Fixed size cpusetf patch
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Dec 17 14:08:51 UTC 2013
On 12/17/2013 7:27 AM, Sebastian Huber wrote:
> On 2013-12-17 14:20, Jennifer Averett wrote:
>> I started out with it as one, but because of the way the tests run
>> a lot of data comes out (one line for each comparison). I split them
>> up so each test doesn't output so many screens of data. If I put them
>> back as one, would it be better only print at the top of the test (ex.
>> AND test) then print details upon a failure within that (this doesn't
>> match the way other tests work though)
> The only interesting output is the "END OF TEST" message, since this checked by
> the RTEMS testing script. I case of failure you get an assert message, this
> should be enough.
Depends on what you mean by interesting. The intent
was to note what the test was doing before the asserts.
Combining the tests also has a tendency to give us huge tests
which don't run on all targets. I don't know in this case
how large the resulting combined test would be.
Since puts/printf are already wrapped by macros to control
whether the output is buffered or not, it would be easy to
make all the tests silent except for begin/end messages. I
was already beginning to consider a macro for "begin" and
"end" test rather than depend on people attempting to manually
make them consistent.
