[PATCH] Updated Legacy code in arm csb336
Vipul Nayyar nayyar_vipul at yahoo.com
Mon Jul 8 13:43:14 UTC 2013
 c/src/lib/libbsp/arm/csb336/console/uart.c    | 128 +++++++++++++++-----------
 c/src/lib/libbsp/arm/csb336/network/network.c |  46 +++------
 2 files changed, 86 insertions(+), 88 deletions(-)
diff --git a/c/src/lib/libbsp/arm/csb336/console/uart.c b/c/src/lib/libbsp/arm/csb336/console/uart.c
index 4dc409b..8156921 100644
--- a/c/src/lib/libbsp/arm/csb336/console/uart.c
+++ b/c/src/lib/libbsp/arm/csb336/console/uart.c
@@ -13,14 +13,16 @@
 #include <libchip/sersupp.h>
 #include <rtems/error.h>
 #include <rtems/bspIo.h>
+#include <assert.h>
 #include <termios.h>
 #include <rtems/irq.h>
 #include <bsp/irq.h>
 #include <mc9328mxl.h>
 /* Define this to use interrupt driver UART driver */
 #define USE_INTERRUPTS 1
+#define UART_TX 1
+#define UART_RX 2
 /* How many serial ports? */
 #define NUM_DEVS       2
@@ -34,18 +36,20 @@ static int imx_uart_set_attrs(int, const struct termios *);
 static void imx_uart_init(int minor);
 static void imx_uart_set_baud(int, int);
 static ssize_t imx_uart_poll_write(int, const char *, size_t);
+static int imx_uart_poll_read_char(int minor);
+static void imx_uart_poll_write_char(int minor, char c);
+static void _BSP_output_char(char c);
+static int _BSP_poll_char(void);
 #if defined(USE_INTERRUPTS)
 static void imx_uart_tx_isr(rtems_irq_hdl_param);
 static void imx_uart_rx_isr(rtems_irq_hdl_param);
-static void imx_uart_isr_on(const rtems_irq_connect_data *irq);
-static void imx_uart_isr_off(const rtems_irq_connect_data *irq);
-static int imx_uart_isr_is_on(const rtems_irq_connect_data *irq);
+static void imx_uart_isr_on(const rtems_irq_number);
+static void imx_uart_isr_off(const rtems_irq_number);
 static ssize_t imx_uart_intr_write(int, const char *, size_t);
+static rtems_irq_number imx_uart_set_name(int,int);
 #endif
 /* TERMIOS callbacks */
 rtems_termios_callbacks imx_uart_cbacks = {
@@ -71,11 +75,6 @@ rtems_termios_callbacks imx_uart_cbacks = {
 #endif
-#if defined(USE_INTERRUPTS)
-static rtems_irq_connect_data imx_uart_tx_isr_data[NUM_DEVS];
-static rtems_irq_connect_data imx_uart_rx_isr_data[NUM_DEVS];
-#endif
 typedef struct {
     int minor;
     mc9328mxl_uart_regs_t * regs;
@@ -184,17 +183,9 @@ static void imx_uart_init(int minor)
     imx_uart_data[minor].idx   = 0;
     if (minor == 0) {
-        imx_uart_tx_isr_data[minor].name = BSP_INT_UART1_TX;
-        imx_uart_rx_isr_data[minor].name = BSP_INT_UART1_RX;
-#endif
         imx_uart_data[minor].regs =
             (mc9328mxl_uart_regs_t *) MC9328MXL_UART1_BASE;
     } else if (minor == 1) {
-        imx_uart_tx_isr_data[minor].name = BSP_INT_UART2_TX;
-        imx_uart_rx_isr_data[minor].name = BSP_INT_UART2_RX;
-#endif
             (mc9328mxl_uart_regs_t *) MC9328MXL_UART2_BASE;
     } else {
@@ -202,20 +193,6 @@ static void imx_uart_init(int minor)
                     __FUNCTION__, __LINE__, minor);
-    imx_uart_tx_isr_data[minor].hdl    = imx_uart_tx_isr;
-    imx_uart_tx_isr_data[minor].handle = &imx_uart_data[minor];
-    imx_uart_tx_isr_data[minor].on     = imx_uart_isr_on;
-    imx_uart_tx_isr_data[minor].off    = imx_uart_isr_off;
-    imx_uart_tx_isr_data[minor].isOn   = imx_uart_isr_is_on;
-    imx_uart_rx_isr_data[minor].hdl    = imx_uart_rx_isr;
-    imx_uart_rx_isr_data[minor].handle  = &imx_uart_data[minor];
-    imx_uart_rx_isr_data[minor].on     = imx_uart_isr_on;
