[Patch] Removing legacy method from arm csb337
Vipul Nayyar
nayyar_vipul at yahoo.com
Tue Jul 2 06:52:52 UTC 2013
Hello Andreas,
Thanks Andreas for pointing out that silly mistake. I didn't focus on other variables being used. I've updated the patch, and wanted to ask, what should be done when status code returned is not successful ?
commit 9b21c1effe34cb716c00ea1c11777ef16ce9c7cc
Author: Vipul Nayyar <nayyar_vipul at yahoo.com>
Date: Tue Jul 2 12:20:49 2013 +0530
Updated Legacy code in arm csb337
diff --git a/c/src/lib/libbsp/arm/csb337/network/network.c b/c/src/lib/libbsp/arm/csb337/network/network.c
index e31bcc0..53d60d2 100644
--- a/c/src/lib/libbsp/arm/csb337/network/network.c
+++ b/c/src/lib/libbsp/arm/csb337/network/network.c
@@ -358,6 +358,7 @@ void at91rm9200_emac_init(void *arg)
at91rm9200_emac_softc_t *sc = arg;
struct ifnet *ifp = &sc->arpcom.ac_if;
+ rtems_status_code stc = RTEMS_SUCCESSFUL;
*This is for stuff that only gets done once (at91rm9200_emac_init()
@@ -382,7 +383,16 @@ void at91rm9200_emac_init(void *arg)
AIC_SMR_REG(AIC_SMR_EMAC) = AIC_SMR_PRIOR(EMAC_INT_PRIORITY);
/* install the interrupt handler */
- BSP_install_rtems_irq_handler(&at91rm9200_emac_isr_data);
+ stc = rtems_interrupt_handler_install(
+ at91rm9200_emac_isr_data.name,
+ "Network",
+ RTEMS_INTERRUPT_UNIQUE,
+ at91rm9200_emac_isr_data.hdl,
+ at91rm9200_emac_isr_data.handle
+ if (stc != RTEMS_SUCCESSFUL) {
+ printk("RTEMS Interrupt handler not installed");
/* EMAC doesn't support promiscuous, so ignore requests */
if (ifp->if_flags & IFF_PROMISC) {
Regards
Vipul Nayyar
________________________________
From: Andreas Heinig <andreas.heinig at cs.tu-dortmund.de>
To: rtems-devel at rtems.org; Vipul Nayyar <nayyar_vipul at yahoo.com>
Sent: Tuesday, 2 July 2013 12:11 PM
Subject: Re: [Patch] Removing legacy method from arm csb337
Hello Vipul,
> b/c/src/lib/libbsp/arm/csb337/network/network.c index e31bcc0..3a02073
> 100644
> + rtems_status_code sc = RTEMS_SUCCESSFUL;
Hello,
you used 'sc' twice:
1) at91rm9200_emac_softc_t
2) rtems_status_code
Cheers
Andreas
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130702/6632aa86/attachment.html>
