[PATCH] dosfs: Reformated only
Ralf Kirchner ralf.kirchner at embedded-brains.de
Fri Feb 1 09:41:57 UTC 2013
 cpukit/libfs/src/dosfs/msdos_init.c |   90 ++++++++++++++++++-----------------
 1 Datei geändert, 46 Zeilen hinzugefügt(+), 44 Zeilen entfernt(-)
diff --git a/cpukit/libfs/src/dosfs/msdos_init.c b/cpukit/libfs/src/dosfs/msdos_init.c
index eb46141..66e218d 100644
--- a/cpukit/libfs/src/dosfs/msdos_init.c
+++ b/cpukit/libfs/src/dosfs/msdos_init.c
@@ -25,56 +25,58 @@
 #include "dosfs.h"
 #include "msdos.h"
-static int msdos_clone_node_info(rtems_filesystem_location_info_t *loc)
+static int msdos_clone_node_info( rtems_filesystem_location_info_t *loc )
-    fat_file_fd_t *fat_fd = loc->node_access;
+  fat_file_fd_t *fat_fd = loc->node_access;
-    return fat_file_reopen(fat_fd);
+  return fat_file_reopen( fat_fd );
-const rtems_filesystem_operations_table  msdos_ops = {
-  .lock_h         =  msdos_lock,
-  .unlock_h       =  msdos_unlock,
-  .eval_path_h    =  msdos_eval_path,
-  .link_h         =  rtems_filesystem_default_link,
+const rtems_filesystem_operations_table msdos_ops = {
+  .lock_h            = msdos_lock,
+  .unlock_h          = msdos_unlock,
+  .eval_path_h       = msdos_eval_path,
+  .link_h            = rtems_filesystem_default_link,
   .are_nodes_equal_h = rtems_filesystem_default_are_nodes_equal,
-  .node_type_h    =  msdos_node_type,
-  .mknod_h        =  msdos_mknod,
-  .rmnod_h        =  msdos_rmnod,
-  .fchmod_h       =  rtems_filesystem_default_fchmod,
-  .chown_h        =  rtems_filesystem_default_chown,
-  .clonenod_h     =  msdos_clone_node_info,
-  .freenod_h      =  msdos_free_node_info,
-  .mount_h        =  rtems_filesystem_default_mount,
-  .fsmount_me_h   =  rtems_dosfs_initialize,
-  .unmount_h      =  rtems_filesystem_default_unmount,
-  .fsunmount_me_h =  msdos_shut_down,
-  .utime_h        =  rtems_filesystem_default_utime,
-  .symlink_h      =  rtems_filesystem_default_symlink,
-  .readlink_h     =  rtems_filesystem_default_readlink,
-  .rename_h       =  msdos_rename,
-  .statvfs_h      =  rtems_filesystem_default_statvfs
+  .node_type_h       = msdos_node_type,
+  .mknod_h           = msdos_mknod,
+  .rmnod_h           = msdos_rmnod,
+  .fchmod_h          = rtems_filesystem_default_fchmod,
+  .chown_h           = rtems_filesystem_default_chown,
+  .clonenod_h        = msdos_clone_node_info,
+  .freenod_h         = msdos_free_node_info,
+  .mount_h           = rtems_filesystem_default_mount,
+  .fsmount_me_h      = rtems_dosfs_initialize,
+  .unmount_h         = rtems_filesystem_default_unmount,
+  .fsunmount_me_h    = msdos_shut_down,
+  .utime_h           = rtems_filesystem_default_utime,
+  .symlink_h         = rtems_filesystem_default_symlink,
+  .readlink_h        = rtems_filesystem_default_readlink,
+  .rename_h          = msdos_rename,
+  .statvfs_h         = rtems_filesystem_default_statvfs
-void msdos_lock(const rtems_filesystem_mount_table_entry_t *mt_entry)
+void msdos_lock( const rtems_filesystem_mount_table_entry_t *mt_entry )
-  msdos_fs_info_t *fs_info = mt_entry->fs_info;
-  rtems_status_code sc = rtems_semaphore_obtain(
+  msdos_fs_info_t  *fs_info = mt_entry->fs_info;
+  rtems_status_code sc      = rtems_semaphore_obtain(
     fs_info->vol_sema,
     RTEMS_WAIT,
     RTEMS_NO_TIMEOUT
-  if (sc != RTEMS_SUCCESSFUL) {
-    rtems_fatal_error_occurred(0xdeadbeef);
+  if ( sc != RTEMS_SUCCESSFUL ) {
+    rtems_fatal_error_occurred( 0xdeadbeef );
-void msdos_unlock(const rtems_filesystem_mount_table_entry_t *mt_entry)
+void msdos_unlock( const rtems_filesystem_mount_table_entry_t *mt_entry )
-  rtems_status_code sc = rtems_semaphore_release(fs_info->vol_sema);
+  rtems_status_code sc      = rtems_semaphore_release( fs_info->vol_sema );
@@ -89,14 +91,14 @@ void msdos_unlock(const rtems_filesystem_mount_table_entry_t *mt_entry)
  *     RC_OK on success, or -1 if error occured (errno set apropriately).
-int rtems_dosfs_initialize(rtems_filesystem_mount_table_entry_t *mt_entry,
-                           const void                           *data)
+int rtems_dosfs_initialize( rtems_filesystem_mount_table_entry_t *mt_entry,
+  const void                                                     *data )
-    int rc;
+  int rc;
-    rc = msdos_initialize_support(mt_entry,
-                                  &msdos_ops,
-                                  &msdos_file_handlers,
-                                  &msdos_dir_handlers);
-    return rc;
+  rc = msdos_initialize_support( mt_entry,
+                                 &msdos_ops,
+                                 &msdos_file_handlers,
+                                 &msdos_dir_handlers );
+  return rc;
\ No newline at end of file
1.7.10.4
