[GSOC] lpc24xx observations
Vipul Nayyar nayyar_vipul at yahoo.com
Wed Aug 28 18:05:24 UTC 2013
Hello,
Thanks Gedare for your observations. I've updated & filtered the list. I've tried to make it as generic as possible. Please have a look. Although I really appreciate your support, but I think maybe more than one member should review this thing. I hope if DrJoel or Cynthia is not too busy, they can join the conversation anytime, since the whole project started with them only.
As always, the observations are updated on the public doc https://docs.google.com/document/d/1W9DMnpocXUKXiQMxHbbp0aG-ecuh94P-3N7hxEJmcgs/edit and submitted below :
Start Files
File : start.S
Location : bsp/start/start.S | libbsp/arch/shared/start/start.S
_start //  Label associated with the starting address of the program
File : bspstart.c
Location : libbsp/shared/bspstart.c | libbsp/arch/shared/bspstart.c | bsp/startup/bspstart.c
bsp_start() // Performs BSP specific initializations
File : bspreset.c
Location : libbsp/shared/bspreset.c | libbsp/arch/shared/bspreset.c | bsp/startup/bspreset.c
bsp_reset()
Standard files used for setting up environment
File :bootcard.c
Header : libbsp//shared/include/bootcard.h
boot_card() //  First C code invoked
File : bspclean.c
Location : libbsp/shared/bspclean.c | bsp/startup/bspclean.c
bsp_fatal_extension() // Shutdown
File : bspgetworkarea.c
Location : libbsp/shared/bspgetworkarea.c | libbsp/arch/shared/bspgetworkarea.c | bsp/startup/bspgetworkarea.c
bsp_work_area_initialize() //  Initialize the RTEMS Workspace and the C Program Heap
File : bsplibc.c
bsp_libc_init() // Initialize the C Library
File : bsppost.c
bsp_postdriver_hook() // BSP specific code for the initialization sequence
File : bsppredriverhook.c
Location : libbsp/shared/bsppredriverhook.c | libbsp/arch/shared/bsppredriverhook.c | bsp/startup/bsppredriverhook.c
bsp_predriver_hook()
File : gnatinstallhandler.c
// No need to include this during compilation, seems empty !!
File : sbrk.c
Location : libbsp/shared/sbrk.c | libbsp/arch/shared/sbrk.c | bsp/startup/sbrk.c
sbrk()
File :stackalloc.c
Header : libbsp/shared/include/stackalloc.h
bsp_stack_allocate_init() // Initialize Heap
bsp_stack_allocate() // Allocate Heap
bsp_stack_free() // Free Heap
Interrupt Files
File :irq.c
Header : bsp/include/irq.h
bsp_interrupt_vector_enable() // Enable interrupt
bsp_interrupt_vector_disable() // Disable interrupt
bsp_interrupt_facility_initialize() // Initialize Interrupt Controller, do other BSP specific initialization.
bsp_interrupt_dispatch() // Reads vector number & calls bsp_interrupt_handler_dispatch() to service the interrupt with the appropriate handler.
File : irq-default-handler.c
// Contains default interrupt handler
File :irq-generic.c
Header : libbsp/shared/shared/include/irq-generic.h
// Generic BSP interrupt support implementation
File :irq-info.c
Header : libbsp/shared/include/irq-info.h
// Generic BSP interrupt information implementation
File : irq-legacy.c
// Generic BSP interrupt support legacy implementation
File : irq-server.c
// Generic BSP interrupt server implementation
File :irq-shell.c
// Generic BSP interrupt shell implementation
Real Time Clock
File : rtc-config.c
bspxx_rtc_initialize() // Initialize RTC chip
bspxx_rtc_get_time() //Get time
bspxx_rtc_set_time() //Set time
bspxx_rtc_probe() // Returns true if device configured by this entry in the RTC_Table is present.
Benchmark Timers
File :benchmark_timer.c
benchmark_timer_initialize() // Initialize benchmark timer
benchmark_timer_read() // Returns benchmark time units
benchmark_timer_disable_subtracting_average_overhead()
Other installed headers
File : include/bsp.h // Global Definitions
File :include/bspopts.h
File :include/irq.h // Interrupt Definitions
File : libbsp/shared/include/coverhd.h // Defines to represent the overhead associated with calling a particular directive from C
File :libbsp/shared/include/utility.h // Utility macros
File : libbsp/shared/include/tm27.h // Timing test
Regards
Vipul Nayyar
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130829/10e76fe9/attachment-0001.html>
