[rtems commit] score: Doxygen Clean Up Task #14
Thu Jan 10 15:00:17 UTC 2013
I know there were discussions during the holidays but is it
wise to edit files in the avr port which were copied from
avr-libc?
We do not own these files. We just copy them.
On 01/10/2013 08:46 AM, Jennifer Averett wrote:
> Module:    rtems
> Branch:    master
> Commit:    ed70eaea0b33f5437ac88856f460568d7905027d
> Changeset: http://git.rtems.org/rtems/commit/?id=ed70eaea0b33f5437ac88856f460568d7905027d
> Author:    Alex Ivanov<alexivanov97 at gmail.com>
> Date:      Thu Jan 10 08:50:33 2013 -0600
>   cpukit/score/cpu/avr/avr/io4414.h          |   17 +++++++++++++++++
>   cpukit/score/cpu/avr/avr/io76c711.h        |   19 +++++++++++++++++++
>   cpukit/score/cpu/avr/avr/io8534.h          |   18 ++++++++++++++++++
>   cpukit/score/cpu/avr/avr/io90pwm1.h        |   17 +++++++++++++++++
>   cpukit/score/cpu/avr/avr/io90pwm216.h      |   17 +++++++++++++++++
>   cpukit/score/cpu/avr/avr/io90pwm3b.h       |   17 +++++++++++++++++
>   cpukit/score/cpu/avr/avr/iom1280.h         |   15 +++++++++++++++
>   cpukit/score/cpu/avr/avr/iom6450.h         |   17 +++++++++++++++++
>   cpukit/score/cpu/avr/avr/iom64c1.h         |   16 ++++++++++++++++
>   cpukit/score/cpu/avr/avr/iom8.h            |   17 +++++++++++++++++
>   cpukit/score/cpu/avr/avr/iom88.h           |   15 +++++++++++++++
>   cpukit/score/cpu/avr/avr/iotn26.h          |   17 +++++++++++++++++
>   cpukit/score/cpu/avr/avr/iotn261.h         |   15 +++++++++++++++
>   cpukit/score/cpu/avr/avr/iousb82.h         |   15 +++++++++++++++
>   cpukit/score/cpu/avr/avr/iox32d4.h         |   18 +++++++++++++++++-
>   cpukit/score/cpu/avr/rtems/asm.h           |   23 +++++++++++++----------
>   cpukit/score/cpu/avr/rtems/score/avr.h     |   15 +++++++++------
>   cpukit/score/cpu/avr/rtems/score/cpu.h     |   10 ++++++----
>   cpukit/score/cpu/avr/rtems/score/cpu_asm.h |   12 +++++++-----
>   cpukit/score/cpu/avr/rtems/score/types.h   |   10 ++++++----
>   20 files changed, 290 insertions(+), 30 deletions(-)
> diff --git a/cpukit/score/cpu/avr/avr/io4414.h b/cpukit/score/cpu/avr/avr/io4414.h
> index 9c8362c..94460a4 100644
> --- a/cpukit/score/cpu/avr/avr/io4414.h
> +++ b/cpukit/score/cpu/avr/avr/io4414.h
> @@ -1,3 +1,11 @@
> + * @file
> + * @brief Definitions for AT90S4414
> + * This file should only be included from<avr/io.h>, never directly.
>   /* Copyright (c) 2002, Marek Michalkiewicz
>      All rights reserved.
> @@ -46,6 +54,14 @@
>   #  error "Attempt to include more than one<avr/ioXXX.h>  file."
>   #endif
> + * @defgroup AvrDef_io4414 AT90S4414 Definitions
> + * @ingroup avr
>   /* I/O registers */
>   /* Analog Comparator Control and Status Register */
> @@ -480,5 +496,6 @@
>   #define SIGNATURE_1 0x92
>   #define SIGNATURE_2 0x01
>   #endif /* _AVR_IO4414_H_ */
> diff --git a/cpukit/score/cpu/avr/avr/io76c711.h b/cpukit/score/cpu/avr/avr/io76c711.h
> index 60e3b74..f469076 100644
> --- a/cpukit/score/cpu/avr/avr/io76c711.h
> +++ b/cpukit/score/cpu/avr/avr/io76c711.h
> @@ -1,3 +1,11 @@
> + * @file
> + * @brief Definitions for AT76C711
> @@ -46,6 +54,14 @@
>   #endif
> + * @defgroup AvrDef_io76c711 AT76C711 Definitions
> + * @ingroup avr
>   /* I/O registers */
>   /* 0x00-0x0C reserved */
> @@ -489,4 +505,7 @@
>      0x8000 - 0xBFFF - program SRAM (read/write), would be nice if other
>                        AVR devices did that as well (no need to use LPM!)
