[PATCH] libbsp: refactored sparc/shared/bspgetworkarea.c to sparc/shared/startup/bspgetworkarea.c
Nick Withers nick at nickwithers.com
Tue Dec 3 07:30:39 UTC 2013
* refactored sparc/shared/bspgetworkarea.c to sparc/shared/startup/bspgetworkarea.c
 c/src/lib/libbsp/sparc/erc32/Makefile.am           |  2 +-
 c/src/lib/libbsp/sparc/leon2/Makefile.am           |  2 +-
 c/src/lib/libbsp/sparc/leon3/Makefile.am           |  2 +-
 c/src/lib/libbsp/sparc/shared/bspgetworkarea.c     | 67 ----------------------
 .../libbsp/sparc/shared/startup/bspgetworkarea.c   | 67 ++++++++++++++++++++++
 5 files changed, 70 insertions(+), 70 deletions(-)
 delete mode 100644 c/src/lib/libbsp/sparc/shared/bspgetworkarea.c
 create mode 100644 c/src/lib/libbsp/sparc/shared/startup/bspgetworkarea.c
diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am b/c/src/lib/libbsp/sparc/erc32/Makefile.am
index 988f3ec..18a1504 100644
--- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
+++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
@@ -29,7 +29,7 @@ libbsp_a_SOURCES =
 # startup
 libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
-    startup/bsppredriver.c ../../sparc/shared/bspgetworkarea.c \
+    startup/bsppredriver.c ../../sparc/shared/startup/bspgetworkarea.c \
     ../../sparc/shared/bsppretaskinghook.c ../../shared/bsppost.c \
     ../../shared/bspstart.c ../../shared/bootcard.c ../../shared/bspinit.c \
     ../../shared/sbrk.c startup/setvec.c startup/spurious.c \
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index ae6dfb0..c05e021 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -48,7 +48,7 @@ libbsp_a_SOURCES =
     ../../shared/bsppost.c startup/bsppredriver.c \
     startup/bspstart.c ../../sparc/shared/bsppretaskinghook.c \
-    ../../sparc/shared/bspgetworkarea.c ../../shared/bootcard.c \
+    ../../sparc/shared/startup/bspgetworkarea.c ../../shared/bootcard.c \
     ../../shared/sbrk.c startup/setvec.c startup/spurious.c startup/bspidle.c \
     ../../shared/bspinit.c startup/bspdelay.c \
     ../../sparc/shared/startup/early_malloc.c
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index 2612438..302b8c4 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -35,7 +35,7 @@ libbsp_a_SOURCES =
     ../../shared/bsppost.c ../../shared/bootcard.c startup/bspstart.c \
     ../../sparc/shared/bsppretaskinghook.c startup/bsppredriver.c \
-    ../../sparc/shared/bspgetworkarea.c ../../shared/sbrk.c startup/setvec.c \
+    ../../sparc/shared/startup/bspgetworkarea.c ../../shared/sbrk.c startup/setvec.c \
     startup/spurious.c startup/bspidle.S startup/bspdelay.c \
     ../../shared/bspinit.c ../../sparc/shared/startup/early_malloc.c
diff --git a/c/src/lib/libbsp/sparc/shared/bspgetworkarea.c b/c/src/lib/libbsp/sparc/shared/bspgetworkarea.c
deleted file mode 100644
index d799800..0000000
--- a/c/src/lib/libbsp/sparc/shared/bspgetworkarea.c
+++ /dev/null
@@ -1,67 +0,0 @@
- *  This set of routines are the BSP specific initialization
- *  support routines.
- *  COPYRIGHT (c) 1989-2008.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.com/license/LICENSE.
-/* #define BSP_GET_WORK_AREA_DEBUG */
-#include <bsp.h>
-#include <bsp/bootcard.h>
-#ifdef BSP_GET_WORK_AREA_DEBUG
-  #include <rtems/bspIo.h>
-#endif
-/* Tells us where to put the workspace in case remote debugger is present.  */
-extern uint32_t rdb_start;
-/* Must be aligned to 8, _end is aligned to 8 */
-unsigned int early_mem = (unsigned int)&end;
- *  This method returns the base address and size of the area which
- *  is to be allocated between the RTEMS Workspace and the C Program
- *  Heap.
