[PATCH 3/3] i386/virtualpok BSP, virtual BSP to be used with POK, build with enable-paravirt
Gedare Bloom
gedare at rtems.org
Tue Dec 3 20:28:32 UTC 2013
Also if you find the time, we're starting an effort to add Doxygen
comments to our BSPs. You can see some notes on the process at
http://www.rtems.org/wiki/index.php/GoogleCodeInProjects#Structuring_Doxygen_in_libbsp
and if you can add Doxygen comments to your BSP that might be helpful.
Right now the best example we have is the lpc32xx in libbsp/arm. The
patch that added doxygen to it is at
http://git.rtems.org/rtems/commit/?id=2d6543d4c84cc896b7ff357772ea02472d49d882
On Tue, Dec 3, 2013 at 11:49 AM, Gedare Bloom <gedare at rtems.org> wrote:
> On Sat, Nov 30, 2013 at 4:13 AM, Philipp Eppelt
> <philipp.eppelt at mailbox.tu-dresden.de> wrote:
>> c/src/lib/libbsp/i386/acinclude.m4 | 2 +
>> c/src/lib/libbsp/i386/virtualpok/Makefile.am | 87 ++++++++
>> c/src/lib/libbsp/i386/virtualpok/README.virt | 15 ++
>> c/src/lib/libbsp/i386/virtualpok/bsp_specs | 14 ++
>> c/src/lib/libbsp/i386/virtualpok/clock/ckinit.c | 139 ++++++++++++
>> c/src/lib/libbsp/i386/virtualpok/configure.ac | 23 ++
>> c/src/lib/libbsp/i386/virtualpok/console/console.c | 184 ++++++++++++++++
>> c/src/lib/libbsp/i386/virtualpok/include/bsp.h | 53 +++++
>> .../virtualpok/include/virtualizationlayerbsp.h | 58 +++++
>> c/src/lib/libbsp/i386/virtualpok/irq/irq.c | 85 +++++++
>> c/src/lib/libbsp/i386/virtualpok/irq/irq.h | 79 +++++++
>> c/src/lib/libbsp/i386/virtualpok/libpart.a | Bin 0 -> 130636 bytes
>> .../i386/virtualpok/make/custom/virtualpok.cfg | 17 ++
>> c/src/lib/libbsp/i386/virtualpok/preinstall.am | 79 +++++++
>> c/src/lib/libbsp/i386/virtualpok/start/_start.S | 37 ++++
>> .../libbsp/i386/virtualpok/start/bspgetworkarea.c | 102 +++++++++
>> .../lib/libbsp/i386/virtualpok/startup/bspstart.c | 41 ++++
>> c/src/lib/libbsp/i386/virtualpok/startup/linkcmds | 244 +++++++++++++++++++++
>> 18 files changed, 1259 insertions(+)
>> create mode 100644 c/src/lib/libbsp/i386/virtualpok/Makefile.am
>> create mode 100644 c/src/lib/libbsp/i386/virtualpok/README.virt
>> create mode 100644 c/src/lib/libbsp/i386/virtualpok/bsp_specs
>> create mode 100644 c/src/lib/libbsp/i386/virtualpok/clock/ckinit.c
>> create mode 100644 c/src/lib/libbsp/i386/virtualpok/configure.ac
>> create mode 100644 c/src/lib/libbsp/i386/virtualpok/console/console.c
>> create mode 100644 c/src/lib/libbsp/i386/virtualpok/include/bsp.h
>> create mode 100644 c/src/lib/libbsp/i386/virtualpok/include/virtualizationlayerbsp.h
>> create mode 100644 c/src/lib/libbsp/i386/virtualpok/irq/irq.c
>> create mode 100644 c/src/lib/libbsp/i386/virtualpok/irq/irq.h
>> create mode 100644 c/src/lib/libbsp/i386/virtualpok/libpart.a
>> create mode 100644 c/src/lib/libbsp/i386/virtualpok/make/custom/virtualpok.cfg
>> create mode 100644 c/src/lib/libbsp/i386/virtualpok/preinstall.am
>> create mode 100644 c/src/lib/libbsp/i386/virtualpok/start/_start.S
>> create mode 100644 c/src/lib/libbsp/i386/virtualpok/start/bspgetworkarea.c
>> create mode 100644 c/src/lib/libbsp/i386/virtualpok/startup/bspstart.c
>> create mode 100644 c/src/lib/libbsp/i386/virtualpok/startup/linkcmds
> <patch snipped>
> Four comments.
> 1) I think libpart.a should not be included?
> 2) can the linkcmds be shared between virtualpok and pc386?
> 3) remane _start.S to be start.S
> 4) move bspgetworkarea.c to startup/ instead of start/.
> -Gedare
