Raspberry/ARM processor halts when invalidating tlb
    Alan Cudmore
    alan.cudmore at gmail.com
    Fri Aug 23 02:19:40 UTC 2013
Hi Hesham,
I don't have an answer for you, but you may be able to find some help or
example code on the raspberrypi.org forums.
A couple of examples:
http://www.raspberrypi.org/phpBB3/viewtopic.php?t=40183&p=336705
http://www.raspberrypi.org/phpBB3/viewtopic.php?t=40665&p=332205
I avoided the MMU setup on the raspberry pi BSP, because I knew that the
GPU based bootloader set up the memory for the ARM CPU. More info on the
whole boot process here:
http://elinux.org/RPi_Software
Another nice thing to have for work like this is a JTAG debugger setup.
I hope I can get an inexpensive setup for mine before I try to add any
more drivers.
The readme at the repository below has some good info on setting up JTAG
on the raspberry pi:
https://github.com/dwelch67/raspberrypi/tree/master/armjtag
Alan
On 8/22/2013 6:48 PM, Hesham Moustafa wrote:
> Hey all,
> I am working on Raspberry Pi BSP which has ARM1176JZF-S (ARMv6)
> processor on it. Here is what I am doing that causes the processor to
> halt:
> At BSP startup, specifically in bsp_start_hook_0 function, I call
> another function that :
> 1- Initialize first level page tables (sections) with READ/WRITE
> permissions.
> 2- Invalidate TLB.
> 3- Enable MMU, Cache, Protection bits in control register.
> Initialization is done correctly and the program reaches my
> application (test case), which tries to update first level page table
> entries to force another protection attributes for a memory region. At
> this part, after, or before, modifying the page table entry, I try to
> invalidate TLB but the program halts there. I disable MMU and Caches
> during updating page tables and invalidating TLB.
> When removing the function call that invalidates the TLB, the program
> proceed to the end successfully.
> Not sure why the processor halts when trying to invalidate the TLB "at
> the second time". I hope someone can tell me the reason.
> Regards,
> Hesham
> rtems-devel mailing list
> rtems-devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130822/479ab767/attachment-0001.html>
