[PATCH] score: Fix _Objects_Shrink_information()
Ralf Corsepius
ralf.corsepius at rtems.org
Fri Jan 4 10:03:50 UTC 2013
On 01/04/2013 10:48 AM, Sebastian Huber wrote:
> On 01/04/2013 10:30 AM, Ralf Corsepius wrote:
>> On 01/03/2013 05:08 PM, Sebastian Huber wrote:
>>> The chain iteration was wrong. The chain tail is not an object.
>>> cpukit/score/src/objectshrinkinformation.c | 36
>>> 1 files changed, 16 insertions(+), 20 deletions(-)
>>> diff --git a/cpukit/score/src/objectshrinkinformation.c
>>> b/cpukit/score/src/objectshrinkinformation.c
>>> index de32f24..466a85d 100644
>>> --- a/cpukit/score/src/objectshrinkinformation.c
>>> +++ b/cpukit/score/src/objectshrinkinformation.c
>>> @@ -34,12 +34,9 @@ void _Objects_Shrink_information(
>>> Objects_Information *information
>>> - Objects_Control *the_object;
>>> - Objects_Control *extract_me;
>>> uint32_t block_count;
>>> uint32_t block;
>>> uint32_t index_base;
>>> - uint32_t index;
>>> * Search the list to find block or chunk with all objects
>>> inactive.
>>> @@ -52,25 +49,24 @@ void _Objects_Shrink_information(
>>> for ( block = 0; block < block_count; block++ ) {
>>> if ( information->inactive_per_block[ block ] ==
>>> information->allocation_size ) {
>>> + Chain_Node *node = _Chain_First( &information->Inactive );
>>> + const Chain_Node *tail = _Chain_Immutable_tail(
>>> + uint32_t index_end = index_base +
>>> information->allocation_size;
>> FWIW: I believe all these "index*" vars, should be size_t (or may be
>> off_t) and
>> not be uint32_t.
> Ok, but this integer type inconsistency has nothing to do with the
> chain iteration fix.
> The information->allocation_size, information->maximum, and
> information->inactive are of type Objects_Maximum which is uint8_t or
> uint16_t.
IMO, this is a bug. All sizes should be size_t.
> The first problem is that information->inactive_per_block is of type
> uint32_t which should be Objects_Maximum to save space since
> information->inactive is the sum of all information->inactive_per_block.
> For calculation with Objects_Maximum type integers we should use not
> use size_t since on 32-bit architectures uint16_t is promoted to int.
> I think uint_fast16_t is the right type.
I am not sure, but I am having doubts on this.
>> Dunno of-head if this can easily be changed or if this just one of
>> links in the
>> long chains of uint32_t vs. size_t vs. off_t issues RTEMS is known to
>> suffer from.
>> Ralf
