test failures on sis
Sebastian Huber
Tue Dec 17 07:36:45 UTC 2013
On 2013-12-16 21:17, Joel Sherrill wrote:
> On 12/16/2013 1:58 AM, Sebastian Huber wrote:
>> >On 2013-12-14 19:32, Joel Sherrill wrote:
>>> >>Hi
>>> >>The failures on sis on the head indicate a few that need
>>> >>some attention.
>>> >>WARNING - heapwalk did not appear to complete execution
>>> >> create a loop in the free list
>>> >>../../../../../../../rtems/c/src/../../testsuites/libtests/heapwalk/init.c:
>>> >>55 retval == expectet_retval
>> >In case RTEMS_DEBUG is enabled, then this is ok.
> OK. I did have debug enabled. Maybe a message before that to
> indicate an assert is expected and a forced failure in the
> test below that point if debug is enabled?
I think its better to fix the test and keep this failure as a remainder.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
