[PATCH 2/2] score: PR2140: Fix _Thread_queue_Process_timeout()
Gedare Bloom
gedare at rtems.org
Fri Aug 23 14:46:58 UTC 2013
This seems OK. I have not looked deeply enough but it bugs me that
maybe there is a race condition on the_thread->Wait.return_code also?
-Gedare
On Fri, Aug 23, 2013 at 6:58 AM, Sebastian Huber
> The _Thread_queue_Process_timeout() operation had several race
> conditions in the event of nested interrupts. Protect the critical
> sections via disabled interrupts.
> cpukit/score/src/threadqprocesstimeout.c | 37 +++++++++++++++++++++++------
> 1 files changed, 29 insertions(+), 8 deletions(-)
> diff --git a/cpukit/score/src/threadqprocesstimeout.c b/cpukit/score/src/threadqprocesstimeout.c
> index 6aaf445..11df85b 100644
> --- a/cpukit/score/src/threadqprocesstimeout.c
> +++ b/cpukit/score/src/threadqprocesstimeout.c
> @@ -25,7 +25,8 @@ void _Thread_queue_Process_timeout(
> Thread_Control *the_thread
> - Thread_queue_Control *the_thread_queue = the_thread->Wait.queue;
> + Thread_queue_Control *the_thread_queue;
> + ISR_Level level;
> * If the_thread_queue is not synchronized, then it is either
> @@ -39,15 +40,35 @@ void _Thread_queue_Process_timeout(
> * a timeout is not allowed to occur.
> - if ( the_thread_queue->sync_state != THREAD_BLOCKING_OPERATION_SYNCHRONIZED &&
> - _Thread_Is_executing( the_thread ) ) {
> - if ( the_thread_queue->sync_state != THREAD_BLOCKING_OPERATION_SATISFIED ) {
> - the_thread->Wait.return_code = the_thread->Wait.queue->timeout_status;
> - the_thread_queue->sync_state = THREAD_BLOCKING_OPERATION_TIMEOUT;
> + _ISR_Disable( level );
> + the_thread_queue = the_thread->Wait.queue;
> + if ( the_thread_queue != NULL ) {
> + if ( the_thread_queue->sync_state != THREAD_BLOCKING_OPERATION_SYNCHRONIZED &&
> + _Thread_Is_executing( the_thread ) ) {
> + if ( the_thread_queue->sync_state != THREAD_BLOCKING_OPERATION_SATISFIED ) {
> + the_thread->Wait.return_code = the_thread_queue->timeout_status;
> + the_thread_queue->sync_state = THREAD_BLOCKING_OPERATION_TIMEOUT;
> + _ISR_Enable( level );
> + } else {
> + bool we_did_it;
> + * We can use the_thread_queue pointer here even if
> + * the_thread->Wait.queue is already set to NULL since the extract
> + * operation will only use the thread queue discipline to select the
> + * right extract operation. The timeout status is set during thread
> + * queue initialization.
> + we_did_it = _Thread_queue_Extract( the_thread_queue, the_thread );
> + if ( we_did_it ) {
> } else {
> - _Thread_queue_Extract( the_thread->Wait.queue, the_thread );
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