-    imx_uart_rx_isr_data[minor].off    = imx_uart_isr_off;
-    imx_uart_rx_isr_data[minor].isOn   = imx_uart_isr_is_on;
-#endif
     imx_uart_data[minor].regs->cr1 = (
         MC9328MXL_UART_CR1_UARTCLKEN |
         MC9328MXL_UART_CR1_UARTEN);
@@ -243,13 +220,31 @@ static void imx_uart_init(int minor)
 static int imx_uart_first_open(int major, int minor, void *arg)
     rtems_libio_open_close_args_t *args = arg;
+    rtems_status_code status = RTEMS_SUCCESSFUL;
     imx_uart_data[minor].tty   = args->iop->data1;
-    BSP_install_rtems_irq_handler(&imx_uart_tx_isr_data[minor]);
-    BSP_install_rtems_irq_handler(&imx_uart_rx_isr_data[minor]);
+#if defined(USE_INTERRUPTS)
+    status = rtems_interrupt_handler_install(
+        imx_uart_set_name(minor, UART_TX),
+        "Network",
+        RTEMS_INTERRUPT_UNIQUE,
+        imx_uart_tx_isr,
+        &imx_uart_data[minor]
+    assert(status == RTEMS_SUCCESSFUL);
+    imx_uart_isr_on(imx_uart_set_name(minor, UART_TX));
+        imx_uart_set_name(minor, UART_RX),
+        "Network",
+        imx_uart_rx_isr,
+    imx_uart_isr_on(imx_uart_set_name(minor, UART_RX));
     imx_uart_data[minor].regs->cr1 |= MC9328MXL_UART_CR1_RRDYEN;
 #endif
@@ -259,8 +254,23 @@ static int imx_uart_first_open(int major, int minor, void *arg)
 static int imx_uart_last_close(int major, int minor, void *arg)
-    BSP_remove_rtems_irq_handler(&imx_uart_tx_isr_data[minor]);
-    BSP_remove_rtems_irq_handler(&imx_uart_rx_isr_data[minor]);
+    imx_uart_isr_off(imx_uart_set_name(minor, UART_TX));
+    status = rtems_interrupt_handler_remove(
+        imx_uart_tx_isr,
+    imx_uart_isr_off(imx_uart_set_name(minor, UART_RX));
+        imx_uart_rx_isr,
 #endif
     return 0;
@@ -317,22 +327,13 @@ static int imx_uart_set_attrs(int minor, const struct termios *t)
+static void imx_uart_isr_on(const rtems_irq_number name)
-    MC9328MXL_AITC_INTENNUM = irq->name;
+    MC9328MXL_AITC_INTENNUM = name;
+static void imx_uart_isr_off(const rtems_irq_number name)
-    MC9328MXL_AITC_INTDISNUM = irq->name;
-    int irq_num = (int)irq->name;
-    if (irq_num < 32) {
-        return MC9328MXL_AITC_INTENABLEL & (1 << irq_num);
-    } else {
-        return MC9328MXL_AITC_INTENABLEH & (1 << (irq_num - 32));
+    MC9328MXL_AITC_INTDISNUM = name;
 static void imx_uart_rx_isr(rtems_irq_hdl_param param)
@@ -369,6 +370,21 @@ static void imx_uart_tx_isr(rtems_irq_hdl_param param)
         rtems_termios_dequeue_characters(uart_data->tty, len);
+static rtems_irq_number imx_uart_set_name(int minor,int uart_name)
+    if (minor == 0) {
+        if (uart_name == UART_TX) return BSP_INT_UART1_TX;
+        else if (uart_name == UART_RX)return BSP_INT_UART1_RX;
+    } else if (minor == 1) {
+        if (uart_name == UART_TX) return BSP_INT_UART2_TX;
+        else if (uart_name == UART_RX) return BSP_INT_UART2_RX;
+    rtems_panic("%s:%d Unknown UART minor number %d\n",
+                    __FUNCTION__, __LINE__, minor);
 #endif
@@ -417,7 +433,7 @@ static void imx_uart_set_baud(int minor, int baud)
  * Polled, non-blocking read from UART
-int imx_uart_poll_read_char(int minor)
     return imx_uart_poll_read(minor);
@@ -425,7 +441,7 @@ int imx_uart_poll_read_char(int minor)
  * Polled, blocking write from UART
-void  imx_uart_poll_write_char(int minor, char c)
     imx_uart_poll_write(minor, &c, 1);
@@ -433,7 +449,7 @@ void  imx_uart_poll_write_char(int minor, char c)
  * Functions for printk() and friends.
