Current head compilation problem
    Sebastian Huber
    Mon Aug 19 08:19:34 UTC 2013
On 2013-08-16 05:00, Chris Johns wrote:
> The fix I pushed to the clockdrv_shell.h's use of CLOCK_DRIVER_ISRS_PER_TICK is
> correct and RTEMS's use of defining 0 and 1 to things via BSPOPTS then using
> '#ifdef' is broken. All BSPOPT defines need to be '#if ....'.
Its not strictly necessary to convert all BSP options to #if since you can
undefine them on the command line, e.g. a "configure ... 'X='" will not define X.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
