[Patch] Removing legacy method from arm csb337
Tue Jul 2 07:10:34 UTC 2013
On 07/02/2013 08:52 AM, Vipul Nayyar wrote:
>       /* install the interrupt handler */
> -    BSP_install_rtems_irq_handler(&at91rm9200_emac_isr_data);
> +    stc = rtems_interrupt_handler_install(
> +      at91rm9200_emac_isr_data.name,
> +      "Network",
> +      RTEMS_INTERRUPT_UNIQUE,
> +      at91rm9200_emac_isr_data.hdl,
> +      at91rm9200_emac_isr_data.handle
> +    if (stc != RTEMS_SUCCESSFUL) {
> +    printk("RTEMS Interrupt handler not installed");
Don't use printk() for error notification.  In case the driver framework has
the ability to return an error status code, then use this.  Unfortunately the
driver frameworks in RTEMS are quite sloppy with this, so I don't know one
which uses this error strategy.  This gives you two options
1. assert()
2. rtems_fatal()
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
