[PATCH] mm: Add infrastructure for basic memory management
Gedare Bloom
gedare at rtems.org
Mon Feb 18 17:47:19 UTC 2013
c/src/lib/libcpu/shared/include/mm.h | 35 ++++++++++++++
c/src/lib/libcpu/shared/src/no_mm.c | 18 +++++++
cpukit/score/Makefile.am | 2 +
cpukit/score/include/rtems/score/mm.h | 53 ++++++++++++++++++++
cpukit/score/inline/rtems/score/mm.inl | 77 ++++++++++++++++++++++++++++++
cpukit/score/preinstall.am | 8 +++
testsuites/sptests/Makefile.am | 3 +-
testsuites/sptests/configure.ac | 2 +
testsuites/sptests/spmm01/Makefile.am | 18 +++++++
testsuites/sptests/spmm01/init.c | 62 ++++++++++++++++++++++++
testsuites/sptests/spmm01/spmm01.scn | 1 +
testsuites/sptests/spmm01/system.h | 27 ++++++++++
testsuites/sptests/spmm02/Makefile.am | 18 +++++++
testsuites/sptests/spmm02/init.c | 82 ++++++++++++++++++++++++++++++++
testsuites/sptests/spmm02/system.h | 27 ++++++++++
15 files changed, 432 insertions(+), 1 deletions(-)
create mode 100644 c/src/lib/libcpu/shared/include/mm.h
create mode 100644 c/src/lib/libcpu/shared/src/no_mm.c
create mode 100644 cpukit/score/include/rtems/score/mm.h
create mode 100644 cpukit/score/inline/rtems/score/mm.inl
create mode 100644 testsuites/sptests/spmm01/Makefile.am
create mode 100644 testsuites/sptests/spmm01/init.c
create mode 100644 testsuites/sptests/spmm01/spmm01.scn
create mode 100644 testsuites/sptests/spmm01/system.h
create mode 100644 testsuites/sptests/spmm02/Makefile.am
create mode 100644 testsuites/sptests/spmm02/init.c
create mode 100644 testsuites/sptests/spmm02/spmm02.scn
create mode 100644 testsuites/sptests/spmm02/system.h
diff --git a/c/src/lib/libcpu/shared/include/mm.h b/c/src/lib/libcpu/shared/include/mm.h
new file mode 100644
index 0000000..82d1090
--- /dev/null
+++ b/c/src/lib/libcpu/shared/include/mm.h
@@ -0,0 +1,35 @@
+ * Copyright (c) 2013 Gedare Bloom.
+ * http://www.rtems.com/license/LICENSE.
+#ifndef __LIBCPU_MM_H
+#define __LIBCPU_MM_H
+#include <rtems/score/mm.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+void _CPU_Memory_management_Initialize(void);
+void _CPU_Memory_management_Install_entry(
+ Memory_management_Entry *mme
+void _CPU_Memory_management_Set_read_only(
+void _CPU_Memory_management_Set_write(
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libcpu/shared/src/no_mm.c b/c/src/lib/libcpu/shared/src/no_mm.c
index 0000000..7f8444f
--- /dev/null
+++ b/c/src/lib/libcpu/shared/src/no_mm.c
@@ -0,0 +1,18 @@
+#include <rtems.h>
+#include <libcpu/mm.h>
+void _CPU_Memory_management_Initialize( void ) { }
+void _CPU_Memory_management_Install_MPE( Memory_management_Entry *mpe ) { }
+void _CPU_Memory_management_Set_read_only( Memory_management_Entry *mpe ) { }
+void _CPU_Memory_management_Set_write( Memory_management_Entry *mpe ) { }
