[PATCH 4/6] add smppflock02 test case
WeiY wei.a.yang at gmail.com
Mon Aug 19 15:39:46 UTC 2013
 testsuites/smptests/smppflock02/Makefile.am     |   19 +++
 testsuites/smptests/smppflock02/init.c          |  173 +++++++++++++++++++++++
 testsuites/smptests/smppflock02/smppflock02.doc |   17 +++
 3 files changed, 209 insertions(+)
 create mode 100644 testsuites/smptests/smppflock02/Makefile.am
 create mode 100644 testsuites/smptests/smppflock02/init.c
 create mode 100644 testsuites/smptests/smppflock02/smppflock02.doc
 create mode 100644 testsuites/smptests/smppflock02/smppflock02.scn
diff --git a/testsuites/smptests/smppflock02/Makefile.am b/testsuites/smptests/smppflock02/Makefile.am
new file mode 100644
index 0000000..668a4df
--- /dev/null
+++ b/testsuites/smptests/smppflock02/Makefile.am
@@ -0,0 +1,19 @@
+rtems_tests_PROGRAMS = smppflock02
+smppflock02_SOURCES = init.c ../../support/src/locked_print.c
+dist_rtems_tests_DATA = smppflock02.scn smppflock02.doc
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+AM_CPPFLAGS += -I$(top_srcdir)/../support/include
+LINK_OBJS = $(smppflock02_OBJECTS)
+LINK_LIBS = $(smppflock02_LDLIBS)
+smppflock02$(EXEEXT): $(smppflock02_OBJECTS) $(smppflock02_DEPENDENCIES)
+	@rm -f smppflock02$(EXEEXT)
+	$(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smppflock02/init.c b/testsuites/smptests/smppflock02/init.c
index 0000000..50050f0
--- /dev/null
+++ b/testsuites/smptests/smppflock02/init.c
@@ -0,0 +1,173 @@
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems.h>
+#include <rtems/score/smprwlock.h>
+#include "tmacros.h"
+#define TASK_PRIORITY 1
+#define CPU_COUNT 32
+typedef enum {
+  INITIAL,
+  START_TEST,
+  STOP_TEST
+} states;
+typedef struct {
+  Atomic_Uint state;
+  rtems_id timer_id;
+  rtems_interval timeout;
+  unsigned long test_counter[CPU_COUNT];
+  SMP_rwlock_Control lock;
+} global_context;
+static global_context context = {
+  .state = ATOMIC_VAR_INITIALIZER(INITIAL),
+  .lock = SMP_RWLOCK_INITIALIZER
+static void stop_test_timer(rtems_id timer_id, void *arg)
+  global_context *ctx = arg;
+  _Atomic_Store_uint(&ctx->state, STOP_TEST, ATOMIC_ORDER_RELEASE);
+static bool assert_state(global_context *ctx, uint_fast32_t desired_state)
+  return _Atomic_Load_uint(&ctx->state, ATOMIC_ORDER_ACQUIRE) == desired_state;
+static void task_write(rtems_task_argument arg)
+  global_context *ctx = (global_context *) arg;
+  uint32_t cpu_count = rtems_smp_get_processor_count();
+  uint32_t cpu_self = rtems_smp_get_current_processor();
+  rtems_status_code sc;
+  while (assert_state(ctx, START_TEST)) {
+    _SMP_rwlock_Acquire_write(&ctx->lock);
+    ++ctx->test_counter[cpu_self];
+    _SMP_rwlock_Release_write(&ctx->lock);
+  sc = rtems_task_suspend(RTEMS_SELF);
+  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+static void task_read(rtems_task_argument arg)
+    _SMP_rwlock_Acquire_read(&ctx->lock);
+    _SMP_rwlock_Release_read(&ctx->lock);
+static void test(void)
+  global_context *ctx = &context;
+  uint32_t cpu;
+  for (cpu = 0; cpu < cpu_count; ++cpu) {
+    if (cpu != cpu_self) {
+      rtems_id task_id;
+      sc = rtems_task_create(
+        rtems_build_name('T', 'A', 'S', 'K'),
+        TASK_PRIORITY,
+        RTEMS_MINIMUM_STACK_SIZE,
+        RTEMS_DEFAULT_MODES,
+        RTEMS_DEFAULT_ATTRIBUTES,
+        &task_id
+      sc = rtems_task_start(task_id, task_read, (rtems_task_argument) ctx);
+  ctx->timeout = 10 * rtems_clock_get_ticks_per_second();
+  sc = rtems_timer_create(rtems_build_name('T', 'I', 'M', 'R'), &ctx->timer_id);
+  sc = rtems_timer_fire_after(
+    ctx->timer_id,
+    ctx->timeout,
+    stop_test_timer,
+    ctx
+  _Atomic_Store_uint(&ctx->state, START_TEST, ATOMIC_ORDER_RELEASE);
+  task_write((rtems_task_argument) ctx);
+    unsigned long local_counter = ctx->test_counter[cpu];
+      printf(
+        "\tprocessor %" PRIu32 ", read task local counter %lu\n",
+        cpu,
+        local_counter
+    } else {
+      printf(
+        "\tprocessor %" PRIu32 ", write task local counter %lu\n",
+        cpu,
+        local_counter
+static void Init(rtems_task_argument arg)
+  puts("\n\n*** TEST SMP phase_fair lock 2 ***");
+  test();
+  puts("*** END OF TEST SMP phase_fair lock 2 ***");
+  rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_SMP_APPLICATION
+#define CONFIGURE_SMP_MAXIMUM_PROCESSORS CPU_COUNT
+#define CONFIGURE_MAXIMUM_TASKS CPU_COUNT
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+#define CONFIGURE_MAXIMUM_TIMERS 1
+#define CONFIGURE_INIT_TASK_PRIORITY TASK_PRIORITY
+#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_DEFAULT_ATTRIBUTES
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/smptests/smppflock02/smppflock02.doc b/testsuites/smptests/smppflock02/smppflock02.doc
index 0000000..21323df
--- /dev/null
+++ b/testsuites/smptests/smppflock02/smppflock02.doc
@@ -0,0 +1,17 @@
+This file describes the directives and concepts tested by this test set.
+test set name: smppflock02
+The screen file was obtained on a PowerPC QorIQ P1020E target running with a
+processor frequency of 800MHz.
+directives:
+  - _SMP_rwlock_Acquire_write()
+  - _SMP_rwlock_Release_write()
+  - _SMP_rwlock_Acquire_read()
+  - _SMP_rwlock_Release_read()
+concepts:
+  - Valid the SMP phase_fair properties implementation
diff --git a/testsuites/smptests/smppflock02/smppflock02.scn b/testsuites/smptests/smppflock02/smppflock02.scn
index 0000000..e69de29
1.7.9.5
