[Patch] Allow customisation of ".exe" extension with Makefile EXEEXT
Nick Withers
nick.withers at anu.edu.au
Fri Jul 5 02:08:14 UTC 2013
Howdy all,
This patch (generated with git diff from the rtems.git root) replaces
".exe" in makefiles and .cfgs so that one can opt to have a different
application ELF binary extension than ".exe" (for instance, I'd like to
use 'EXEEXT=""') and it'd be just dandy if it were to be merged in for
4.11:
____
diff --git a/c/src/lib/libbsp/arm/gba/make/custom/gba.cfg b/c/src/lib/libbsp/arm/gba/make/custom/gba.cfg
index ee9be6a..1ae2fb8 100644
--- a/c/src/lib/libbsp/arm/gba/make/custom/gba.cfg
+++ b/c/src/lib/libbsp/arm/gba/make/custom/gba.cfg
@@ -20,6 +20,6 @@ CFLAGS_OPTIMIZE_V = -O2 -g
define bsp-post-link
$(OBJCOPY) -O binary --remove-section=.comment \
--remove-section=.note --strip-unneeded \
- $(basename $@).exe $(basename $@)$(DOWNEXT)
+ $(basename $@)$(EXEEXT) $(basename $@)$(DOWNEXT)
$(default-bsp-post-link)
endef
diff --git a/c/src/lib/libbsp/arm/gp32/make/custom/gp32.cfg b/c/src/lib/libbsp/arm/gp32/make/custom/gp32.cfg
index f287310..a558362 100644
--- a/c/src/lib/libbsp/arm/gp32/make/custom/gp32.cfg
+++ b/c/src/lib/libbsp/arm/gp32/make/custom/gp32.cfg
@@ -16,6 +16,6 @@ CPU_CFLAGS = -mstructure-size-boundary=32 -mcpu=arm920t -mfpu=vfp -mfloat-abi=so
- $(OBJCOPY) -O binary $(basename $@).exe $(basename $@)$(DOWNEXT)
+ $(OBJCOPY) -O binary $(basename $@)$(EXEEXT) $(basename $@)$(DOWNEXT)
endef
diff --git a/c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s69xx.inc b/c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s69xx.inc
index 4387c19..362d9f4 100644
--- a/c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s69xx.inc
+++ b/c/src/lib/libbsp/arm/lm3s69xx/make/custom/lm3s69xx.inc
@@ -12,5 +12,5 @@ CFLAGS_OPTIMIZE_V = -O2 -g
- $(OBJCOPY) -O binary $(basename $@).exe $(basename $@).ralf
endef
diff --git a/c/src/lib/libbsp/arm/nds/make/custom/nds.cfg b/c/src/lib/libbsp/arm/nds/make/custom/nds.cfg
index 9e4844d..78172e6 100644
--- a/c/src/lib/libbsp/arm/nds/make/custom/nds.cfg
+++ b/c/src/lib/libbsp/arm/nds/make/custom/nds.cfg
@@ -28,7 +28,7 @@ endif
- $(OBJCOPY) -O binary $(basename $@).exe $(basename $@).bin
+ $(OBJCOPY) -O binary $(basename $@)$(EXEEXT) $(basename $@).bin
$(NDSTOOL) -c $(basename $@).nds -9 $(basename $@).bin \
-7 $(COPROC_ELF_PATH)/coproc.bin
rm -f $(basename $@).bin
diff --git a/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg b/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg
