[Patch] Removing legacy method from arm csb337
    Gedare Bloom
    gedare at rtems.org
    Fri Jul  5 18:33:24 UTC 2013
On Fri, Jul 5, 2013 at 2:02 PM, Vipul Nayyar <nayyar_vipul at yahoo.com> wrote:
> Please test the attached patch once again. I guess attaching with email to
> the devel list is the appropriate method to submit patches ?
http://wiki.rtems.org/wiki/index.php/Contributing
> I've removed most of the warnings in the file that I could. I think I've not
> introduced any trailing spaces in the code, if that's what you were talking
> about.
You can test your patch with git-am, which will tell you about
whitespace errors in your patch. for example,
$> git checkout -b test
$> git am ../patches/arm-csb337.patch
> Regards
> Vipul Nayyar
> rtems-devel mailing list
> rtems-devel at rtems.org
