[rtems commit] libfs: Doxygen Clean Up Task #1
Wed Jan 9 16:18:43 UTC 2013
You're right these param changes are incorrect. I can revert most of
these cleanly, but would lose the conversion to retval..
On Wed, Jan 9, 2013 at 11:05 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On 01/09/2013 09:44 AM, Sebastian Huber wrote:
>> On 01/08/2013 02:58 PM, Gedare Bloom wrote:
>>> - * @param[in,out] node The IMFS node.
>>> - * @param[in] info The IMFS type information.
>>> + * @param[in,out] node is the IMFS node.
>>> + * @param[in] info is the IMFS type information.
>> Why was this changed?  I added these comments only recently.  I thought
>> that we
>> agreed to use:
>> @param[in] var The foobar variable.  We use a complete sentence since this
>> is
>> more flexible.  This allows also multiple sentences.
> Not answering the question but being pedantic, foobar should be referred
> to as a parameter not a variable.  The values passed to a function are
> arguments and are referenced with the corresponding parameter name
> in the function.
> At least that seems to be the consensus of the books and C sites
> I am looking at. :)
> Joel Sherrill, Ph.D.             Director of Research&  Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
> Ask me about RTEMS: a free RTOS  Huntsville AL 35806
> Support Available               (256) 722-9985
> rtems-devel mailing list
> rtems-devel at rtems.org