>   #endif /* _AVR_IO76C711_H_ */
> diff --git a/cpukit/score/cpu/avr/avr/io8534.h b/cpukit/score/cpu/avr/avr/io8534.h
> index f25cfd2..10e20b3 100644
> --- a/cpukit/score/cpu/avr/avr/io8534.h
> +++ b/cpukit/score/cpu/avr/avr/io8534.h
> @@ -1,3 +1,11 @@
> + * @file
> + * @brief Definitions for AT90C8534
> @@ -46,6 +54,14 @@
>   #endif
> + * @defgroup AvrDef_io8534 AT90C8534 Definitions
> + * @ingroup avr
>   /* I/O registers */
>   /* 0x00..0x03 reserved */
> @@ -212,4 +228,6 @@
>   #define E2END          0x1FF
>   #define FLASHEND       0x1FFF
>   #endif /* _AVR_IO8534_H_ */
> diff --git a/cpukit/score/cpu/avr/avr/io90pwm1.h b/cpukit/score/cpu/avr/avr/io90pwm1.h
> index ccf77af..d893fd9 100644
> --- a/cpukit/score/cpu/avr/avr/io90pwm1.h
> +++ b/cpukit/score/cpu/avr/avr/io90pwm1.h
> @@ -1,3 +1,11 @@
> + * @file
> + * @brief Definitions for AT90PWM1
>   /* Copyright (c) 2005, Andrey Pashchenko
>      Copyright (c) 2007, Anatoly Sokolov
> @@ -47,6 +55,14 @@
>   #endif
> + * @defgroup AvrDef_io90pwm1 AT90PWM1 Definitions
> + * @ingroup avr
>   /* I/O registers */
>   /* Reserved [0x00..0x02] */
> @@ -1116,5 +1132,6 @@
>   #define __BOOT_LOCK_BITS_0_EXIST
>   #define __BOOT_LOCK_BITS_1_EXIST
>   #endif /* _AVR_IOPWM1_H_ */
> diff --git a/cpukit/score/cpu/avr/avr/io90pwm216.h b/cpukit/score/cpu/avr/avr/io90pwm216.h
> index 70682e7..7a53cf0 100644
> --- a/cpukit/score/cpu/avr/avr/io90pwm216.h
> +++ b/cpukit/score/cpu/avr/avr/io90pwm216.h
> @@ -1,3 +1,11 @@
> + * @file
> + * @brief Definitions for AT90PWM216
>   /* Copyright (c) 2007, Atmel Corporation
> @@ -46,6 +54,14 @@
>   #endif
> + * @defgroup AvrDef_io90pwm216 AT90PWM216 Definitions
> + * @ingroup avr
>   /* I/O registers */
>   /* Port B Input Pins Address */
> @@ -1176,5 +1192,6 @@
>   #define SIGNATURE_1 0x94
>   #define SIGNATURE_2 0x83
>   #endif /* _AVR_IO90PWM216_H_ */
> diff --git a/cpukit/score/cpu/avr/avr/io90pwm3b.h b/cpukit/score/cpu/avr/avr/io90pwm3b.h
> index 0d648fb..7885ec9 100644
> --- a/cpukit/score/cpu/avr/avr/io90pwm3b.h
> +++ b/cpukit/score/cpu/avr/avr/io90pwm3b.h
> @@ -1,3 +1,11 @@
> + * @file
> + * @brief Definitions for AT90PWM3B
>   /* Copyright (c) 2007 Atmel Corporation
> @@ -48,6 +56,14 @@
>   #ifndef _AVR_IO90PWM3B_H_
>   #define _AVR_IO90PWM3B_H_ 1
> + * @defgroup AvrDef_io90pwm3b AT90PWM3B Definitions
> + * @ingroup avr
>   /* Registers and associated bit numbers */
>   #define PINB _SFR_IO8(0x03)
> @@ -1387,5 +1403,6 @@
>   #define SIGNATURE_1 0x93
>   #endif /* _AVR_IO90PWM3B_H_ */
> diff --git a/cpukit/score/cpu/avr/avr/iom1280.h b/cpukit/score/cpu/avr/avr/iom1280.h
> index 5bed7c9..933e709 100644
> --- a/cpukit/score/cpu/avr/avr/iom1280.h
> +++ b/cpukit/score/cpu/avr/avr/iom1280.h
> @@ -1,3 +1,9 @@
> + * @file
> + * @brief Definitions for ATmega1280
>   /* Copyright (c) 2005 Anatoly Sokolov
> @@ -36,6 +42,14 @@
>   #include<avr/iomxx0_1.h>
