disable)), %l6
+        nop
         ! Are we dispatching from a previous ISR in the interrupted thread?
-        ld       [%l6 + %lo(SYM(_CPU_ISR_Dispatch_disable))], %l7
+        ld       [%l5 + SPARC_PER_CPU_ISR_DISPATCH_DISABLE], %l7
         orcc     %l7, %g0, %g0   ! Is this thread already doing an ISR?
         nop
@@ -606,9 +608,9 @@ dont_fix_pil2:
          *  return to the interrupt dispatcher.
-        ldub     [%l5 + PER_CPU_DISPATCH_NEEDED], %l5
+        ldub     [%l5 + PER_CPU_DISPATCH_NEEDED], %l6
-        orcc     %l5, %g0, %g0   ! Is thread switch necessary?
+        orcc     %l6, %g0, %g0   ! Is thread switch necessary?
         bz       simple_return   ! no, then do a simple return
         nop
@@ -616,12 +618,9 @@ dont_fix_pil2:
          *  Invoke interrupt dispatcher.
-        PUBLIC(_ISR_Dispatch)
-SYM(_ISR_Dispatch):
         ! Set ISR dispatch nesting prevention flag
         mov      1,%l6
-        sethi    %hi(SYM(_CPU_ISR_Dispatch_disable)), %l5
-        st       %l6,[%l5 + %lo(SYM(_CPU_ISR_Dispatch_disable))]
+        st       %l6, [%l5 + SPARC_PER_CPU_ISR_DISPATCH_DISABLE]
          *  The following subtract should get us back on the interrupted
@@ -676,8 +675,7 @@ dispatchAgain:
 allow_nest_again:
         ! Zero out ISR stack nesting prevention flag
-        st       %g0,[%l5 + %lo(SYM(_CPU_ISR_Dispatch_disable))]
+        st       %g0, [%l5 + SPARC_PER_CPU_ISR_DISPATCH_DISABLE]
          *  The CWP in place at this point may be different from
diff --git a/cpukit/score/cpu/sparc/cpu.c b/cpukit/score/cpu/sparc/cpu.c
index baa15c0..1865a21 100644
--- a/cpukit/score/cpu/sparc/cpu.c
+++ b/cpukit/score/cpu/sparc/cpu.c
@@ -19,8 +19,15 @@
 #include <rtems/score/isr.h>
 #include <rtems/rtems/cache.h>
+RTEMS_STATIC_ASSERT(
+  offsetof( Per_CPU_Control, cpu_per_cpu.isr_dispatch_disable)
+    == SPARC_PER_CPU_ISR_DISPATCH_DISABLE,
  *  This initializes the set of opcodes placed in each trap
  *  table entry.  The routine which installs a handler is responsible
@@ -65,13 +72,6 @@ void _CPU_Initialize(void)
   pointer = &_CPU_Null_fp_context;
   _CPU_Context_save_fp( &pointer );
 #endif
-   *  Since no tasks have been created yet and no interrupts have occurred,
-   *  there is no way that the currently executing thread can have an
-   *  _ISR_Dispatch stack frame on its stack.
-  _CPU_ISR_Dispatch_disable = 0;
 uint32_t   _CPU_ISR_Get_level( void )
diff --git a/cpukit/score/cpu/sparc/rtems/score/cpu.h b/cpukit/score/cpu/sparc/rtems/score/cpu.h
index 61f0410..690ddcf 100644
--- a/cpukit/score/cpu/sparc/rtems/score/cpu.h
+++ b/cpukit/score/cpu/sparc/rtems/score/cpu.h
@@ -357,7 +357,13 @@ typedef struct {
 /** This defines the size of the minimum stack frame. */
 #define CPU_MINIMUM_STACK_FRAME_SIZE          0x60
-#define CPU_PER_CPU_CONTROL_SIZE 0
+#define CPU_PER_CPU_CONTROL_SIZE 4
+ * @brief Offset of the CPU_Per_CPU_control::isr_dispatch_disable field
+ * relative to the Per_CPU_Control begin.
+#define SPARC_PER_CPU_ISR_DISPATCH_DISABLE 0
  * @defgroup Contexts SPARC Context Structures
@@ -383,7 +389,13 @@ typedef struct {
 #ifndef ASM
 typedef struct {
-  /* There is no CPU specific per-CPU state */
+   * This flag is context switched with each thread.  It indicates
+   * that THIS thread has an _ISR_Dispatch stack frame on its stack.
+   * By using this flag, we can avoid nesting more interrupt dispatching
+   * attempts on a previously interrupted thread's stack.
+  uint32_t isr_dispatch_disable;
 } CPU_Per_CPU_control;
@@ -769,14 +781,6 @@ typedef struct {
 SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context CPU_STRUCTURE_ALIGNMENT;
- * This flag is context switched with each thread.  It indicates
- * that THIS thread has an _ISR_Dispatch stack frame on its stack.
- * By using this flag, we can avoid nesting more interrupt dispatching
- * attempts on a previously interrupted thread's stack.
-SCORE_EXTERN volatile uint32_t _CPU_ISR_Dispatch_disable;
  * The following type defines an entry in the SPARC's trap table.
  * NOTE: The instructions chosen are RTEMS dependent although one is
1.7.7
