[PATCH 3/6] add smppflock01 test case
    WeiY
    wei.a.yang at gmail.com
    Mon Aug 19 15:39:45 UTC 2013
 testsuites/smptests/smppflock01/Makefile.am     |   19 +++
 testsuites/smptests/smppflock01/init.c          |  176 +++++++++++++++++++++++
 testsuites/smptests/smppflock01/smppflock01.doc |   17 +++
 3 files changed, 212 insertions(+)
 create mode 100644 testsuites/smptests/smppflock01/Makefile.am
 create mode 100644 testsuites/smptests/smppflock01/init.c
 create mode 100644 testsuites/smptests/smppflock01/smppflock01.doc
 create mode 100644 testsuites/smptests/smppflock01/smppflock01.scn
diff --git a/testsuites/smptests/smppflock01/Makefile.am b/testsuites/smptests/smppflock01/Makefile.am
new file mode 100644
index 0000000..74a1810
--- /dev/null
+++ b/testsuites/smptests/smppflock01/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smppflock01
+smppflock01_SOURCES = init.c ../../support/src/locked_print.c
+dist_rtems_tests_DATA = smppflock01.scn smppflock01.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(smppflock01_OBJECTS)
+LINK_LIBS = $(smppflock01_LDLIBS)
+smppflock01$(EXEEXT): $(smppflock01_OBJECTS) $(smppflock01_DEPENDENCIES)
+	@rm -f smppflock01$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smppflock01/init.c b/testsuites/smptests/smppflock01/init.c
index 0000000..987a200
--- /dev/null
+++ b/testsuites/smptests/smppflock01/init.c
@@ -0,0 +1,176 @@
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <rtems/score/smprwlock.h>
+#include "tmacros.h"
+#define TASK_PRIORITY 1
+#define CPU_COUNT 32
+#define TEST_COUNT 10
+ *  Keep the names and IDs in global variables so another task can use them.
+volatile bool TaskRan[ CPU_COUNT ];
+static Atomic_Uint locked;
+static SMP_rwlock_Control lock;
+static void task(rtems_task_argument arg)
+  SMP_rwlock_Control *pflock = (SMP_rwlock_Control *) arg;
+//  uint32_t cpu_count = rtems_smp_get_processor_count();
+  uint32_t cpu_self = rtems_smp_get_current_processor();
+  rtems_status_code sc;
+  uint_fast32_t l;
+  int i = TEST_COUNT;
+  /* XXX - Delay a bit to allow debug messages from
+   * startup to print.  This may need to go away when
+   * debug messages go away.
+  locked_print_initialize();
+  while (i--) {
+    _SMP_rwlock_Acquire_write(pflock);
+      l = _Atomic_Load_uint(&locked, ATOMIC_ORDER_ACQUIRE);
+      if (l != 0) {
+        locked_printf("ERROR [WR:%d]: %u != 0\n", __LINE__, l);
+      _Atomic_Fetch_add_uint(&locked, 1, ATOMIC_ORDER_RELEASE);
+      if (l != 8) {
+        locked_printf("ERROR [WR:%d]: %u != 2\n", __LINE__, l);
+      _Atomic_Fetch_sub_uint(&locked, 1, ATOMIC_ORDER_RELEASE);
+      if (l != 0) {
+	  _SMP_rwlock_Release_write(&lock);
+	  _SMP_rwlock_Acquire_read(&lock);
+	    _Atomic_Load_uint(&locked, ATOMIC_ORDER_ACQUIRE);
+	    if (l != 0) {
+	      locked_printf("ERROR [RD:%d]: %u != 0\n", __LINE__, l);
+	  _SMP_rwlock_Release_read(&lock);
+  /* Set the flag that the task is up and running */
+  TaskRan[cpu_self] = true;
+  sc = rtems_task_suspend(RTEMS_SELF);
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+static void test(void)
+  SMP_rwlock_Control *pflock = &lock;
+  uint32_t cpu_count = rtems_smp_get_processor_count();
+  uint32_t cpu;
+  int i;
+  char ch;
+  _SMP_rwlock_Initialize(pflock);
+/* Initialize the TaskRan array */
+  for ( i=0; i<cpu_count; i++ ) {
+    TaskRan[i] = false;
+  for (cpu = 0; cpu < cpu_count; ++cpu) {
+    if (cpu != cpu_self) {
+      rtems_id task_id;
+      ch = '0' + cpu;
+      sc = rtems_task_create(
+        rtems_build_name('T', 'A', ch, ' '),
+        TASK_PRIORITY,
+        RTEMS_MINIMUM_STACK_SIZE,
+        RTEMS_DEFAULT_MODES,
+        RTEMS_DEFAULT_ATTRIBUTES,
+        &task_id
+      sc = rtems_task_start(task_id, task, (rtems_task_argument) pflock);
+static void Init(rtems_task_argument arg)
+  bool allDone;
+  int i;
+  puts("\n\n*** TEST SMP phase_fair lock 1 ***");
+  test();
+  /* Wait on the all tasks to run */
+  while (1) {
+    allDone = true;
+    for ( i=1; i<cpu_count; i++ ) {
+      if (TaskRan[i] == false)
+        allDone = false;
+    if (allDone) {
+      locked_printf( "\n\n*** END OF TEST SMP phase_fair lock 1 ***\n" );
+      rtems_test_exit( 0 );
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_SMP_APPLICATION
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
+#define CONFIGURE_MAXIMUM_TASKS CPU_COUNT
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+#define CONFIGURE_MAXIMUM_TIMERS 1
+#define CONFIGURE_INIT_TASK_PRIORITY TASK_PRIORITY
+#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_DEFAULT_ATTRIBUTES
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smppflock01/smppflock01.doc b/testsuites/smptests/smppflock01/smppflock01.doc
index 0000000..b8f74ba
--- /dev/null
+++ b/testsuites/smptests/smppflock01/smppflock01.doc
@@ -0,0 +1,17 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smppflock01
+The screen file was obtained on a PowerPC QorIQ P1020E target running with a
+processor frequency of 800MHz.
+directives:
+  - _SMP_rwlock_Acquire_write()
+  - _SMP_rwlock_Release_write()
+  - _SMP_rwlock_Acquire_read()
+  - _SMP_rwlock_Release_read()
+concepts:
+  - Valid the SMP rwlock correctness
diff --git a/testsuites/smptests/smppflock01/smppflock01.scn b/testsuites/smptests/smppflock01/smppflock01.scn
index 0000000..e69de29
1.7.9.5