index 9751658..6b47ea2 100644
--- a/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg
+++ b/c/src/lib/libbsp/arm/raspberrypi/make/custom/raspberrypi.cfg
@@ -16,7 +16,7 @@ CFLAGS_OPTIMIZE_V = -O2 -g
# is currently required.
$(OBJCOPY) -O binary --strip-all \
- $(SIZE) $(basename $@).exe
+ $(SIZE) $(basename $@)$(EXEEXT)
endef
diff --git a/c/src/lib/libbsp/i386/pc386/make/custom/pc386.cfg b/c/src/lib/libbsp/i386/pc386/make/custom/pc386.cfg
index e827d87..9f7428d 100644
--- a/c/src/lib/libbsp/i386/pc386/make/custom/pc386.cfg
+++ b/c/src/lib/libbsp/i386/pc386/make/custom/pc386.cfg
@@ -46,7 +46,7 @@ define bsp-post-link
$(OBJCOPY) -O elf32-i386 \
--remove-section=.note \
- --strip-unneeded $(basename $@).exe $(basename $@).nxe
+ --strip-unneeded $(basename $@)$(EXEEXT) $(basename $@).nxe
$(OBJCOPY) -O binary $(basename $@).nxe $(basename $@).bin
$(PROJECT_TOOLS)/bin2boot -v $(basename $@)$(DOWNEXT) $(HEADERADDR)\
$(START16FILE) $(START16ADDR) 0 $(basename $@).bin $(RELOCADDR) 0
diff --git a/c/src/lib/libbsp/lm32/lm32_evr/make/custom/lm32_evr.cfg b/c/src/lib/libbsp/lm32/lm32_evr/make/custom/lm32_evr.cfg
index d70ff80..c1951d0 100644
--- a/c/src/lib/libbsp/lm32/lm32_evr/make/custom/lm32_evr.cfg
+++ b/c/src/lib/libbsp/lm32/lm32_evr/make/custom/lm32_evr.cfg
@@ -21,7 +21,7 @@ CPU_CFLAGS =
CFLAGS_OPTIMIZE_V = -O0 -g
- $(OBJCOPY) -O binary --strip-all $(basename $@).exe \
+ $(OBJCOPY) -O binary --strip-all $(basename $@)$(EXEEXT) \
-R entry -R exceptions $(basename $@)$(DOWNEXT)
endef
diff --git a/c/src/lib/libbsp/lm32/milkymist/make/custom/milkymist.cfg b/c/src/lib/libbsp/lm32/milkymist/make/custom/milkymist.cfg
index 5a44658..ae691eb 100644
--- a/c/src/lib/libbsp/lm32/milkymist/make/custom/milkymist.cfg
+++ b/c/src/lib/libbsp/lm32/milkymist/make/custom/milkymist.cfg
@@ -21,7 +21,7 @@ CPU_CFLAGS = -mbarrel-shift-enabled -mmultiply-enabled \
endef
diff --git a/c/src/lib/libbsp/m68k/av5282/make/custom/av5282.cfg b/c/src/lib/libbsp/m68k/av5282/make/custom/av5282.cfg
index 0bbeaf1..a668d99 100644
--- a/c/src/lib/libbsp/m68k/av5282/make/custom/av5282.cfg
+++ b/c/src/lib/libbsp/m68k/av5282/make/custom/av5282.cfg
@@ -22,5 +22,5 @@ endif
endef
diff --git a/c/src/lib/libbsp/m68k/genmcf548x/make/custom/genmcf548x.inc b/c/src/lib/libbsp/m68k/genmcf548x/make/custom/genmcf548x.inc
index 843524c..a910bd3 100644
--- a/c/src/lib/libbsp/m68k/genmcf548x/make/custom/genmcf548x.inc
+++ b/c/src/lib/libbsp/m68k/genmcf548x/make/custom/genmcf548x.inc
@@ -15,7 +15,7 @@ CPU_CFLAGS = -mcfv4e -Wa,-memac
CFLAGS_OPTIMIZE_V = -O2 -g -fomit-frame-pointer
endef
diff --git a/c/src/lib/libbsp/m68k/idp/make/custom/idp.cfg b/c/src/lib/libbsp/m68k/idp/make/custom/idp.cfg
index 937ce30..d10029a 100644
--- a/c/src/lib/libbsp/m68k/idp/make/custom/idp.cfg
+++ b/c/src/lib/libbsp/m68k/idp/make/custom/idp.cfg
@@ -16,7 +16,7 @@ CPU_CFLAGS = -msoft-float
- $(OBJCOPY) -O srec $(basename $@).exe $(basename $@).srec
+ $(OBJCOPY) -O srec $(basename $@)$(EXEEXT) $(basename $@).srec
sed -e 's/.$$//' -e '/^S0/d' $(basename $@).srec | \
$(PACKHEX) > $(basename $@)$(DOWNEXT)
rm -f $(basename $@).srec
diff --git a/c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235.cfg b/c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235.cfg
index 4dcb890..9b22a21 100644
--- a/c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235.cfg
+++ b/c/src/lib/libbsp/m68k/mcf52235/make/custom/mcf52235.cfg
@@ -18,6 +18,6 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fomit-frame-pointer
endef
diff --git a/c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x.cfg b/c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x.cfg
index 6a415a7..90e76e2 100644
