[PATCH] libblock: Do resource allocation in one place
Thu Feb 21 09:22:00 UTC 2013
Sebastian Huber wrote:
>>> If we allocate
>>> all resources in rtems_bdbuf_init() we have consistent behaviour.
>> What determines "consistent behavior" ? Creating the tasks or letting
>> them run
>> to a blocking point ? This adds an interesting constraint to using the
>> cache.
> We have consistent behaviour if after rtems_bdbuf_init() no fatal errors
> can happen due to configuration errors or resources limits. This makes
> it easier to detect configuration errors for users. If
> rtems_bdbuf_init() fails, then we have a configuration problem and this
> is immediately obvious. If we have some time later during the system
> startup a fatal error in a worker task, then it is more difficult to
> deduce the error reason.
Good point. Ok to commit.
