[PATCH 3/5] Shared libmm implemenation for ARM BSPs
Sebastian Huber
Tue Aug 27 08:15:57 UTC 2013
On 2013-08-26 20:28, Hesham Moustafa wrote:
> On Mon, Aug 26, 2013 at 5:31 PM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 2013-08-26 02:14, Hesham AL-Matary wrote:
> + * @brief dummy exception handler for data aborts to help in debugging
> +void dummy_data_abort_exception___handler(void);
> This is a completely different stuff and should go into a separate patch.
> I don't think we need this handler. In case a data abort we get a fatal
> error. It is up to the fatal error handler to do something with this. It
> may use your new arm_cp15_print_fault_status___description() (why is it
> defined in a header file?).
> I created this dummy exception handler to help me in debugging the code. There is
> a TODO task to call fatal error function, hopefully in the next fixed patch, to
> remove
> the dummy handler and use fatal error.
For the ARM exception handling see:
http://git.rtems.org/rtems/tree/cpukit/score/cpu/arm/armv4-exception-default.S
They end up in:
void _ARM_Exception_default( CPU_Exception_frame *frame )
rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
In an application specific fatal handler you can do such debug output. The
BSPs must not use printk(), they have to be minimalistic.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
