ARM RTEMS SMP Support
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Mon Feb 18 19:41:24 UTC 2013
On 2/18/2013 2:21 AM, Xi Yang wrote:
> On 14 February 2013 10:39, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>> Xi
>> Can you post the URL for your project? And a general bit
>> on the status and target. That way if someone wants to help,
>> everything will be right here.
> I am doing a research project for my PhD, which is using M3 cores to
> do garbage collection for the JVM. The JVM is running on big A9 cores.
> I don't have a URL for that. I will post the paper and code URL to the
> mailing list after it is accepted.
Very cool!
But I actually meant a link for the ARM SMP work you did so anyone
on the list can review, comment, pitch in.  We all would love to see it
merged so having more eyes on it would help get it ready and merged
sooner.
hint.. I am hoping someone will step up and do this... hint..
> Regards.
>> --joel
>> On 2/13/2013 4:56 PM, Xi Yang wrote:
>>> Hi Joel,
>>> On 14 February 2013 05:37, Joel Sherrill <joel.sherrill at oarcorp.com>
>>> wrote:
>>>> You just threw down the gauntlet to Xi Yang!! Time to
>>>> merge. :)
>>>> On 2/13/2013 12:02 PM, Claus, Ric wrote:
>>>> SMP is not available for ARM?  That's a big issue for me.  What's
>>>> involved
>>>> to provide that support?
>>>> Compared to writing a BSP from scratch, not much. :)
>>>> You can look at either the pc386 or leon3 BSPs and associated
>>>> ports for an idea of how much code is architecture
>>>> and BSP specific.
>>>> Or even better.. help us merge the GSOC project by Xi Yang.
>>> Sorry, Joel. I was too busy to clean the code. I will try my best to
>>> submit the patches as soon as possible.
>>> By the way, I am doing a research project which is using RTEMS as the
>>> kernel for the small M3 ARM cores.
>>> Regards.
>>>> http://www.rtems.com/ml/rtems-users/2012/august/msg00084.html
>>>> has a github link. I suspect there may be some BSP or CPU model
>>>> variation between his work and yours.
>>>> Our atomic code is based off that in FreeBSD. So this would be the
>>>> starting point for the atomic.h support.
>>>> http://svnweb.freebsd.org/base/head/sys/arm/include/atomic.h?view=log&pathrev=151334
>>>> --joel
>>>> Ric
>>>> ________________________________________
>>>> From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] On
>>>> Behalf Of Joel Sherrill [joel.sherrill at OARcorp.com]
>>>> Sent: Wednesday, February 13, 2013 8:42 AM
>>>> To: yangwei weiyang
>>>> Cc: RTEMS Devel
>>>> Subject: Re: [rtems commit] tests: atomic support for RTEMS. Uniprocessor
>>>> tests for atomic ops.
>>>> On 2/13/2013 10:28 AM, yangwei weiyang wrote:
>>>> OK i am studying how to implement a common ISR_Disable and ISR_Enable
>>>> ops to simulate atomic ops. But it is just for the UP architectures,
>>>> for SMP architectures which are not supported by atomic now this will
>>>> not be suitable.
>>>> That's OK. The only architectures we currently support SMP on are
>>>> x86 and SPARC (only for LEON3).  Beyond powerpc and arm, I think
>>>> it is unlikely we will have SMP.
>>>> In general terms, if the CPU doesn't have atomic instructions
>>>> to implement these with, then it is very unlikely to ever show
>>>> up in an SMP configuration.  This makes the ISR disable/enable
>>>> implementation suitable for UP.
>>>> My biggest concerns is more general. I envision two common
>>>> scenarios within a single architecture:
>>>> + certain cpu models or architecture revisions have atomic
>>>>       instructions and some don't. But this is defined in the
>>>>      architecture and can be handled in cpukit. ISR disable/enable
>>>>       in some cases, real atomic in others.
>>>> + Similar case but CPU models have pulled instructions from
>>>>       architectural revisions "above" them. The instruction is
>>>>       there but not part of the real architectural revision the CPU
>>>>       model is based upon.
>>>> The isr disable/enable implementation may need to be available
>>>> all the time as a fallback.
>>>> --joel
>>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>>> Support Available                (256) 722-9985
