[PATCH 3/5] Shared libmm implemenation for ARM BSPs
Gedare Bloom
gedare at rtems.org
Tue Aug 27 13:35:07 UTC 2013
On Tue, Aug 27, 2013 at 4:15 AM, Sebastian Huber
> For the ARM exception handling see:
> http://git.rtems.org/rtems/tree/cpukit/score/cpu/arm/armv4-exception-default.S
> They end up in:
> void _ARM_Exception_default( CPU_Exception_frame *frame )
> rtems_fatal( RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
> In an application specific fatal handler you can do such debug output. The
> BSPs must not use printk(), they have to be minimalistic.
Hesham, you may like to write an application-specific fatal handler
for your mmtests, especially any that are designed to trigger the
exception handling mechanism.
