Posix Tests Compiler Warnings
Wed Aug 21 13:05:47 UTC 2013
Hello,
before we start here we should first fix the <inttypes.h> provided by Newlib:
http://www.rtems.org/pipermail/rtems-devel/2013-August/004055.html
On 2013-08-21 06:33, Rempel, Cynthia wrote:
> Hi,
> Reducing the number of unnecessary compiler warnings makes it easier to find (and fix) real compiler warnings...
> The fix is in accordance with:
> https://www.kernel.org/doc/Documentation/printk-formats.txt
> If <type> is dependent on a config option for its size (e.g., sector_t,
> blkcnt_t) or is architecture-dependent for its size (e.g., tcflag_t), use a
> format specifier of its largest possible type and explicitly cast to it.
> This patch reduces the number of posix tests compiler warnings, by recasting arguments in printf statements...
> Thanks,
> Cynthia Rempel
> rtems-devel mailing list
> rtems-devel at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
