[PATCH 11/12] bsps/i386: Revert most SMP related changes
Mon Aug 5 14:08:18 UTC 2013
The commit partially restores the _ISR_Handler code to the original
version in commit b8fc2de1ce089c585da81c157ec0f24a90e484b7.  A list of
reverted changes follows.
commit c236082873cb4a2fd42af4ca0868106e1dd65422
Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
Date:   Tue Jul 30 15:54:53 2013 +0200
    smp: Provide cache optimized Per_CPU_Control
    Delete _Per_CPU_Information_p.
This commit was completely reverted.
commit 39e51758c86754cef5ba4521c0c36578521f73d0
Date:   Fri Jun 14 14:00:38 2013 +0200
    smp: Add and use _CPU_SMP_Get_current_processor()
    Add and use _SMP_Get_current_processor() and
    rtems_smp_get_current_processor().
    Delete bsp_smp_interrupt_cpu().
    Change type of current processor index from int to uint32_t to match
    _SMP_Processor_count type.
commit e94aa61b6820e34732840139dbe3f2016c6f1e24
Author: Till Straumann <strauman at slac.stanford.edu>
Date:   Fri Aug 5 00:15:50 2011 +0000
    2011-08-04	Till Straumann <strauman at slac.stanford.edu>
    	* shared/irq/irq_asm.S: BUGFIX (introduced by SMP changes
    	which moved code around, apparently): *must* store i8259
    	mask to frame *before* switching to IRQ stack. The code
    	retrieves the mask after switching back to original stack.
    	Also, the IRQ stack has no reserved space for the mask;
    	storing it there could overwrite memory!
commit 01f2692e338d592f363b2e27b2f62d8182d1124e
Author: Jennifer Averett <Jennifer.Averett at OARcorp.com>
Date:   Mon Aug 1 13:41:50 2011 +0000
    2011-08-01	Jennifer Averett <Jennifer.Averett at OARcorp.com>
    	PR 1802
    	* shared/irq/irq_asm.S, shared/irq/irq_init.c, shared/smp/smp-imps.c,
    	shared/smp/smp-imps.h: Add SMP support for i386.
    	* shared/smp/getcpuid.c: New file.
The parts modifying the code of _ISR_Handler were reverted.
commit 66729db3115e865fa45bc4e9ab81d8266894151c
Author: Joel Sherrill <joel.sherrill at OARcorp.com>
Date:   Wed Mar 16 20:05:17 2011 +0000
    2011-03-16	Jennifer Averett <jennifer.averett at OARcorp.com>
    	PR 1729/cpukit
    	* shared/irq/irq_asm.S: Add next step in SMP support. This adds an
    	allocated array of the Per_CPU structures to support multiple cpus vs
    	a single instance of the structure which is still used if SMP support
    	is disabled. Configuration support is also added to explicitly enable
    	or disable SMP. But SMP can only be enabled for the CPUs which will
    	support it initially -- SPARC and i386. With the stub BSP support, a
    	BSP can be run as a single core SMP system from an RTEMS data
    	structure standpoint.
 c/src/lib/libbsp/i386/shared/irq/irq_asm.S |  100 +++++++++++++---------------
 1 files changed, 46 insertions(+), 54 deletions(-)
diff --git a/c/src/lib/libbsp/i386/shared/irq/irq_asm.S b/c/src/lib/libbsp/i386/shared/irq/irq_asm.S
index bbc1afb..f77dd7f 100644
--- a/c/src/lib/libbsp/i386/shared/irq/irq_asm.S
+++ b/c/src/lib/libbsp/i386/shared/irq/irq_asm.S
@@ -44,9 +44,17 @@ SYM (_ISR_Handler):
 	 *  Before this was point is reached the vectors unique
 	 *  entry point did the following:
-	 *     1. saved scratch registers registers eax edx ecx
+	 *     1. saved scratch registers registers eax edx ecx"
 	 *     2. put the vector number in ecx.
+	 * BEGINNING OF ESTABLISH SEGMENTS
+	 *  WARNING: If an interrupt can occur when the segments are
+	 *           not correct, then this is where we should establish
+	 *           the segments.  In addition to establishing the
+	 *           segments, it may be necessary to establish a stack
+	 *           in the current data area on the outermost interrupt.
 	 *  NOTE:  If the previous values of the segment registers are
 	 *         pushed, do not forget to adjust SAVED_REGS.
