[PATCH 3/3] i386/virtualpok BSP, virtual BSP to be used with POK, build with enable-paravirt
Philipp Eppelt philipp.eppelt at mailbox.tu-dresden.de
Thu Dec 5 13:39:07 UTC 2013
On 12/03/2013 05:49 PM, Gedare Bloom wrote:
> On Sat, Nov 30, 2013 at 4:13 AM, Philipp Eppelt
> <philipp.eppelt at mailbox.tu-dresden.de> wrote:
>>  c/src/lib/libbsp/i386/acinclude.m4                 |   2 +
>>  c/src/lib/libbsp/i386/virtualpok/Makefile.am       |  87 ++++++++
>>  c/src/lib/libbsp/i386/virtualpok/README.virt       |  15 ++
>>  c/src/lib/libbsp/i386/virtualpok/bsp_specs         |  14 ++
>>  c/src/lib/libbsp/i386/virtualpok/clock/ckinit.c    | 139 ++++++++++++
>>  c/src/lib/libbsp/i386/virtualpok/configure.ac      |  23 ++
>>  c/src/lib/libbsp/i386/virtualpok/console/console.c | 184 ++++++++++++++++
>>  c/src/lib/libbsp/i386/virtualpok/include/bsp.h     |  53 +++++
>>  .../virtualpok/include/virtualizationlayerbsp.h    |  58 +++++
>>  c/src/lib/libbsp/i386/virtualpok/irq/irq.c         |  85 +++++++
>>  c/src/lib/libbsp/i386/virtualpok/irq/irq.h         |  79 +++++++
>>  c/src/lib/libbsp/i386/virtualpok/libpart.a         | Bin 0 -> 130636 bytes
>>  .../i386/virtualpok/make/custom/virtualpok.cfg     |  17 ++
>>  c/src/lib/libbsp/i386/virtualpok/preinstall.am     |  79 +++++++
>>  c/src/lib/libbsp/i386/virtualpok/start/_start.S    |  37 ++++
>>  .../libbsp/i386/virtualpok/start/bspgetworkarea.c  | 102 +++++++++
>>  .../lib/libbsp/i386/virtualpok/startup/bspstart.c  |  41 ++++
>>  c/src/lib/libbsp/i386/virtualpok/startup/linkcmds  | 244 +++++++++++++++++++++
>>  18 files changed, 1259 insertions(+)
>>  create mode 100644 c/src/lib/libbsp/i386/virtualpok/Makefile.am
>>  create mode 100644 c/src/lib/libbsp/i386/virtualpok/README.virt
>>  create mode 100644 c/src/lib/libbsp/i386/virtualpok/bsp_specs
>>  create mode 100644 c/src/lib/libbsp/i386/virtualpok/clock/ckinit.c
>>  create mode 100644 c/src/lib/libbsp/i386/virtualpok/configure.ac
>>  create mode 100644 c/src/lib/libbsp/i386/virtualpok/console/console.c
>>  create mode 100644 c/src/lib/libbsp/i386/virtualpok/include/bsp.h
>>  create mode 100644 c/src/lib/libbsp/i386/virtualpok/include/virtualizationlayerbsp.h
>>  create mode 100644 c/src/lib/libbsp/i386/virtualpok/irq/irq.c
>>  create mode 100644 c/src/lib/libbsp/i386/virtualpok/irq/irq.h
>>  create mode 100644 c/src/lib/libbsp/i386/virtualpok/libpart.a
>>  create mode 100644 c/src/lib/libbsp/i386/virtualpok/make/custom/virtualpok.cfg
>>  create mode 100644 c/src/lib/libbsp/i386/virtualpok/preinstall.am
>>  create mode 100644 c/src/lib/libbsp/i386/virtualpok/start/_start.S
>>  create mode 100644 c/src/lib/libbsp/i386/virtualpok/start/bspgetworkarea.c
>>  create mode 100644 c/src/lib/libbsp/i386/virtualpok/startup/bspstart.c
>>  create mode 100644 c/src/lib/libbsp/i386/virtualpok/startup/linkcmds
> <patch snipped>
> Four comments.
> 1) I think libpart.a should not be included?
You won't be able to compile the bsp unless there is a libpart.a
present. The build process will fail with undefined reference at
link-time. I thought it might be good to have it as an example, without
implementing, building and copying it in/from POK.
I can drop it and provide a link to my github repo in the README. There
one can download libpart.a.
> 2) can the linkcmds be shared between virtualpok and pc386?
There are some differences. In the pc386 linkcmds ENTRY(start) is
commented out and the RamBase definition is missing. In virtualpok the
sections start at 0x1000 instead of 0x0. I don't know how this will
affect the pc386 dependent BSPs.
I copied the rest, as I didn't make any other changes (I didn't add
RamBase, was that definition dropped?)
> 3) remane _start.S to be start.S
done.
> 4) move bspgetworkarea.c to startup/ instead of start/.
done.
Cheers,
Philipp
