Deterministic Archives
Chris Johns
chrisj at rtems.org
Fri Feb 1 01:33:35 UTC 2013
Ralf Corsepius wrote:
> If you're serously interested in this, bring this to the attention of
> upstream binutils, newlib, GCC and automake and have all these tools
> changed.
All you need to use is binutils 2.23.1 and then add
'--enable-deterministic-archives' to the configure command of binutils.
This is one line in your crossrpms scripts.
I have added this to the Source Builder and will commit the changes
soon. The results for the SPARC arch are:
$ ./Development/rtems/da-4.11/bin/sparc-rtems4.11-ar -tvv
Development/rtems/da-4.11/sparc-rtems4.11/lib/libc.a | head
rw-r--r-- 0/0 3180 Jan 1 10:00 1970 lib_a-_Exit.o
rw-r--r-- 0/0 9360 Jan 1 10:00 1970 lib_a-__adjust.o
rw-r--r-- 0/0 9820 Jan 1 10:00 1970 lib_a-__atexit.o
rw-r--r-- 0/0 10256 Jan 1 10:00 1970 lib_a-__call_atexit.o
rw-r--r-- 0/0 14608 Jan 1 10:00 1970 lib_a-__dprintf.o
rw-r--r-- 0/0 3368 Jan 1 10:00 1970 lib_a-__exp10.o
rw-r--r-- 0/0 2856 Jan 1 10:00 1970 lib_a-__ten_mu.o
rw-r--r-- 0/0 5000 Jan 1 10:00 1970 lib_a-_isatty.o
rw-r--r-- 0/0 3164 Jan 1 10:00 1970 lib_a-a64l.o
rw-r--r-- 0/0 3252 Jan 1 10:00 1970 lib_a-abort.o
> I for one do not see much sense in this (All it does it to add
> complexity and non-portability) and therefore am opposed to doing this.
The change is fine, harmless and I support it. I have built the tools
with a single line change enabling it and it seems to work as
documented. I do not see the complexity nor portability issues.