> + * @defgroup AvrDef_iom1280 ATmega1280 Definitions
> + * @ingroup avr
>   /* Constants */
>   #define SPM_PAGESIZE    256
>   #define RAMEND          0x21FF
> @@ -89,5 +103,6 @@
>   #define SIGNATURE_1 0x97
>   #define SIGNATURE_2 0x03
>   #endif /* _AVR_IOM1280_H_ */
> diff --git a/cpukit/score/cpu/avr/avr/iom6450.h b/cpukit/score/cpu/avr/avr/iom6450.h
> index 8317f18..0a11429 100644
> --- a/cpukit/score/cpu/avr/avr/iom6450.h
> +++ b/cpukit/score/cpu/avr/avr/iom6450.h
> @@ -1,3 +1,11 @@
> + * @file
> + * @brief Definitions for ATmega6450
>   /* Copyright (c) 2004,2005,2006 Eric B. Weddington
> @@ -46,6 +54,14 @@
>   #endif
> + * @defgroup AvrDef_iom6450 ATmega6450 Definitions
> + * @ingroup avr
>   #define PINA    _SFR_IO8(0x00)
> @@ -902,5 +918,6 @@
>   #define SIGNATURE_1 0x96
>   #define SIGNATURE_2 0x06
>   #endif /* _AVR_IOM6450_H_ */
> diff --git a/cpukit/score/cpu/avr/avr/iom64c1.h b/cpukit/score/cpu/avr/avr/iom64c1.h
> index a30aee0..5d2ef5d 100644
> --- a/cpukit/score/cpu/avr/avr/iom64c1.h
> +++ b/cpukit/score/cpu/avr/avr/iom64c1.h
> @@ -1,3 +1,11 @@
> + * @file
> + * @brief Definitions for ATmega64C1
>   /* Copyright (c) 2009 Atmel Corporation
> @@ -47,6 +55,13 @@
>   #ifndef _AVR_ATmega64C1_H_
>   #define _AVR_ATmega64C1_H_ 1
> + * @defgroup AvrDef_iom64c1 ATmega64C1 Definitions
> + * @ingroup avr
>   /* Registers and associated bit numbers. */
> @@ -1292,6 +1307,7 @@
>   #define SIGNATURE_2 0x86
>   #endif /* _AVR_ATmega64C1_H_ */
> diff --git a/cpukit/score/cpu/avr/avr/iom8.h b/cpukit/score/cpu/avr/avr/iom8.h
> index 02ad8e1..c43ac86 100644
> --- a/cpukit/score/cpu/avr/avr/iom8.h
> +++ b/cpukit/score/cpu/avr/avr/iom8.h
> @@ -1,3 +1,11 @@
> + * @file
> + * @brief Definitions for ATmega8
> @@ -46,6 +54,14 @@
>   #endif
> + * @defgroup AvrDef_iom8 ATmega8 Definitions
> + * @ingroup avr
>   /* I/O registers */
>   /* TWI stands for "Two Wire Interface" or "TWI Was I2C(tm)" */
> @@ -609,5 +625,6 @@
>   #define SIGNATURE_2 0x07
>   #endif /* _AVR_IOM8_H_ */
> diff --git a/cpukit/score/cpu/avr/avr/iom88.h b/cpukit/score/cpu/avr/avr/iom88.h
> index 063b1fa..60ef3d2 100644
> --- a/cpukit/score/cpu/avr/avr/iom88.h
> +++ b/cpukit/score/cpu/avr/avr/iom88.h
> @@ -1,3 +1,9 @@
> + * @file
> + * @brief Definitions for ATmega88
>   /* Copyright (c) 2004, Theodore A. Roth
> @@ -32,6 +38,14 @@
>   #ifndef _AVR_IOM88_H_
>   #define _AVR_IOM88_H_ 1
> + * @defgroup AvrDef_iom88 ATmega88 Definitions
> + * @ingroup avr
>   #include<avr/iomx8.h>
>   /* Constants */
> @@ -86,5 +100,6 @@
>   #define SIGNATURE_2 0x0A
>   #endif /* _AVR_IOM88_H_ */
> diff --git a/cpukit/score/cpu/avr/avr/iotn26.h b/cpukit/score/cpu/avr/avr/iotn26.h
> index 068d7f9..8722055 100644
> --- a/cpukit/score/cpu/avr/avr/iotn26.h
> +++ b/cpukit/score/cpu/avr/avr/iotn26.h
> @@ -1,3 +1,11 @@
> + * @file
> + * @brief Definitions for ATtiny26
>   /* Copyright (c) 2004,2005 Eric B. Weddington