-void bsp_work_area_initialize(void)
-  /* must be identical to STACK_SIZE in start.S */
-  #define STACK_SIZE (16 * 1024)
-  /* Early dynamic memory allocator is placed just above _end  */
-  void *work_area_start = (void *)early_mem;
-  uintptr_t work_area_size  =
-    (uintptr_t)rdb_start - (uintptr_t)early_mem - STACK_SIZE;
-  early_mem        = ~0; /* Signal bsp_early_malloc not to be used anymore */
-   *  The following may be helpful in debugging what goes wrong when
-   *  you are allocating the Work Area in a new BSP.
-  #ifdef BSP_GET_WORK_AREA_DEBUG
-      void *sp = __builtin_frame_address(0);
-      void *end = *work_area_start + *work_area_size;
-      printk(
-        "work_area_start = 0x%p\n"
-        "work_area_size = %d 0x%08x\n"
-        "end = 0x%p\n"
-        "current stack pointer = 0x%p%s\n",
-        work_area_start,
-        work_area_size,  /* decimal */
-        work_area_size,  /* hexadecimal */
-        end,
-        sp,
-        ((sp >= *work_area_start && sp <= end) ? " OVERLAPS!" : "")
-     printk( "rdb_start = 0x%08x\n", rdb_start );
- #endif
-  bsp_work_area_initialize_default(work_area_start, work_area_size);
diff --git a/c/src/lib/libbsp/sparc/shared/startup/bspgetworkarea.c b/c/src/lib/libbsp/sparc/shared/startup/bspgetworkarea.c
new file mode 100644
index 0000000..d799800
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/startup/bspgetworkarea.c
@@ -0,0 +1,67 @@
+ *  This set of routines are the BSP specific initialization
+ *  support routines.
+ *  COPYRIGHT (c) 1989-2008.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+/* #define BSP_GET_WORK_AREA_DEBUG */
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#ifdef BSP_GET_WORK_AREA_DEBUG
+  #include <rtems/bspIo.h>
+#endif
+/* Tells us where to put the workspace in case remote debugger is present.  */
+extern uint32_t rdb_start;
+/* Must be aligned to 8, _end is aligned to 8 */
+unsigned int early_mem = (unsigned int)&end;
+ *  This method returns the base address and size of the area which
+ *  is to be allocated between the RTEMS Workspace and the C Program
+ *  Heap.
+void bsp_work_area_initialize(void)
+  /* must be identical to STACK_SIZE in start.S */
+  #define STACK_SIZE (16 * 1024)
+  /* Early dynamic memory allocator is placed just above _end  */
+  void *work_area_start = (void *)early_mem;
+  uintptr_t work_area_size  =
+    (uintptr_t)rdb_start - (uintptr_t)early_mem - STACK_SIZE;
+  early_mem        = ~0; /* Signal bsp_early_malloc not to be used anymore */
+   *  The following may be helpful in debugging what goes wrong when
+   *  you are allocating the Work Area in a new BSP.
+  #ifdef BSP_GET_WORK_AREA_DEBUG
+      void *sp = __builtin_frame_address(0);
+      void *end = *work_area_start + *work_area_size;
+      printk(
+        "work_area_start = 0x%p\n"
+        "work_area_size = %d 0x%08x\n"
+        "end = 0x%p\n"
+        "current stack pointer = 0x%p%s\n",
+        work_area_start,
+        work_area_size,  /* decimal */
+        work_area_size,  /* hexadecimal */
+        end,
+        sp,
+        ((sp >= *work_area_start && sp <= end) ? " OVERLAPS!" : "")
+     printk( "rdb_start = 0x%08x\n", rdb_start );
+ #endif
+  bsp_work_area_initialize_default(work_area_start, work_area_size);
1.8.3.1
