[Patch] Removing legacy method from arm csb336
Sun Jul 7 13:16:42 UTC 2013
Overall this patch looks good, but there are some minor issues.
On 07/07/13 13:33, Vipul Nayyar wrote:
> Hello,
> Worked again on csb336 patch. Following points I've kept in mind while doing this :
> 1) Update legacy install and remove methods to the new generic ones
> 2)Removed all uses of tems_irq_connect_data type
> 3) Inserted protoypes for functions which didn't had one
> 4) Made functions static that are only used in that file
> Hoping to get reviews, so that I can move on with other BSPs.
> commit e22d51a1f9d2efeba77e97ff0c81a9a5800af20c
> Author: Vipul Nayyar <nayyar_vipul at yahoo.com>
> Date:   Sun Jul 7 16:51:07 2013 +0530
>      Updated Legacy code in arm csb336
> diff --git a/c/src/lib/libbsp/arm/csb336/console/uart.c b/c/src/lib/libbsp/arm/csb336/console/uart.c
> index 4dc409b..96126fa 100644
> --- a/c/src/lib/libbsp/arm/csb336/console/uart.c
> +++ b/c/src/lib/libbsp/arm/csb336/console/uart.c
> @@ -13,6 +13,7 @@
>   #include <libchip/sersupp.h>
>   #include <rtems/error.h>
>   #include <rtems/bspIo.h>
> +#include <assert.h>
>   #include <termios.h>
>   #include <rtems/irq.h>
>   #include <bsp/irq.h>
> @@ -34,13 +35,17 @@ static int imx_uart_set_attrs(int, const struct termios *);
>   static void imx_uart_init(int minor);
>   static void imx_uart_set_baud(int, int);
>   static ssize_t imx_uart_poll_write(int, const char *, size_t);
> +static int imx_uart_poll_read_char(int minor);
> +static void imx_uart_poll_write_char(int minor, char c);
> +static void _BSP_output_char(char c);
> +static int _BSP_poll_char(void);
One empty line is enough.
>   #if defined(USE_INTERRUPTS)
>   static void imx_uart_tx_isr(rtems_irq_hdl_param);
>   static void imx_uart_rx_isr(rtems_irq_hdl_param);
> -static void imx_uart_isr_on(const rtems_irq_connect_data *irq);
> -static void imx_uart_isr_off(const rtems_irq_connect_data *irq);
> -static int imx_uart_isr_is_on(const rtems_irq_connect_data *irq);
> +static void imx_uart_isr_on(const rtems_irq_number);
> +static void imx_uart_isr_off(const rtems_irq_number);
>   static ssize_t imx_uart_intr_write(int, const char *, size_t);
>   #endif
> @@ -71,11 +76,6 @@ rtems_termios_callbacks imx_uart_cbacks = {
>   #endif
> -#if defined(USE_INTERRUPTS)
> -static rtems_irq_connect_data imx_uart_tx_isr_data[NUM_DEVS];
> -static rtems_irq_connect_data imx_uart_rx_isr_data[NUM_DEVS];
> -#endif
>   typedef struct {
>       int minor;
>       mc9328mxl_uart_regs_t * regs;
> @@ -184,17 +184,9 @@ static void imx_uart_init(int minor)
>       imx_uart_data[minor].idx   = 0;
>       if (minor == 0) {
> -        imx_uart_tx_isr_data[minor].name = BSP_INT_UART1_TX;
> -        imx_uart_rx_isr_data[minor].name = BSP_INT_UART1_RX;
> -#endif
>           imx_uart_data[minor].regs =
>               (mc9328mxl_uart_regs_t *) MC9328MXL_UART1_BASE;
>       } else if (minor == 1) {
> -        imx_uart_tx_isr_data[minor].name = BSP_INT_UART2_TX;
> -        imx_uart_rx_isr_data[minor].name = BSP_INT_UART2_RX;
> -#endif
>               (mc9328mxl_uart_regs_t *) MC9328MXL_UART2_BASE;
>       } else {
> @@ -202,20 +194,6 @@ static void imx_uart_init(int minor)
>                       __FUNCTION__, __LINE__, minor);
> -    imx_uart_tx_isr_data[minor].hdl    = imx_uart_tx_isr;
> -    imx_uart_tx_isr_data[minor].handle = &imx_uart_data[minor];
> -    imx_uart_tx_isr_data[minor].on     = imx_uart_isr_on;
> -    imx_uart_tx_isr_data[minor].off    = imx_uart_isr_off;
> -    imx_uart_tx_isr_data[minor].isOn   = imx_uart_isr_is_on;
> -    imx_uart_rx_isr_data[minor].hdl    = imx_uart_rx_isr;
> -    imx_uart_rx_isr_data[minor].handle  = &imx_uart_data[minor];
> -    imx_uart_rx_isr_data[minor].on     = imx_uart_isr_on;
> -    imx_uart_rx_isr_data[minor].off    = imx_uart_isr_off;
> -    imx_uart_rx_isr_data[minor].isOn   = imx_uart_isr_is_on;
> -#endif
>       imx_uart_data[minor].regs->cr1 = (
>           MC9328MXL_UART_CR1_UARTCLKEN |
>           MC9328MXL_UART_CR1_UARTEN);
> @@ -243,13 +221,43 @@ static void imx_uart_init(int minor)
>   static int imx_uart_first_open(int major, int minor, void *arg)
>       rtems_libio_open_close_args_t *args = arg;
> +    rtems_status_code status = RTEMS_SUCCESSFUL;
> +    rtems_irq_number name_uart_tx, name_uart_rx;
These variables are unused if USE_INTERRUPTS is not defined.  Please
compile this file with USE_INTERRUPTS defined and undefined and watch
for warnings.
>       imx_uart_data[minor].tty   = args->iop->data1;
> -    BSP_install_rtems_irq_handler(&imx_uart_tx_isr_data[minor]);
> -    BSP_install_rtems_irq_handler(&imx_uart_rx_isr_data[minor]);
> +    if (minor == 0) {
> +        name_uart_tx = BSP_INT_UART1_TX;
> +        name_uart_rx = BSP_INT_UART1_RX;
> +    } else if (minor == 1) {
> +        name_uart_tx = BSP_INT_UART2_TX;
> +        name_uart_rx = BSP_INT_UART2_RX;
> +    } else {
> +        rtems_panic("%s:%d Unknown UART minor number %d\n",
> +                    __FUNCTION__, __LINE__, minor);
> +#if defined(USE_INTERRUPTS)
> +    status = rtems_interrupt_handler_install(
> +        name_uart_tx,
> +        "Network",
> +        RTEMS_INTERRUPT_UNIQUE,
> +        imx_uart_tx_isr,
> +        &imx_uart_data[minor]
> +    assert(status == RTEMS_SUCCESSFUL);
> +    imx_uart_isr_on(name_uart_tx);
> +        name_uart_rx,
> +        "Network",
> +        imx_uart_rx_isr,
> +    imx_uart_isr_on(name_uart_rx);
>       imx_uart_data[minor].regs->cr1 |= MC9328MXL_UART_CR1_RRDYEN;
>   #endif
> @@ -258,9 +266,35 @@ static int imx_uart_first_open(int major, int minor, void *arg)
>   static int imx_uart_last_close(int major, int minor, void *arg)
> +    if (minor == 0) {
> +    } else {
The lines above are a copy and paste version of some code earlier. You
should avoid copy and past in general.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
