pthread_once() and rtems_gxx_once()
Thu Jul 4 14:18:17 UTC 2013
Hello,
both functions disable currently the preemption to ensure mutual exclusion.
This doesn't work on SMP.  This makes also pthread_once() not POSIX conform.
Here we have
http://pubs.opengroup.org/onlinepubs/7908799/xsh/pthread_once.html
"On return from pthread_once(), it is guaranteed that init_routine() has
completed."
This is not true if the init_routine() blocks on a resource access.  I assume
that GCC needs also this guarantee.
To address this issue we have to protect the section with a mutex.  So it could
look like this:
int pthread_once(
   pthread_once_t   *once_control,
   void           ( *init_routine )( void )
   int eno = 0;
   if ( once_control->is_initialized ) {
     if ( !once_control->init_executed ) {
       _RTEMS_Lock_allocator();
         once_control->init_executed = true;
         ( *init_routine )();
       _RTEMS_Unlock_allocator();
   } else {
     eno = EINVAL;
   return eno;
We can also introduce a new API mutex for this, but I don't think this is
necessary.
This implementation has a severe defect.  Asynchronous cancellation, restart,
suspend or deletion inside the critical section leads to a permanently locked
mutex.  This leads to the next problem.  The cancellation support is also in
the POSIX API (e.g. pthread_setcanceltype).  I think we have to move this also
to the Classic API (there is a bug in this area
https://www.rtems.org/bugzilla/show_bug.cgi?id=2035).  This leads to the next
problem.  To use this we may need cleanup handlers (e.g.
pthread_cleanup_push/pop).  The current pthread_cleanup_push() implementation
is broken.  It uses workspace allocation with a silent failure.
As documented here
http://pubs.opengroup.org/onlinepubs/009695399/functions/pthread_cleanup_push.html
the cleanup handling can be implemented with data structures on the stack
(instead of the workspace).
I see the following steps to fix the pthread_once() and rtems_gxx_once()
implementation.
1. Change the cleanup handler implementation to use data structures on the
stack (Newlib owned header file, use <sys/queue.h> for lists instead of RTEMS
chains) and move the cleanup support to the Score (available now in all APIs).
2. Implement the once functions with a mutex.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