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 8da32a5..47efcea 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -30,6 +30,7 @@ include_rtems_score_HEADERS += include/rtems/score/protectedheap.h
include_rtems_score_HEADERS += include/rtems/score/interr.h
include_rtems_score_HEADERS += include/rtems/score/isr.h
include_rtems_score_HEADERS += include/rtems/score/isrlevel.h
+include_rtems_score_HEADERS += include/rtems/score/mm.h
include_rtems_score_HEADERS += include/rtems/score/object.h
include_rtems_score_HEADERS += include/rtems/score/percpu.h
include_rtems_score_HEADERS += include/rtems/score/priority.h
@@ -92,6 +93,7 @@ include_rtems_score_HEADERS += inline/rtems/score/coremutex.inl
include_rtems_score_HEADERS += inline/rtems/score/coresem.inl
include_rtems_score_HEADERS += inline/rtems/score/heap.inl
include_rtems_score_HEADERS += inline/rtems/score/isr.inl
+include_rtems_score_HEADERS += inline/rtems/score/mm.inl
include_rtems_score_HEADERS += inline/rtems/score/object.inl
include_rtems_score_HEADERS += inline/rtems/score/priority.inl
include_rtems_score_HEADERS += inline/rtems/score/prioritybitmap.inl
diff --git a/cpukit/score/include/rtems/score/mm.h b/cpukit/score/include/rtems/score/mm.h
index 0000000..f3dcfd1
--- /dev/null
+++ b/cpukit/score/include/rtems/score/mm.h
@@ -0,0 +1,53 @@
+ * @file
+ * @brief Manages use of MPU/MMU units to provide memory management.
+ * Copyright (c) 2012 Hesham Al-Matary.
+#ifndef _RTEMS_SCORE_MM_H
+#define _RTEMS_SCORE_MM_H
+/* @defgroup SuperCoreMM Memory Management Support
+ * @ingroup Score
+#include <inttypes.h>
+#ifdef __cplusplus
+ extern "C" {
+#endif
+ * @brief A managed _Memory_management_Region.
+typedef struct {
+ char *name;
+ uintptr_t base;
+ size_t size;
+ bool installed;
+ /* points to structure defining the BSP specific MM entry */
+ void *bsp_mme;
+} Memory_management_Entry;
+#ifndef __RTEMS_APPLICATION__
+#include <rtems/score/mm.inl>
+#endif
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/score/inline/rtems/score/mm.inl b/cpukit/score/inline/rtems/score/mm.inl
index 0000000..abe065d
--- /dev/null
+++ b/cpukit/score/inline/rtems/score/mm.inl
@@ -0,0 +1,77 @@
+ * @file
+ * @brief Inlined Routines from the Memory Management Manager
+# error "Never use <rtems/score/mm.inl> directly; include <rtems/score/mm.h> instead."
+#endif
+#ifndef _RTEMS_SCORE_MM_INL
+#define _RTEMS_SCORE_MM_INL
+ * @addtogroup SuperCoreMM
+ * @brief Calls _CPU_Memory_management_Initialize.
+RTEMS_INLINE_ROUTINE void _Memory_management_Initialize( void )
+ _CPU_Memory_management_Initialize();
+ * @brief Calls _CPU_Memory_management_Install_entry.
+RTEMS_INLINE_ROUTINE void _Memory_management_Install_entry(
+ _CPU_Memory_management_Install_entry(mme);
+ * @brief Calls _CPU_Memory_management_Uninstall_entry.
+RTEMS_INLINE_ROUTINE void _Memory_management_Uninstall_entry(
+ _CPU_Memory_management_Uninstall_entry(mme);
+ * @brief Calls _CPU_Memory_management_Set_write.
