[PATCH 2/2] score: PR2140: Fix _Thread_queue_Process_timeout()
Sebastian Huber
Fri Aug 23 10:58:33 UTC 2013
The _Thread_queue_Process_timeout() operation had several race
conditions in the event of nested interrupts. Protect the critical
sections via disabled interrupts.
cpukit/score/src/threadqprocesstimeout.c | 37 +++++++++++++++++++++++------
1 files changed, 29 insertions(+), 8 deletions(-)
diff --git a/cpukit/score/src/threadqprocesstimeout.c b/cpukit/score/src/threadqprocesstimeout.c
index 6aaf445..11df85b 100644
--- a/cpukit/score/src/threadqprocesstimeout.c
+++ b/cpukit/score/src/threadqprocesstimeout.c
@@ -25,7 +25,8 @@ void _Thread_queue_Process_timeout(
Thread_Control *the_thread
- Thread_queue_Control *the_thread_queue = the_thread->Wait.queue;
+ Thread_queue_Control *the_thread_queue;
+ ISR_Level level;
* If the_thread_queue is not synchronized, then it is either
@@ -39,15 +40,35 @@ void _Thread_queue_Process_timeout(
* a timeout is not allowed to occur.
- if ( the_thread_queue->sync_state != THREAD_BLOCKING_OPERATION_SYNCHRONIZED &&
- _Thread_Is_executing( the_thread ) ) {
- if ( the_thread_queue->sync_state != THREAD_BLOCKING_OPERATION_SATISFIED ) {
- the_thread->Wait.return_code = the_thread->Wait.queue->timeout_status;
- the_thread_queue->sync_state = THREAD_BLOCKING_OPERATION_TIMEOUT;
+ _ISR_Disable( level );
+ the_thread_queue = the_thread->Wait.queue;
+ if ( the_thread_queue != NULL ) {
+ if ( the_thread_queue->sync_state != THREAD_BLOCKING_OPERATION_SYNCHRONIZED &&
+ _Thread_Is_executing( the_thread ) ) {
+ if ( the_thread_queue->sync_state != THREAD_BLOCKING_OPERATION_SATISFIED ) {
+ the_thread->Wait.return_code = the_thread_queue->timeout_status;
+ the_thread_queue->sync_state = THREAD_BLOCKING_OPERATION_TIMEOUT;
+ _ISR_Enable( level );
+ } else {
+ bool we_did_it;
+ * We can use the_thread_queue pointer here even if
+ * the_thread->Wait.queue is already set to NULL since the extract
+ * operation will only use the thread queue discipline to select the
+ * right extract operation. The timeout status is set during thread
+ * queue initialization.
+ we_did_it = _Thread_queue_Extract( the_thread_queue, the_thread );
+ if ( we_did_it ) {
} else {
- _Thread_queue_Extract( the_thread->Wait.queue, the_thread );
1.7.7
