[1/1] tmoverhd.doc
Sun Jan 6 13:26:44 UTC 2013
applied.
On Sat, Dec 29, 2012 at 11:55 PM, Cynthia Rempel
<cynt6007 at vandals.uidaho.edu> wrote:
> Hi,
> Adding test documentation...
> diff --git a/testsuites/tmtests/tmoverhd/tmoverhd.doc b/testsuites/tmtests/tmov$
> index a2dcbde..cfa564f 100644
> --- a/testsuites/tmtests/tmoverhd/tmoverhd.doc
> +++ b/testsuites/tmtests/tmoverhd/tmoverhd.doc
> @@ -6,4 +6,79 @@
>  #  http://www.rtems.com/license/LICENSE.
> +directives:
> ++ rtems shutdown executive
> ++ rtems task create
> ++ rtems task ident
> ++ rtems task start
> ++ rtems task restart
> ++ rtems task delete
> ++ rtems task suspend
> ++ rtems task resume
> ++ rtems task set priority
> ++ rtems task mode
> ++ rtems task get note
> ++ rtems task set note
> ++ rtems task wake when
> ++ rtems task wake after
> ++ rtems interrupt catch
> ++ rtems clock get
> ++ rtems clock set
> ++ rtems clock tick
> ++ rtems timer create
> ++ rtems timer delete
> ++ rtems timer ident
> ++ rtems timer fire after
> ++ rtems timer fire when
> ++ rtems timer reset
> ++ rtems timer cancel
> ++ rtems semaphore create
> ++ rtems semaphore delete
> ++ rtems semaphore ident
> ++ rtems semaphore obtain
> ++ rtems semaphore release
> ++ rtems message queue create
> ++ rtems message queue ident
> ++ rtems message queue delete
> ++ rtems message queue send
> ++ rtems message queue urgent
> ++ rtems message queue broadcast
> ++ rtems message queue receive
> ++ rtems message queue flush
> ++ rtems event send
> ++ rtems event receive
> ++ rtems signal catch
> ++ rtems signal send
> ++ rtems partition create
> ++ rtems partition ident
> ++ rtems partition delete
> ++ rtems partition get buffer
> ++ rtems partition return buffer
> ++ rtems region create
> ++ rtems region ident
> ++ rtems region delete
> ++ rtems region get segment
> ++ rtems region return segment
> ++ rtems port create
> ++ rtems port ident
> ++ rtems port delete
> ++ rtems port external to internal
> ++ rtems port internal to external
> ++ rtems io initialize
> ++ rtems io open
> ++ rtems io close
> ++ rtems io read
> ++ rtems io write
> ++ rtems io control
> ++ rtems fatal error occurred
> ++ rtems rate monotonic create
> ++ rtems rate monotonic ident
> ++ rtems rate monotonic delete
> ++ rtems rate monotonic cancel
> ++ rtems rate monotonic period
> ++ rtems multiprocessing announce
> +concepts:
> ++ Test the overhead of various classic RTEMS directives.
> rtems-devel mailing list
> rtems-devel at rtems.org