+RTEMS_INLINE_ROUTINE void _Memory_management_Set_write(
+ _CPU_Memory_management_Set_write(mme);
+ * @brief Calls _CPU_Memory_management_Set_read_only
+RTEMS_INLINE_ROUTINE void _Memory_management_Set_read_only(
+ _CPU_Memory_management_Set_read_only(mme);
+#endif
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index a346c79..d3d0ea5 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -103,6 +103,10 @@ $(PROJECT_INCLUDE)/rtems/score/isrlevel.h: include/rtems/score/isrlevel.h $(PROJ
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/isrlevel.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/isrlevel.h
+$(PROJECT_INCLUDE)/rtems/score/mm.h: include/rtems/score/mm.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/mm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/mm.h
$(PROJECT_INCLUDE)/rtems/score/object.h: include/rtems/score/object.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/object.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/object.h
@@ -292,6 +296,10 @@ $(PROJECT_INCLUDE)/rtems/score/isr.inl: inline/rtems/score/isr.inl $(PROJECT_INC
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/isr.inl
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/isr.inl
+$(PROJECT_INCLUDE)/rtems/score/mm.inl: inline/rtems/score/mm.inl $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/mm.inl
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/mm.inl
$(PROJECT_INCLUDE)/rtems/score/object.inl: inline/rtems/score/object.inl $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/object.inl
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/object.inl
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index c9d20dd..81d9089 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -24,7 +24,8 @@ SUBDIRS = \
spintrcritical05 spintrcritical06 spintrcritical07 spintrcritical08 \
spintrcritical09 spintrcritical10 spintrcritical11 spintrcritical12 \
spintrcritical13 spintrcritical14 spintrcritical15 spintrcritical16 \
- spintrcritical17 spintrcritical18 spmkdir spmountmgr01 spheapprot \
+ spintrcritical17 spintrcritical18 \
+ spmkdir spmm01 spmm02 spmountmgr01 spheapprot \
spsimplesched01 spsimplesched02 spsimplesched03 spnsext01 \
spedfsched01 spedfsched02 spedfsched03 \
spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01 \
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 2e48949..6cb1d46 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -183,6 +183,8 @@ spintrcritical16/Makefile
spintrcritical17/Makefile
spheapprot/Makefile
spmkdir/Makefile
+spmm01/Makefile
+spmm02/Makefile
spmountmgr01/Makefile
spnotepad01/Makefile
spnsext01/Makefile
diff --git a/testsuites/sptests/spmm01/Makefile.am b/testsuites/sptests/spmm01/Makefile.am
index 0000000..7f8b851
--- /dev/null
+++ b/testsuites/sptests/spmm01/Makefile.am
@@ -0,0 +1,18 @@
+rtems_tests_PROGRAMS = spmm01
+spmm01_SOURCES = init.c system.h
+dist_rtems_tests_DATA = mmtests.scn
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+LINK_OBJS = $(spmm01_OBJECTS) $(spmm01_LDADD)
+LINK_LIBS = $(spmm01_LDLIBS)
+spmm01$(EXEEXT): $(spmm01_OBJECTS) $(spmm01_DEPENDENCIES)
+ @rm -f spmm01$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/sptests/spmm01/init.c b/testsuites/sptests/spmm01/init.c
index 0000000..4f48ebb
--- /dev/null
+++ b/testsuites/sptests/spmm01/init.c
@@ -0,0 +1,62 @@
+/* Init
+ * This routine is the initialization task for this test program.
