test failures on sis
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Dec 16 20:17:48 UTC 2013
On 12/16/2013 1:58 AM, Sebastian Huber wrote:
> On 2013-12-14 19:32, Joel Sherrill wrote:
>> Hi
>> The failures on sis on the head indicate a few that need
>> some attention.
>> WARNING - heapwalk did not appear to complete execution
>> create a loop in the free list
>> ../../../../../../../rtems/c/src/../../testsuites/libtests/heapwalk/init.c:
>> 55 retval == expectet_retval
> In case RTEMS_DEBUG is enabled, then this is ok.
OK. I did have debug enabled. Maybe a message before that to
indicate an assert is expected and a forced failure in the
test below that point if debug is enabled?
>> WARNING - mrfs_fstime did not appear to complete execution
>> Sleep a few seconds
>> ../../../../../../../rtems/c/src/../../testsuites/fstests/mrfs_fstime/../fstime/test.c:
>> 128 st.st_ctime == st.st_mtime
> This is a TODO for the RFS.
>> WARNING - sp2038 did not appear to complete execution
>> I think this is expected.
> Yes, this needs a 64-bit time_t.
>> WARNING - spintrcritical20 did not appear to complete execution
>> *** TEST INTERRUPT CRITICAL SECTION 20 ***
>> This looks like recent changes may have broken things or
>> the assertion is not really guaranteed all the time.
> I think this is a problem with the test. I see sporadic failures here.
I will put it on my every growing list to look at.
>> Support - rtems_timer_create - creating timer 1
>> ../../../../../../../rtems/c/src/../../testsuites/sptests/spintrcritical20/init.c:
>> 139 ctx->thread_queue_was_null
>> WARNING - sppagesize did not appear to complete execution
>> Known failure until tools adjusted.