> @@ -46,6 +54,14 @@
>   #ifndef _AVR_IOTN26_H_
>   #define _AVR_IOTN26_H_ 1
> + * @defgroup AvrDef_iotn26 ATtiny26 Definitions
> + * @ingroup avr
>   /* Reserved [0x00..0x03] */
> @@ -380,5 +396,6 @@
>   #define SIGNATURE_1 0x91
>   #define SIGNATURE_2 0x09
>   #endif  /* _AVR_IOTN26_H_ */
> diff --git a/cpukit/score/cpu/avr/avr/iotn261.h b/cpukit/score/cpu/avr/avr/iotn261.h
> index 6e18069..9b91b7b 100644
> --- a/cpukit/score/cpu/avr/avr/iotn261.h
> +++ b/cpukit/score/cpu/avr/avr/iotn261.h
> @@ -1,3 +1,9 @@
> + * @file
> + * @brief Definitions for ATtiny261
>   /* Copyright (c) 2006, Anatoly Sokolov
> @@ -34,6 +40,14 @@
>   #ifndef _AVR_IOTN261_H_
>   #define _AVR_IOTN261_H_ 1
> + * @defgroup AvrDef_iotn261 ATtiny261 Definitions
> + * @ingroup avr
>   #include<avr/iotnx61.h>
>   #define SPM_PAGESIZE 32
> @@ -83,5 +97,6 @@
>   #define SIGNATURE_2 0x0C
>   #endif /* _AVR_IOTN261_H_ */
> diff --git a/cpukit/score/cpu/avr/avr/iousb82.h b/cpukit/score/cpu/avr/avr/iousb82.h
> index 428ed9b..94232af 100644
> --- a/cpukit/score/cpu/avr/avr/iousb82.h
> +++ b/cpukit/score/cpu/avr/avr/iousb82.h
> @@ -1,3 +1,9 @@
> + * @file
> + * @brief Ddefinitions for AT90USB82
>   /* Copyright (c) 2007 Anatoly Sokolov
> @@ -36,6 +42,14 @@
>   #include<avr/iousbxx2.h>
> + * @defgroup AvrDef_iousb82 AT90USB82 Definitions
> + * @ingroup avr
>   /* Constants */
>   #define SPM_PAGESIZE 128
>   #define RAMEND       0x2FF
> @@ -83,5 +97,6 @@
>   #endif /* _AVR_AT90USB82_H_ */
> diff --git a/cpukit/score/cpu/avr/avr/iox32d4.h b/cpukit/score/cpu/avr/avr/iox32d4.h
> index 7f7d710..0e01175 100644
> --- a/cpukit/score/cpu/avr/avr/iox32d4.h
> +++ b/cpukit/score/cpu/avr/avr/iox32d4.h
> @@ -1,6 +1,13 @@
> + * @file
> + * @brief Definitions for ATxmega32D4
>      Redistribution and use in source and binary forms, with or without
>      modification, are permitted provided that the following conditions are met:
> @@ -47,6 +54,14 @@
>   #ifndef _AVR_ATxmega32D4_H_
>   #define _AVR_ATxmega32D4_H_ 1
> + * @defgroup AvrDef_iox32d4 ATxmega32D4 Definitions
> + * @ingroup avr
>   /* Ungrouped common registers */
>   #define GPIO0  _SFR_MEM8(0x0000)  /* General Purpose IO Register 0 */
> @@ -5539,6 +5554,7 @@ IO Module Instances. Mapped to memory.
>   #define SIGNATURE_1 0x95
>   #define SIGNATURE_2 0x42
>   #endif /* _AVR_ATxmega32D4_H_ */
> diff --git a/cpukit/score/cpu/avr/rtems/asm.h b/cpukit/score/cpu/avr/rtems/asm.h
> index 89f1385..e93841d 100644
> --- a/cpukit/score/cpu/avr/rtems/asm.h
> +++ b/cpukit/score/cpu/avr/rtems/asm.h
> @@ -1,17 +1,20 @@
> - * @file rtems/asm.h
> + * @file
> - *  This include file attempts to address the problems
> - *  caused by incompatible flavors of assemblers and
> - *  toolsets.  It primarily addresses variations in the
> - *  use of leading underscores on symbols and the requirement
> - *  that register names be preceded by a %.