+#define __RTEMS_VIOLATE_KERNEL_VISIBILITY__
+#define CONFIGURE_INIT
+#include "system.h"
+#include <stdio.h>
+#include <stdlib.h>
+rtems_task Init(
+ rtems_task_argument ignored
+ Memory_management_Entry mme1 = {
+ .name = "Valid Entry-1",
+ .base = 0x00100000,
+ .size = 0x200000,
+ .installed = false,
+ .bsp_mme = NULL
+ Memory_management_Entry mme2 = {
+ .name = "Valid Entry-2",
+ .base = 0x00400000,
+ .size = 0x100000,
+ .bsp_mme = NULL
+ puts( "\n\n*** Start of spmm01 ***\n" );
+ puts( "initialize the memory management manager\n");
+ _Memory_management_Initialize ( );
+ printf("Test 1: Installing Entry-1\n");
+ _Memory_management_Install_entry( &mme1 );
+ printf("Test 2: Set Read only for installed Entry-1 permissions\n");
+ _Memory_management_Set_read_only( &mme1 );
+ printf("Test 3 : Installing Entry-2\n");
+ _Memory_management_Install_entry( &mme2 );
+ printf("Test 4: Set Write permission for installed Entry-2\n");
+ _Memory_management_Set_write( &mme2 );
+ printf( "\n\n*** End of spmm01 ***\n" );
+ exit( 0 );
diff --git a/testsuites/sptests/spmm01/spmm01.scn b/testsuites/sptests/spmm01/spmm01.scn
index 0000000..8b13789
--- /dev/null
+++ b/testsuites/sptests/spmm01/spmm01.scn
@@ -0,0 +1 @@
diff --git a/testsuites/sptests/spmm01/system.h b/testsuites/sptests/spmm01/system.h
index 0000000..206ef29
--- /dev/null
+++ b/testsuites/sptests/spmm01/system.h
@@ -0,0 +1,27 @@
+/* system.h
+#include <rtems.h>
+/* functions */
+rtems_task Init(
+ rtems_task_argument argument
+/* configuration information */
+#include <bsp.h> /* for device driver prototypes */
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 2
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
+/* end of include file */
diff --git a/testsuites/sptests/spmm02/Makefile.am b/testsuites/sptests/spmm02/Makefile.am
index 0000000..405e336
--- /dev/null
+++ b/testsuites/sptests/spmm02/Makefile.am
@@ -0,0 +1,18 @@
+rtems_tests_PROGRAMS = spmm02
+spmm02_SOURCES = init.c system.h
+LINK_OBJS = $(spmm02_OBJECTS) $(spmm02_LDADD)
+LINK_LIBS = $(spmm02_LDLIBS)
+spmm02$(EXEEXT): $(spmm02_OBJECTS) $(spmm02_DEPENDENCIES)
+ @rm -f spmm02$(EXEEXT)
+ $(make-exe)
diff --git a/testsuites/sptests/spmm02/init.c b/testsuites/sptests/spmm02/init.c
index 0000000..fb52436
--- /dev/null
+++ b/testsuites/sptests/spmm02/init.c
@@ -0,0 +1,82 @@
+/* Init
+#include <stdio.h>
+rtems_task Init(
+ unsigned char* a1;
+ unsigned char* a2;
+ char a;
+ /* FIXME: Make these addresses target-independent */
+ .size = 0x200000,
+ .bsp_mme = NULL
+ .size = 0x100000,
+ .bsp_mme = NULL
+ puts( "\n\n*** Start of spmm02 ***\n" );
+ printf("Test 3: Installing Entry-2\n");
+ /* FIXME: Make fatal tests? */
+ /* FIXME: make addresses target-independent */
+ a1 = (char*)0xffffffffU;
+ printf("Checking MMU exception 1: Read from Unmapped block\n");
+ a = *a1++;
+ a1 = (char*)0xffffffffU + 0x2000U;
+ printf("Checking MMU exception 2: Write to Unmapped block\n");
+ //*a1++ = 0xCC;
+ // this one isn't an exception.
+ a2 = mme1.base;
+ printf("Checking MMU exception 3: Read from readonly block\n");
+ a = *a2++;
+ printf("Checking MMU exception 4: Write to readonly block \n");
+ *a2++ = 0xCC;
+ printf( "\n\n*** End of spmm02 ***\n" );
+ exit( 0 );
diff --git a/testsuites/sptests/spmm02/spmm02.scn b/testsuites/sptests/spmm02/spmm02.scn
index 0000000..e69de29
diff --git a/testsuites/sptests/spmm02/system.h b/testsuites/sptests/spmm02/system.h
index 0000000..15dd018
--- /dev/null
+++ b/testsuites/sptests/spmm02/system.h
@@ -0,0 +1,27 @@
+/* system.h
+ * COPYRIGHT (c) 2013 Gedare Bloom.
+#include <rtems.h>
+/* functions */
+rtems_task Init(
1.7.1
