[PATCH] powerpc: motorola: Move bspreset.c to startup/
gedare at rtems.org
gedare at rtems.org
Mon Dec 2 17:09:57 UTC 2013
* Move shared/console/bspreset.c to motorola_powerpc/startup/bspreset.c
.../libbsp/powerpc/motorola_powerpc/Makefile.am | 4 +--
.../powerpc/motorola_powerpc/startup/bspreset.c | 27 ++++++++++++++++++++
c/src/lib/libbsp/powerpc/shared/console/bspreset.c | 27 --------------------
3 files changed, 29 insertions(+), 29 deletions(-)
create mode 100644 c/src/lib/libbsp/powerpc/motorola_powerpc/startup/bspreset.c
delete mode 100644 c/src/lib/libbsp/powerpc/shared/console/bspreset.c
diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am b/c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am
index 9a3206d..1c829f7 100644
--- a/c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am
+++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am
@@ -52,7 +52,8 @@ libbsp_a_SOURCES += ../../powerpc/shared/startup/bspstart.c \
../../powerpc/shared/startup/ppc_idle.c \
../../powerpc/shared/startup/sbrk.c ../../shared/bootcard.c \
../../shared/bspclean.c ../../shared/bsplibc.c ../../shared/bsppost.c \
- ../../shared/gnatinstallhandler.c
+ ../../shared/gnatinstallhandler.c \
+ startup/bspreset.c
# tod
@@ -75,7 +76,6 @@ libbsp_a_SOURCES += \
../../powerpc/shared/console/uart.c \
../../powerpc/shared/console/console.c \
../../powerpc/shared/console/inch.c \
- ../../powerpc/shared/console/bspreset.c \
../../powerpc/shared/console/consoleIo.h \
../../powerpc/shared/console/keyboard.h \
../../powerpc/shared/console/uart.h
diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/startup/bspreset.c b/c/src/lib/libbsp/powerpc/motorola_powerpc/startup/bspreset.c
new file mode 100644
index 0000000..ab21611
--- /dev/null
+++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/startup/bspreset.c
@@ -0,0 +1,27 @@
+#include "../../shared/console/console.inl"
+#include <rtems/bspIo.h>
+#include <libcpu/stackTrace.h>
+| Function: bsp_reset
+| Description: Reboot the PC.
+| Global Variables: None.
+| Arguments: None.
+| Returns: Nothing.
+void bsp_reset(void)
+ printk("Printing a stack trace for your convenience :-)\n");
+ CPU_print_stack();
+ /* shutdown and reboot */
+#if defined(mvme2100)
+ *(unsigned char*)0xffe00000 |= 0x80;
+#else
+ /* Memory-mapped Port 92 PIB device access
+ *(unsigned char*)0x80000092 |= 0x01;
+ outb(1, 0x92);
+#endif
+} /* bsp_reset */
diff --git a/c/src/lib/libbsp/powerpc/shared/console/bspreset.c b/c/src/lib/libbsp/powerpc/shared/console/bspreset.c
deleted file mode 100644
index 2b47458..0000000
--- a/c/src/lib/libbsp/powerpc/shared/console/bspreset.c
+++ /dev/null
@@ -1,27 +0,0 @@
-#include "console.inl"
-#include <rtems/bspIo.h>
-#include <libcpu/stackTrace.h>
-| Function: bsp_reset
-| Description: Reboot the PC.
-| Global Variables: None.
-| Arguments: None.
-| Returns: Nothing.
-void bsp_reset(void)
- printk("Printing a stack trace for your convenience :-)\n");
- CPU_print_stack();
- /* shutdown and reboot */
-#if defined(mvme2100)
- *(unsigned char*)0xffe00000 |= 0x80;
-#else
- /* Memory-mapped Port 92 PIB device access
- *(unsigned char*)0x80000092 |= 0x01;
- outb(1, 0x92);
-#endif
-} /* bsp_reset */
1.7.9.5