--- a/c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x.cfg
+++ b/c/src/lib/libbsp/m68k/mcf5225x/make/custom/mcf5225x.cfg
@@ -22,6 +22,6 @@ CFLAGS_OPTIMIZE_V = -O2 -fomit-frame-pointer
endef
diff --git a/c/src/lib/libbsp/m68k/mcf5235/make/custom/mcf5235.cfg b/c/src/lib/libbsp/m68k/mcf5235/make/custom/mcf5235.cfg
index 8a543ac..b5c3c49 100644
--- a/c/src/lib/libbsp/m68k/mcf5235/make/custom/mcf5235.cfg
+++ b/c/src/lib/libbsp/m68k/mcf5235/make/custom/mcf5235.cfg
@@ -22,6 +22,6 @@ endif
endef
diff --git a/c/src/lib/libbsp/m68k/mcf5329/make/custom/mcf5329.cfg b/c/src/lib/libbsp/m68k/mcf5329/make/custom/mcf5329.cfg
index e68fd28..e1f5734 100644
--- a/c/src/lib/libbsp/m68k/mcf5329/make/custom/mcf5329.cfg
+++ b/c/src/lib/libbsp/m68k/mcf5329/make/custom/mcf5329.cfg
@@ -20,6 +20,6 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fomit-frame-pointer
endef
diff --git a/c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg b/c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg
index a1be91b..bf55e4f 100644
--- a/c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg
+++ b/c/src/lib/libbsp/m68k/mrm332/make/custom/mrm332.cfg
@@ -31,8 +31,8 @@ define bsp-post-link
return s } ;\
/\.text/ { base = $$4 ; size = $$3 };\
END { printf("0x%x", h2d(base) + h2d(size)) }'\
- ` $(basename $@).pxe $(basename $@).exe
+ ` $(basename $@).pxe $(basename $@)$(EXEEXT)
$(NM) -g -n $(basename $@).pxe > $(basename $@).pnum
@@ -41,7 +41,7 @@ define bsp-post-link
endef
else
diff --git a/c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136.cfg b/c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136.cfg
index 74cdd64..2f63f04 100644
--- a/c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136.cfg
+++ b/c/src/lib/libbsp/m68k/mvme136/make/custom/mvme136.cfg
@@ -17,7 +17,7 @@ CPU_CFLAGS = -mcpu=68020
CFLAGS_OPTIMIZE_V = -Os -g -fomit-frame-pointer -DNDEBUG
diff --git a/c/src/lib/libbsp/m68k/mvme147/make/custom/mvme147.cfg b/c/src/lib/libbsp/m68k/mvme147/make/custom/mvme147.cfg
index 0ba9719..9880587 100644
--- a/c/src/lib/libbsp/m68k/mvme147/make/custom/mvme147.cfg
+++ b/c/src/lib/libbsp/m68k/mvme147/make/custom/mvme147.cfg
@@ -15,7 +15,7 @@ CPU_CFLAGS = -mcpu=68030
diff --git a/c/src/lib/libbsp/m68k/mvme147s/make/custom/mvme147s.cfg b/c/src/lib/libbsp/m68k/mvme147s/make/custom/mvme147s.cfg
index e14de8d..3eaade8 100644
--- a/c/src/lib/libbsp/m68k/mvme147s/make/custom/mvme147s.cfg
+++ b/c/src/lib/libbsp/m68k/mvme147s/make/custom/mvme147s.cfg
diff --git a/c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162.cfg b/c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162.cfg
index d8a217f..4b343b2 100644
--- a/c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162.cfg
+++ b/c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162.cfg
@@ -20,7 +20,7 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fomit-frame-pointer
endef
# BSP-specific tools
diff --git a/c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162lx.cfg b/c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162lx.cfg
index 81c398e..2a210a9 100644
--- a/c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162lx.cfg
+++ b/c/src/lib/libbsp/m68k/mvme162/make/custom/mvme162lx.cfg
@@ -25,7 +25,7 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fomit-frame-pointer
endef
diff --git a/c/src/lib/libbsp/m68k/mvme167/make/custom/mvme167.cfg b/c/src/lib/libbsp/m68k/mvme167/make/custom/mvme167.cfg
index a56de0f..21bd9af 100644
--- a/c/src/lib/libbsp/m68k/mvme167/make/custom/mvme167.cfg
+++ b/c/src/lib/libbsp/m68k/mvme167/make/custom/mvme167.cfg
@@ -36,5 +36,5 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fno-omit-frame-pointer
