Bash Script to find discrepancies in BSP file organization
Gedare Bloom
gedare at rtems.org
Sat Aug 31 15:08:51 UTC 2013
Vipul, would it make sense to also look for the specified files under
the BSP in all its subdirectories and report that information in case
the file is not found where it is expected?
double check all of the BSP hook files. I noticed bsppredriverhook.c
has the wrong location for ../shared/startup/bsppredriverhook.c (it
omits "startup")
-Gedare
On Fri, Aug 30, 2013 at 6:49 PM, Vipul Nayyar <nayyar_vipul at yahoo.com> wrote:
> Hello DrJoel,
> Haven't heard from you for a long time. I hope you're well. I also sincerely
> hope that you're following the discussion about the project. I've attached a
> bash script, somewhat similar to what we both wrote during the start. Please
> have a look & verify whether it's output is upto your satisfaction. It
> checks more rules for a BSP that I observed & wrote by looking at lpc24xx.
> Just drop the script in libbsp, or some where down in an architecture or a
> bsp folder. Or else you can give it the path of a bsp from the terminal.
> I've tested it & I think it's giving the required results.
> Please observe it & I'm all ears for any improvements that you suggest.
> Hoping to hear from you soon.
> Regards
> Vipul Nayyar
