Current head compilation problem
Fri Aug 16 14:07:45 UTC 2013
CC:Vipul
Vipul, please have a look at the pc386 and determine if the changes
you provided have caused the compilation errors we are seeing.
-Gedare
On Thu, Aug 15, 2013 at 11:00 PM, Chris Johns <chrisj at rtems.org> wrote:
> Sree Harsha Konduri wrote:
>> ../../../../../pc386/lib/librtemsbsp.a(ckinit.o): In function
>> `bsp_clock_nanoseconds_since_last_tick_i8254':
>> /home/harsha/rtems/4.11/pc386/i386-rtems4.11/c/pc386/lib/libbsp/i386/pc386/../../../../../../../../rtems/c/src/lib/libbsp/i386/pc386/clock/ckinit.c:153:
>> undefined reference to `Clock_driver_isrs'
> The clock driver in the pc looks suspect. The clockdrv_shell.h code in the
> bsp/shared area uses CLOCK_DRIVER_ISRS_PER_TICK as a 0 or 1 to determine if
> it is enabled or disabled while this clock driver seems to do something
> different with the same label. It also has a bug where the data is
> conditional while the code expects it to be present. I do not understand the
> logic being used here. Someone who knows this driver will need to comment
> and look at a fix.
> The fix I pushed to the clockdrv_shell.h's use of CLOCK_DRIVER_ISRS_PER_TICK
> is correct and RTEMS's use of defining 0 and 1 to things via BSPOPTS then
> using '#ifdef' is broken. All BSPOPT defines need to be '#if ....'.
> Chris
> rtems-devel mailing list
> rtems-devel at rtems.org