# for more details.
- $(OBJCOPY) -O binary -R .comment -S $(basename $@).exe $(basename $@)$(DOWNEXT)
+ $(OBJCOPY) -O binary -R .comment -S $(basename $@)$(EXEEXT) $(basename $@)$(DOWNEXT)
endef
diff --git a/c/src/lib/libbsp/m68k/sim68000/make/custom/sim68000.cfg b/c/src/lib/libbsp/m68k/sim68000/make/custom/sim68000.cfg
index bb3354a..fb355cb 100644
--- a/c/src/lib/libbsp/m68k/sim68000/make/custom/sim68000.cfg
+++ b/c/src/lib/libbsp/m68k/sim68000/make/custom/sim68000.cfg
@@ -16,5 +16,5 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fomit-frame-pointer
- $(OBJCOPY) -O srec $(basename $@).exe $(basename $@)$(DOWNEXT)
+ $(OBJCOPY) -O srec $(basename $@)$(EXEEXT) $(basename $@)$(DOWNEXT)
endef
diff --git a/c/src/lib/libbsp/m68k/sim68000/make/custom/simcpu32.cfg b/c/src/lib/libbsp/m68k/sim68000/make/custom/simcpu32.cfg
index 939a1e1..817e162 100644
--- a/c/src/lib/libbsp/m68k/sim68000/make/custom/simcpu32.cfg
+++ b/c/src/lib/libbsp/m68k/sim68000/make/custom/simcpu32.cfg
endef
diff --git a/c/src/lib/libbsp/m68k/uC5282/make/custom/uC5282.cfg b/c/src/lib/libbsp/m68k/uC5282/make/custom/uC5282.cfg
index caf93a8..3c62a17 100644
--- a/c/src/lib/libbsp/m68k/uC5282/make/custom/uC5282.cfg
+++ b/c/src/lib/libbsp/m68k/uC5282/make/custom/uC5282.cfg
endef
diff --git a/c/src/lib/libbsp/nios2/nios2_iss/make/custom/nios2_iss.cfg b/c/src/lib/libbsp/nios2/nios2_iss/make/custom/nios2_iss.cfg
index e8fb39d..8254eec 100644
--- a/c/src/lib/libbsp/nios2/nios2_iss/make/custom/nios2_iss.cfg
+++ b/c/src/lib/libbsp/nios2/nios2_iss/make/custom/nios2_iss.cfg
@@ -21,7 +21,7 @@ CPU_CFLAGS = -mno-hw-mul -mno-hw-div
endef
diff --git a/c/src/lib/libbsp/powerpc/haleakala/make/custom/haleakala.cfg b/c/src/lib/libbsp/powerpc/haleakala/make/custom/haleakala.cfg
index 41cd98e..67ffe58 100644
--- a/c/src/lib/libbsp/powerpc/haleakala/make/custom/haleakala.cfg
+++ b/c/src/lib/libbsp/powerpc/haleakala/make/custom/haleakala.cfg
@@ -20,5 +20,5 @@ CFLAGS_OPTIMIZE_V = -O1 -g
endef
diff --git a/c/src/lib/libbsp/powerpc/mbx8xx/make/custom/mbx8xx.inc b/c/src/lib/libbsp/powerpc/mbx8xx/make/custom/mbx8xx.inc
index c1a2235..4795de7 100644
--- a/c/src/lib/libbsp/powerpc/mbx8xx/make/custom/mbx8xx.inc
+++ b/c/src/lib/libbsp/powerpc/mbx8xx/make/custom/mbx8xx.inc
@@ -49,7 +49,7 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fno-keep-inline-functions
LDFLAGS += $(MBX8xx_LDFLAGS)
- cp $(basename $@).exe $(basename $@)$(DOWNEXT)
+ cp $(basename $@)$(EXEEXT) $(basename $@)$(DOWNEXT)
$(STRIP) $(basename $@)$(DOWNEXT)
endef
diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg
index fc775d1..8ff97b3 100644
--- a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg
+++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mcp750.cfg
@@ -17,11 +17,11 @@ CFLAGS_OPTIMIZE_V = -O2 -g -mmultiple -mstring -mstrict-align
- $(OBJCOPY) -O binary -R .comment -S $(basename $@).exe rtems
+ $(OBJCOPY) -O binary -R .comment -S $(basename $@)$(EXEEXT) rtems
gzip -vf9 rtems
$(LD) -o $(basename $@)$(DOWNEXT) \
$ $(PROJECT_RELEASE)/lib/bootloader.o \
- --just-symbols=$(basename $@).exe \
+ --just-symbols=$(basename $@)$(EXEEXT) \
-b binary rtems.gz -T $(PROJECT_RELEASE)/lib/ppcboot.lds \
-Map $(basename $@).map && chmod 755 $@
rm -f rtems.gz
diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mtx603e.cfg b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mtx603e.cfg
index 2411501..6c7f597 100644
--- a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mtx603e.cfg
+++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mtx603e.cfg
@@ -16,11 +16,11 @@ CFLAGS_OPTIMIZE_V = -O2 -g -mmultiple -mstring -mstrict-align
gzip -vf9 rtems
rm -f rtems.gz
diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2100.cfg b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2100.cfg
index 93e14ab..d724b5d 100644
--- a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2100.cfg
+++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2100.cfg
gzip -vf9 rtems
rm -f rtems.gz
diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2307.cfg b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2307.cfg
index d7dac3a..ee00561 100644
--- a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2307.cfg
+++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/mvme2307.cfg
@@ -17,10 +17,10 @@ CFLAGS_OPTIMIZE_V = -O2 -g
gzip -vf9 rtems
$(LD) -o $(basename $@)$(DOWNEXT) $(PROJECT_RELEASE)/lib/bootloader.o \
rm -f rtems.gz
diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep-altivec.cfg b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep-altivec.cfg
index cef17e5..1dd1744 100644
--- a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep-altivec.cfg
+++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep-altivec.cfg
@@ -18,15 +18,15 @@ CFLAGS_OPTIMIZE_V = -O2 -g
ifdef PURE_BINARY
endef
else
gzip -vf9 rtems
rm -f rtems.gz
diff --git a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep.cfg b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep.cfg
index 3922767..e5f11fc 100644
--- a/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep.cfg
+++ b/c/src/lib/libbsp/powerpc/motorola_powerpc/make/custom/qemuprep.cfg
ifdef PURE_BINARY
endef
else
gzip -vf9 rtems
rm -f rtems.gz
diff --git a/c/src/lib/libbsp/powerpc/mvme3100/make/custom/mvme3100.cfg b/c/src/lib/libbsp/powerpc/mvme3100/make/custom/mvme3100.cfg
index 3ea5c2b..ddd6d23 100644
--- a/c/src/lib/libbsp/powerpc/mvme3100/make/custom/mvme3100.cfg
+++ b/c/src/lib/libbsp/powerpc/mvme3100/make/custom/mvme3100.cfg
@@ -17,5 +17,5 @@ CFLAGS_OPTIMIZE_V = -O2 -g
endef
diff --git a/c/src/lib/libbsp/powerpc/mvme5500/make/custom/mvme5500.cfg b/c/src/lib/libbsp/powerpc/mvme5500/make/custom/mvme5500.cfg
index b4727bc..4c59a07 100644
--- a/c/src/lib/libbsp/powerpc/mvme5500/make/custom/mvme5500.cfg
+++ b/c/src/lib/libbsp/powerpc/mvme5500/make/custom/mvme5500.cfg
@@ -19,7 +19,7 @@ CFLAGS_OPTIMIZE_V = -O2 -g
endef
diff --git a/c/src/lib/libbsp/powerpc/qemuppc/make/custom/qemuppc.cfg b/c/src/lib/libbsp/powerpc/qemuppc/make/custom/qemuppc.cfg
index 177f88f..b768855 100644
--- a/c/src/lib/libbsp/powerpc/qemuppc/make/custom/qemuppc.cfg
+++ b/c/src/lib/libbsp/powerpc/qemuppc/make/custom/qemuppc.cfg
@@ -16,5 +16,5 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fno-keep-inline-functions
endef
diff --git a/c/src/lib/libbsp/powerpc/score603e/make/custom/score603e.cfg b/c/src/lib/libbsp/powerpc/score603e/make/custom/score603e.cfg
index 7b03438..a657bb3 100644
--- a/c/src/lib/libbsp/powerpc/score603e/make/custom/score603e.cfg
+++ b/c/src/lib/libbsp/powerpc/score603e/make/custom/score603e.cfg
