Deterministic Archives
Fri Feb 1 01:24:26 UTC 2013
Sebastian Huber wrote:
> If binutils was configured with --enable-deterministic-archives, then
> this mode is on by default. It can be disabled with the `U' modifier,
> below.
My playing seems to indicate you need 2.23.1 for this to work.
> We should consider to add this configure option to the standard tool
> chain build. This helps to avoid artificial differences in library files.
This is a great idea and I fully support doing this. It will help with
verification and validation.
