[Patch] Reenable LD_PATHS, as suggested by Makefile.leaf
Nick Withers
nick.withers at anu.edu.au
Fri Jul 5 02:03:39 UTC 2013
Hey there!
Here's a patch to re-enable LD_PATHS (I have an external library,
RTEMS_gdb_stub, to pull in) in gcc-target-default.cfg:
____
diff --git a/c/src/make/compilers/gcc-target-default.cfg
b/c/src/make/compilers/gcc-target-default.cfg
index 813bd5c..a70681d 100644
--- a/c/src/make/compilers/gcc-target-default.cfg
+++ b/c/src/make/compilers/gcc-target-default.cfg
@@ -65,13 +65,12 @@ CXXFLAGS += $(CXXFLAGS_OPTIMIZE) $(CXXFLAGS_DEBUG)
endif
# List of library paths without -L
-LD_PATHS= $(PROJECT_RELEASE)/lib
+LD_PATHS+= $(PROJECT_RELEASE)/lib
# ld flag for incomplete link
LDFLAGS_INCOMPLETE = -r
-# LDFLAGS=$(LDFLAGS_DEBUG) $(LD_PATHS:%=-L%)
-LDFLAGS += $(LDFLAGS_DEBUG)
+LDFLAGS+= $(LDFLAGS_DEBUG) $(LD_PATHS:%=-L%)
# Stuff to clean and clobber for the compiler and its tools
____
(I've added an extra space after "LDFLAGS+=" since I emailed this in
http://www.rtems.org/pipermail/rtems-devel/2013-July/003497.html )
See
http://git.rtems.org/rtems/commit/c/src/make/compilers/gcc-target-default.cfg?id=ea9f76742163cccf98eb326db7459c18d2fad1b6 for why LD_PATHS had been commented ("Now implicitly handled by gcc-spec").
Makefile.leaf suggests that this variable should be used, so I think
putting it back is the right thing to do...?
Nick Withers
Embedded Systems Programmer
Room 2.26, Building 57
Department of Nuclear Physics
Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
eMail: nick.withers at anu.edu.au
Phone: +61 2 6125 2091
Mobile: +61 414 397 446