@@ -22,7 +22,7 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fno-keep-inline-functions
- $(OBJCOPY) -O srec $(basename $@).exe $(basename $@).s1
+ $(OBJCOPY) -O srec $(basename $@)$(EXEEXT) $(basename $@).s1
sed -e 's/.$$//' $(basename $@).s1 | \
$(PACKHEX) >$(basename $@)$(DOWNEXT)
rm -f $(basename $@).s1
diff --git a/c/src/lib/libbsp/powerpc/ss555/make/custom/ss555.cfg b/c/src/lib/libbsp/powerpc/ss555/make/custom/ss555.cfg
index 22ae7fb..cde7f4a 100644
--- a/c/src/lib/libbsp/powerpc/ss555/make/custom/ss555.cfg
+++ b/c/src/lib/libbsp/powerpc/ss555/make/custom/ss555.cfg
@@ -23,6 +23,6 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fno-keep-inline-functions
endef
diff --git a/c/src/lib/libbsp/powerpc/tqm8xx/make/custom/tqm8xx.inc b/c/src/lib/libbsp/powerpc/tqm8xx/make/custom/tqm8xx.inc
index 119bc28..da32441 100644
--- a/c/src/lib/libbsp/powerpc/tqm8xx/make/custom/tqm8xx.inc
+++ b/c/src/lib/libbsp/powerpc/tqm8xx/make/custom/tqm8xx.inc
@@ -15,7 +15,7 @@ CPU_CFLAGS = -mcpu=860 -Dmpc860 \
endef
diff --git a/c/src/lib/libbsp/powerpc/virtex/make/custom/virtex.cfg b/c/src/lib/libbsp/powerpc/virtex/make/custom/virtex.cfg
index a91530c..96aa7cc 100644
--- a/c/src/lib/libbsp/powerpc/virtex/make/custom/virtex.cfg
+++ b/c/src/lib/libbsp/powerpc/virtex/make/custom/virtex.cfg
@@ -19,5 +19,5 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fno-keep-inline-functions
endef
diff --git a/c/src/lib/libbsp/powerpc/virtex4/make/custom/virtex4.cfg b/c/src/lib/libbsp/powerpc/virtex4/make/custom/virtex4.cfg
index 333b144..713c297 100644
--- a/c/src/lib/libbsp/powerpc/virtex4/make/custom/virtex4.cfg
+++ b/c/src/lib/libbsp/powerpc/virtex4/make/custom/virtex4.cfg
@@ -14,6 +14,6 @@ CFLAGS_OPTIMIZE_V = -O2 -g -fno-keep-inline-functions
# Miscellaneous additions go here
endef
diff --git a/c/src/lib/libbsp/powerpc/virtex5/make/custom/virtex5.cfg b/c/src/lib/libbsp/powerpc/virtex5/make/custom/virtex5.cfg
index b4a7bd3..9601fbc 100644
--- a/c/src/lib/libbsp/powerpc/virtex5/make/custom/virtex5.cfg
+++ b/c/src/lib/libbsp/powerpc/virtex5/make/custom/virtex5.cfg
endef
diff --git a/c/src/make/leaf.cfg b/c/src/make/leaf.cfg
index dd0defe..8d3f52e 100644
--- a/c/src/make/leaf.cfg
+++ b/c/src/make/leaf.cfg
@@ -8,11 +8,8 @@ ifndef LINKCMDS
LINKCMDS=$(PROJECT_RELEASE)/lib/linkcmds
endif
-## what to do about $(EXEEXT) --> $(EXEEXT)
-## -o $(basename $@)$(EXEEXT) OR
-DOWNEXT=.ralf
+EXEEXT?=.exe
+DOWNEXT?=.ralf
define bsp-link-c
$(LINK.c) $(CPU_CFLAGS) $(AM_CFLAGS) $(AM_LDFLAGS) \
diff --git a/make/leaf.cfg b/make/leaf.cfg
index 90cda37..6ebf4bd 100644
--- a/make/leaf.cfg
+++ b/make/leaf.cfg
@@ -78,20 +78,17 @@ clean: clean-am
.PHONY: clean clean-am
endif
-DOWNEXT=.ralf
+EXEEXT?=.exe
+DOWNEXT?=.ralf
define bsp-link-c
- -o $(basename $@).exe $(LINK_OBJS) $(LINK_LIBS)
+ -o $(basename $@)$(EXEEXT) $(LINK_OBJS) $(LINK_LIBS)
endef
define bsp-link-cxx
$(LINK.cc) $(CPU_CFLAGS) $(AM_CFLAGS) $(AM_LDFLAGS) \
endef
define default-bsp-post-link
@@ -102,7 +99,7 @@ endef
ifndef bsp-post-link
endef
endif
____
Nick Withers
Embedded Systems Programmer
Room 2.26, Building 57
Department of Nuclear Physics
Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
eMail: nick.withers at anu.edu.au
Phone: +61 2 6125 2091
Mobile: +61 414 397 446
