[PATCH 3/5] Shared libmm implemenation for ARM BSPs
Hesham Moustafa
heshamelmatary at gmail.com
Mon Aug 26 18:28:25 UTC 2013
On Mon, Aug 26, 2013 at 5:31 PM, Sebastian Huber <
> On 2013-08-26 02:14, Hesham AL-Matary wrote:
>> + * @brief dummy exception handler for data aborts to help in debugging
>> +void dummy_data_abort_exception_**handler(void);
> This is a completely different stuff and should go into a separate patch.
> I don't think we need this handler. In case a data abort we get a fatal
> error. It is up to the fatal error handler to do something with this. It
> may use your new arm_cp15_print_fault_status_**description() (why is it
> defined in a header file?).
> I created this dummy exception handler to help me in debugging the code.
There is
a TODO task to call fatal error function, hopefully in the next fixed
patch, to remove
the dummy handler and use fatal error.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-devel mailing list
> rtems-devel at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-devel<http://www.rtems.org/mailman/listinfo/rtems-devel>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130826/c67553e5/attachment-0001.html>
