Bash Script to find discrepancies in BSP file organization
Gedare Bloom
gedare at rtems.org
Sat Aug 31 15:11:44 UTC 2013
Also, tm27.h can be (usually is) overwritten by the BSP and located in
./include/tm27.h.
On Sat, Aug 31, 2013 at 11:08 AM, Gedare Bloom <gedare at rtems.org> wrote:
> Vipul, would it make sense to also look for the specified files under
> the BSP in all its subdirectories and report that information in case
> the file is not found where it is expected?
> double check all of the BSP hook files. I noticed bsppredriverhook.c
> has the wrong location for ../shared/startup/bsppredriverhook.c (it
> omits "startup")
> -Gedare
> On Fri, Aug 30, 2013 at 6:49 PM, Vipul Nayyar <nayyar_vipul at yahoo.com> wrote:
>> Hello DrJoel,
>> Haven't heard from you for a long time. I hope you're well. I also sincerely
>> hope that you're following the discussion about the project. I've attached a
>> bash script, somewhat similar to what we both wrote during the start. Please
>> have a look & verify whether it's output is upto your satisfaction. It
>> checks more rules for a BSP that I observed & wrote by looking at lpc24xx.
>> Just drop the script in libbsp, or some where down in an architecture or a
>> bsp folder. Or else you can give it the path of a bsp from the terminal.
>> I've tested it & I think it's giving the required results.
>> Please observe it & I'm all ears for any improvements that you suggest.
>> Hoping to hear from you soon.
>> Regards
>> Vipul Nayyar