-void _BSP_output_char(char c)
     poll_write(c);
     if (c == '\n') {
@@ -443,7 +459,7 @@ void _BSP_output_char(char c)
 BSP_output_char_function_type BSP_output_char = _BSP_output_char;
-int _BSP_poll_char(void)
     return poll_read();
diff --git a/c/src/lib/libbsp/arm/csb336/network/network.c b/c/src/lib/libbsp/arm/csb336/network/network.c
index e513595..f93fcc8 100644
--- a/c/src/lib/libbsp/arm/csb336/network/network.c
+++ b/c/src/lib/libbsp/arm/csb336/network/network.c
@@ -19,6 +19,7 @@
 #include <sys/param.h>
 #include <sys/mbuf.h>
@@ -39,19 +40,8 @@
 #define START_TRANSMIT_EVENT    RTEMS_EVENT_2
 static void enet_isr(rtems_irq_hdl_param);
-static void enet_isr_on(const rtems_irq_connect_data *unused);
-static void enet_isr_off(const rtems_irq_connect_data *unused);
-static int enet_isr_is_on(const rtems_irq_connect_data *irq);
-/* Replace the first value with the clock's interrupt name. */
-rtems_irq_connect_data mc9328mxl_enet_isr_data = {
-    .name    = BSP_INT_GPIO_PORTA,
-    .hdl     = enet_isr,
-    .handle  = (void *)BSP_INT_GPIO_PORTA,
-    .on      = enet_isr_on,
-    .off     = enet_isr_off,
-    .isOn    = enet_isr_is_on,
+static void enet_isr_on(void);
 typedef struct {
   unsigned long rx_packets;        /* total packets received         */
   unsigned long tx_packets;        /* total packets transmitted      */
@@ -238,6 +228,7 @@ void  mc9328mxl_enet_init_hw(mc9328mxl_enet_softc_t *sc)
     uint16_t stat;
     uint16_t my = 0;
     lan91c11x_write_reg(LAN91C11X_RCR, LAN91C11X_RCR_RST);
     lan91c11x_write_reg(LAN91C11X_RCR, 0);
@@ -334,7 +325,15 @@ void  mc9328mxl_enet_init_hw(mc9328mxl_enet_softc_t *sc)
     MC9328MXL_GPIOA_IMR |= bit(3);
     /* Install the interrupt handler */
-    BSP_install_rtems_irq_handler(&mc9328mxl_enet_isr_data);
+        BSP_INT_GPIO_PORTA,
+        "Network",
+        enet_isr,
+        (void *)BSP_INT_GPIO_PORTA
+    enet_isr_on();
 } /* mc9328mxl_enet_init_hw() */
@@ -602,7 +601,7 @@ void mc9328mxl_enet_stats (mc9328mxl_enet_softc_t *sc)
 /* Enables mc9328mxl_enet interrupts. */
     /* Enable interrupts */
     MC9328MXL_AITC_INTENNUM = MC9328MXL_INT_GPIO_PORTA;
@@ -610,23 +609,6 @@ static void enet_isr_on(const rtems_irq_connect_data *unused)
     return;
-/* Disables enet interrupts */
-    /* disable all various TX/RX interrupts */
-    MC9328MXL_AITC_INTDISNUM = MC9328MXL_INT_GPIO_PORTA;
-    return;
-/* Tests to see if mc9328mxl_enet interrupts are enabled, and returns non-0 if so.
- * If interrupt is not enabled, returns 0.
-    return MC9328MXL_AITC_INTENABLEL & (1 << MC9328MXL_INT_GPIO_PORTA);
 /*  Driver ioctl handler */
 static int
 mc9328mxl_enet_ioctl (struct ifnet *ifp, ioctl_command_t command, caddr_t data)
1.7.11.7