> + * @brief Address the Problems Caused by Incompatible Flavor of
> + * Assemblers and Toolsets
> + * This include file attempts to address the problems
> + * caused by incompatible flavors of assemblers and
> + * toolsets.  It primarily addresses variations in the
> + * use of leading underscores on symbols and the requirement
> + * that register names be preceded by a %.
> + * @note The spacing in the use of these macros
> + *       is critical to them working as advertised.
> - *  NOTE: The spacing in the use of these macros
> - *        is critical to them working as advertised.
>    *  COPYRIGHT:
>    *  This file is based on similar code found in newlib available
> @@ -324,7 +327,7 @@
>          lpm / mov Rd,r0
>          lpm / adiw ZL,1
>          lpm / mov Rd,r0 / adiw ZL,1
>      For enhanced chips it is one instruction always.
>      ATTENTION:  unlike enhanced chips SREG (S,V,N,Z,C) flags are
> diff --git a/cpukit/score/cpu/avr/rtems/score/avr.h b/cpukit/score/cpu/avr/rtems/score/avr.h
> index 23ecbb3..cee1a24 100644
> --- a/cpukit/score/cpu/avr/rtems/score/avr.h
> +++ b/cpukit/score/cpu/avr/rtems/score/avr.h
> @@ -1,13 +1,16 @@
> - * @file rtems/score/avr.h
> + * @file
> + * @brief Intel AVR Set up Basic CPU Dependency Settings Based on
> + * Compiler Settings
> + * This file sets up basic CPU dependency settings based on
> + * compiler settings.  For example, it can determine if
> + * floating point is available.  This particular implementation
> + * is specified to the avr port.
> - *  This file sets up basic CPU dependency settings based on
> - *  compiler settings.  For example, it can determine if
> - *  floating point is available.  This particular implementation
> - *  is specified to the avr port.
>    *  COPYRIGHT 2004, Ralf Corsepius, Ulm, Germany.
>    *  The license and distribution terms for this file may be
> diff --git a/cpukit/score/cpu/avr/rtems/score/cpu.h b/cpukit/score/cpu/avr/rtems/score/cpu.h
> index 2bfcbce..5f1577a 100644
> --- a/cpukit/score/cpu/avr/rtems/score/cpu.h
> +++ b/cpukit/score/cpu/avr/rtems/score/cpu.h
> @@ -1,11 +1,13 @@
> - * @file rtems/score/cpu.h
> + * @file
> + * @brief Intel AVR CPU Department Source
> + * This include file contains information pertaining to the AVR
> + * processor.
> - *  This include file contains information pertaining to the AVR
> - *  processor.
>    *  COPYRIGHT (c) 1989-2006.
>    *  On-Line Applications Research Corporation (OAR).
> diff --git a/cpukit/score/cpu/avr/rtems/score/cpu_asm.h b/cpukit/score/cpu/avr/rtems/score/cpu_asm.h
> index e3797a9..e11caec 100644
> --- a/cpukit/score/cpu/avr/rtems/score/cpu_asm.h
> +++ b/cpukit/score/cpu/avr/rtems/score/cpu_asm.h
> @@ -1,12 +1,14 @@
> - * @file rtems/score/cpu_asm.h
> + * @file
> + * @brief Intel AVR Assembly File
> + * Very loose template for an include file for the cpu_asm.? file
> + * if it is implemented as a ".S" file (preprocessed by cpp) instead
> + * of a ".s" file (preprocessed by gm4 or gasp).
> - *  Very loose template for an include file for the cpu_asm.? file
> - *  if it is implemented as a ".S" file (preprocessed by cpp) instead
> - *  of a ".s" file (preprocessed by gm4 or gasp).
>    *  COPYRIGHT (c) 1989-1999.
> diff --git a/cpukit/score/cpu/avr/rtems/score/types.h b/cpukit/score/cpu/avr/rtems/score/types.h
> index 77eb0db..a4710d3 100644
> --- a/cpukit/score/cpu/avr/rtems/score/types.h
> +++ b/cpukit/score/cpu/avr/rtems/score/types.h
> @@ -1,11 +1,13 @@
> - * @file rtems/score/types.h
> + * @file
> + * @brief Intel AVR CPU Type Definitions
> + * This include file contains type definitions pertaining to the Intel
> + * avr processor family.
> - *  This include file contains type definitions pertaining to the Intel
> - *  avr processor family.
> rtems-vc mailing list
> rtems-vc at rtems.org
> http://www.rtems.org/mailman/listinfo/rtems-vc
Joel Sherrill, Ph.D.             Director of Research&  Development
Ask me about RTEMS: a free RTOS  Huntsville AL 35806
Support Available               (256) 722-9985
