[rtems commit] tests: atomic support for RTEMS. Uniprocessor tests for atomic ops.
Claus, Ric
claus at slac.stanford.edu
Wed Feb 13 18:02:11 UTC 2013
SMP is not available for ARM? That's a big issue for me. What's involved to provide that support?
Ric
________________________________________
From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] On Behalf Of Joel Sherrill [joel.sherrill at OARcorp.com]
Sent: Wednesday, February 13, 2013 8:42 AM
To: yangwei weiyang
Cc: RTEMS Devel
Subject: Re: [rtems commit] tests: atomic support for RTEMS. Uniprocessor tests for atomic ops.
On 2/13/2013 10:28 AM, yangwei weiyang wrote:
> OK i am studying how to implement a common ISR_Disable and ISR_Enable
> ops to simulate atomic ops. But it is just for the UP architectures,
> for SMP architectures which are not supported by atomic now this will
> not be suitable.
That's OK. The only architectures we currently support SMP on are
x86 and SPARC (only for LEON3). Beyond powerpc and arm, I think
it is unlikely we will have SMP.
In general terms, if the CPU doesn't have atomic instructions
to implement these with, then it is very unlikely to ever show
up in an SMP configuration. This makes the ISR disable/enable
implementation suitable for UP.
My biggest concerns is more general. I envision two common
scenarios within a single architecture:
+ certain cpu models or architecture revisions have atomic
instructions and some don't. But this is defined in the
architecture and can be handled in cpukit. ISR disable/enable
in some cases, real atomic in others.
+ Similar case but CPU models have pulled instructions from
architectural revisions "above" them. The instruction is
there but not part of the real architectural revision the CPU
model is based upon.
The isr disable/enable implementation may need to be available
all the time as a fallback.
--joel
