Current head compilation problem
Gedare Bloom
gedare at rtems.org
Mon Aug 26 20:17:42 UTC 2013
Committed with small modifications.
On Fri, Aug 16, 2013 at 4:57 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> I think the change from #ifdef to #if changed this.
> pc386 set CLOCK_DRIVER_ISRS_PER_TICK to a
> string rather than a numeric value. I added
> CLOCK_DRIVER_ISRS_PER_TICK_VALUE and
> did some other clean up on the driver.
> With the attached patch, it compiles again and
> ticker runs.
> Please review and let me know if OK to commit.
> On 8/16/2013 11:03 AM, Gedare Bloom wrote:
>> OK. If you find the bug in the modified clockdrv_shell.h think about
>> how it might be fixed.
>> On Fri, Aug 16, 2013 at 11:49 AM, Vipul Nayyar <nayyar_vipul at yahoo.com>
>> wrote:
>>> Hello,
>>> Will look more closely into the matter.
>>> FWIW, I compiled the pc386 bsp giving the same configure statement as
>>> Sree
>>> gave, in my personal fork of rtems from github which is about 18 or so
>>> commits behind the master( that means my fork does not contain Sebastian
>>> Chris' #define -> #if patches).
>>> And it compiled successfully, without giving any errors.
>>> What I feel, is that the following two patches that modified
>>> clockdrv_shell.h need to be checked again..
>>> http://git.rtems.org/rtems/commit/?id=b7f206097313f794dbe53202542b5894aad6a117
>>> http://git.rtems.org/rtems/commit/?id=d473dc0b22d3276130f893a51350c8bfb8beaac8
>>> My patches for pc386 were checked carefully by Sebastian, but will have
>>> to
>>> look more closely to find any bug caused due to my patches.
>>> Regards
>>> Vipul Nayyar
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
