STM32F4 failure on semaphore release in termios.
Karel Gardas
karel.gardas at centrum.cz
Sat Aug 31 21:07:32 UTC 2013
On 08/30/13 08:58 AM, Sebastian Huber wrote:
> On 2013-08-28 23:30, Karel Gardas wrote:
>> _Internal_error_Occurred (the_source=RTEMS_FATAL_SOURCE_EXCEPTION,
>> is_internal=false, the_error=536875260)
> If you get an exception like this, then you can use in GDB to figure out
> the context (the actual program counter of the exception is not the
> direct value of register_pc):
> Breakpoint 6, _Internal_error_Occurred
> (the_source=RTEMS_FATAL_SOURCE_EXCEPTION, is_internal=false,
> the_error=1049524) at
> ../../../../../../rtems/c/src/../../cpukit/score/src/interr.c:35
> 35 _User_extensions_Fatal( the_source, is_internal, the_error );
> (gdb) p/x *(CPU_Exception_frame *)the_error
> $1 = {
Thanks for this nice trick!
$2 = {register_r0 = 0x20006acc, register_r1 = 0x1a010004, register_r2 =
0x0, register_r3 = 0x1a010003, register_r4 = 0x20006ab8, register_r5 =
0x20001794, register_r6 = 0x20006d80, register_r7 = 0x20003c70,
register_r8 = 0x20003e7c, register_r9 = 0x20001440, register_r10 = 0x0,
register_r11 = 0x18fc0, register_r12 = 0x0, register_sp = 0x0,
register_lr = 0xe57b, register_pc = 0xe584, register_xpsr = 0x21000000,
vector = 0x3, vfp_context = 0x1}
(gdb) dis 0xe584
warning: bad breakpoint number at or near '0xe584'
(gdb) disas 0xe584
Dump of assembler code for function _Chain_Get_first_unprotected:
0x0000e56c <+0>: push {r7, lr}
0x0000e56e <+2>: sub sp, #24
0x0000e570 <+4>: add r7, sp, #0
0x0000e572 <+6>: str r0, [r7, #4]
0x0000e574 <+8>: ldr r0, [r7, #4]
0x0000e576 <+10>: bl 0xe4d8 <_Chain_Head>
0x0000e57a <+14>: str r0, [r7, #20]
0x0000e57c <+16>: ldr r3, [r7, #20]
0x0000e57e <+18>: ldr r3, [r3, #0]
0x0000e580 <+20>: str r3, [r7, #16]
0x0000e582 <+22>: ldr r3, [r7, #16]
0x0000e584 <+24>: ldr r3, [r3, #0]
0x0000e586 <+26>: str r3, [r7, #12]
0x0000e588 <+28>: ldr r3, [r7, #20]
0x0000e58a <+30>: ldr r2, [r7, #12]
0x0000e58c <+32>: str r2, [r3, #0]
0x0000e58e <+34>: ldr r3, [r7, #12]
0x0000e590 <+36>: ldr r2, [r7, #20]
0x0000e592 <+38>: str r2, [r3, #4]
0x0000e594 <+40>: ldr r3, [r7, #16]
0x0000e596 <+42>: mov r0, r3
0x0000e598 <+44>: add.w r7, r7, #24
0x0000e59c <+48>: mov sp, r7
0x0000e59e <+50>: pop {r7, pc}
End of assembler dump.
So it looks like I've debugged well and got up to the culprit. Now the
question is why this ldr fails...
Thanks,
Karel