@@ -74,8 +82,6 @@ SYM (_ISR_Handler):
 	movl      ebx, EBX_OFF(esp)
 	movl      eax, ESP_OFF(esp)
 	movl      ebp, EBP_OFF(esp)
-	movw      SYM (i8259s_cache), ax /* save current i8259 interrupt mask */
-	movl      eax, MSK_OFF(esp)      /* save in stack frame */
 #ifdef __SSE__
 	/* NOTE: SSE only is supported if the BSP enables fxsave/fxrstor
@@ -96,54 +102,15 @@ SYM (_ISR_Handler):
 	ldmxcsr ARG_OFF(esp)            /* clean-slate MXCSR              */
 #endif
-.check_stack_switch:
-	movl      esp, ebp                  /* ebp = previous stack pointer */
-#if defined(RTEMS_SMP) && defined(BSP_HAS_SMP)
-	call     SYM(_CPU_SMP_Get_current_processor)
-	sall     $PER_CPU_CONTROL_SIZE_LOG2, eax
-	addl     $SYM(_Per_CPU_Information), eax
-	movl     eax, ebx
-        pushl    ecx
-        call     SYM(_ISR_SMP_Enter)
-        popl     ecx
-        cmpl     $0, eax
-        jne      .i8259
-        movl     PER_CPU_INTERRUPT_STACK_HIGH(ebx), esp
-#else
-	movl     $SYM(_Per_CPU_Information), ebx
-         *  Is this the outermost interrupt?
-	 *  Switch stacks if necessary
-	cmpl      $0, PER_CPU_ISR_NEST_LEVEL(ebx)
-	jne       nested                    /* No, then continue */
-	 *  We want to insure that the old stack pointer is in ebp
-	 *  By saving it on every interrupt, all we have to do is
-	 *  movl ebp->esp near the end of every interrupt.
-nested:
-	incl      PER_CPU_ISR_NEST_LEVEL(ebx)  /* one nest level deeper */
-	incl      SYM (_Thread_Dispatch_disable_level) /* disable multitasking */
-#endif
-         *  i8259 Management
-.i8259:
         /* Do not disable any 8259 interrupts if this isn't from one */
 	cmp       ecx, 16               /* is this a PIC IRQ? */
-	jge       .end_of_i8259
+	jge       .check_stack_switch
 	 * acknowledge the interrupt
-	movw      SYM (i8259s_cache), ax /* fetch current i8259 interrupt mask */
+	movw      SYM (i8259s_cache), ax /* save current i8259 interrupt mask */
+	movl      eax, MSK_OFF(esp)      /* save in stack frame */
 	 * compute the new PIC mask:
@@ -167,7 +134,39 @@ nested:
 	outb      $PIC_SLAVE_COMMAND_IO_PORT
 .master:
 	outb      $PIC_MASTER_COMMAND_IO_PORT
-.end_of_i8259:
+	 *  Now switch stacks if necessary
+PUBLIC (ISR_STOP)
+ISR_STOP:
+.check_stack_switch:
+	movl      esp, ebp                  /* ebp = previous stack pointer */
+	movl      $SYM(_Per_CPU_Information), ebx
+	/* is this the outermost interrupt? */
+	cmpl      $0, PER_CPU_ISR_NEST_LEVEL(ebx)
+	jne       nested                    /* No, then continue */
+	movl      PER_CPU_INTERRUPT_STACK_HIGH(ebx), esp
+	 *  We want to insure that the old stack pointer is in ebp
+	 *  By saving it on every interrupt, all we have to do is
+	 *  movl ebp->esp near the end of every interrupt.
+nested:
+	incl      PER_CPU_ISR_NEST_LEVEL(ebx)  /* one nest level deeper */
+	incl      SYM (_Thread_Dispatch_disable_level) /* disable multitasking */
+	 * GCC versions starting with 4.3 no longer place the cld
+	 * instruction before string operations.  We  need to ensure
+	 * it is set correctly for ISR handlers.
+	cld
 	 * re-enable interrupts at processor level as the current
@@ -210,14 +209,8 @@ nested:
 	outb	  $PIC_MASTER_IMR_IO_PORT
 	movb	  ah, al
 	outb	  $PIC_SLAVE_IMR_IO_PORT
-.dont_restore_i8259:
-        call    SYM(_ISR_SMP_Exit)
-	testl	eax, eax
-	je	.exit
-#else
+.dont_restore_i8259:
 	decl      PER_CPU_ISR_NEST_LEVEL(ebx)  /* one less ISR nest level */
 	                                    /* If interrupts are nested, */
 	                                    /*   then dispatching is disabled */
@@ -231,7 +224,6 @@ nested:
 	                                    /* Is task switch necessary? */
 	jne       .schedule                 /* Yes, then call the scheduler */
 	jmp       .exit                     /* No, exit */
-#endif
 .schedule:
1.7.7
