ARM RTEMS SMP Support
Xi Yang
hiyangxi at gmail.com
Mon Feb 18 22:24:52 UTC 2013
On 19 February 2013 06:41, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> On 2/18/2013 2:21 AM, Xi Yang wrote:
>> On 14 February 2013 10:39, Joel Sherrill <joel.sherrill at oarcorp.com>
>> wrote:
>>> Xi
>>> Can you post the URL for your project? And a general bit
>>> on the status and target. That way if someone wants to help,
>>> everything will be right here.
>> I am doing a research project for my PhD, which is using M3 cores to
>> do garbage collection for the JVM. The JVM is running on big A9 cores.
>> I don't have a URL for that. I will post the paper and code URL to the
>> mailing list after it is accepted.
> Very cool!
> But I actually meant a link for the ARM SMP work you did so anyone
> on the list can review, comment, pitch in. We all would love to see it
> merged so having more eyes on it would help get it ready and merged
> sooner.
Sorry, I misunderstand your question. Here is the link
https://github.com/yangxi/omap4m3
Regards.
> hint.. I am hoping someone will step up and do this... hint..
>> Regards.
>>> --joel
>>> On 2/13/2013 4:56 PM, Xi Yang wrote:
>>>> Hi Joel,
>>>> On 14 February 2013 05:37, Joel Sherrill <joel.sherrill at oarcorp.com>
>>>> wrote:
>>>>> You just threw down the gauntlet to Xi Yang!! Time to
>>>>> merge. :)
>>>>> On 2/13/2013 12:02 PM, Claus, Ric wrote:
>>>>> SMP is not available for ARM? That's a big issue for me. What's
>>>>> involved
>>>>> to provide that support?
>>>>> Compared to writing a BSP from scratch, not much. :)
>>>>> You can look at either the pc386 or leon3 BSPs and associated
>>>>> ports for an idea of how much code is architecture
>>>>> and BSP specific.
>>>>> Or even better.. help us merge the GSOC project by Xi Yang.
>>>> Sorry, Joel. I was too busy to clean the code. I will try my best to
>>>> submit the patches as soon as possible.
>>>> By the way, I am doing a research project which is using RTEMS as the
>>>> kernel for the small M3 ARM cores.
>>>> Regards.
>>>>> http://www.rtems.com/ml/rtems-users/2012/august/msg00084.html
>>>>> has a github link. I suspect there may be some BSP or CPU model
>>>>> variation between his work and yours.
>>>>> Our atomic code is based off that in FreeBSD. So this would be the
>>>>> starting point for the atomic.h support.
>>>>> http://svnweb.freebsd.org/base/head/sys/arm/include/atomic.h?view=log&pathrev=151334
>>>>> --joel
>>>>> Ric
>>>>> ________________________________________
>>>>> From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] On
>>>>> Behalf Of Joel Sherrill [joel.sherrill at OARcorp.com]
>>>>> Sent: Wednesday, February 13, 2013 8:42 AM
>>>>> To: yangwei weiyang
>>>>> Cc: RTEMS Devel
>>>>> Subject: Re: [rtems commit] tests: atomic support for RTEMS.
>>>>> Uniprocessor
>>>>> tests for atomic ops.
>>>>> On 2/13/2013 10:28 AM, yangwei weiyang wrote:
>>>>> OK i am studying how to implement a common ISR_Disable and ISR_Enable
>>>>> ops to simulate atomic ops. But it is just for the UP architectures,
>>>>> for SMP architectures which are not supported by atomic now this will
>>>>> not be suitable.
>>>>> That's OK. The only architectures we currently support SMP on are
>>>>> x86 and SPARC (only for LEON3). Beyond powerpc and arm, I think
>>>>> it is unlikely we will have SMP.
>>>>> In general terms, if the CPU doesn't have atomic instructions
>>>>> to implement these with, then it is very unlikely to ever show
>>>>> up in an SMP configuration. This makes the ISR disable/enable
>>>>> implementation suitable for UP.
>>>>> My biggest concerns is more general. I envision two common
>>>>> scenarios within a single architecture:
>>>>> + certain cpu models or architecture revisions have atomic
>>>>> instructions and some don't. But this is defined in the
>>>>> architecture and can be handled in cpukit. ISR disable/enable
>>>>> in some cases, real atomic in others.
>>>>> + Similar case but CPU models have pulled instructions from
>>>>> architectural revisions "above" them. The instruction is
>>>>> there but not part of the real architectural revision the CPU
>>>>> model is based upon.
>>>>> The isr disable/enable implementation may need to be available
>>>>> all the time as a fallback.
>>>>> --joel
>>>>> Joel Sherrill, Ph.D. Director of Research & Development
>>>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>>>> Support Available (256) 722-9985
