[PATCH] Updated Legacy code in arm csb336
Sebastian Huber
Mon Jul 8 15:09:32 UTC 2013
On 07/08/2013 03:43 PM, Vipul Nayyar wrote:
> c/src/lib/libbsp/arm/csb336/console/uart.c | 128 +++++++++++++++-----------
> c/src/lib/libbsp/arm/csb336/network/network.c | 46 +++------
> 2 files changed, 86 insertions(+), 88 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/csb336/console/uart.c b/c/src/lib/libbsp/arm/csb336/console/uart.c
> index 4dc409b..8156921 100644
> --- a/c/src/lib/libbsp/arm/csb336/console/uart.c
> +++ b/c/src/lib/libbsp/arm/csb336/console/uart.c
> /* Define this to use interrupt driver UART driver */
> #define USE_INTERRUPTS 1
> +#define UART_TX 1
> +#define UART_RX 2
> static ssize_t imx_uart_intr_write(int, const char *, size_t);
> +static rtems_irq_number imx_uart_set_name(int,int);
This rtems_irq_number is defined in <rtems/irq.h>. This it belongs to the
legacy API we want to get rid of. Use rtems_vector_number instead.
> +static rtems_irq_number imx_uart_set_name(int minor,int uart_name)
> + if (minor == 0) {
> + if (uart_name == UART_TX) return BSP_INT_UART1_TX;
> + else if (uart_name == UART_RX)return BSP_INT_UART1_RX;
> + } else if (minor == 1) {
> + if (uart_name == UART_TX) return BSP_INT_UART2_TX;
> + else if (uart_name == UART_RX) return BSP_INT_UART2_RX;
> + rtems_panic("%s:%d Unknown UART minor number %d\n",
> + __FUNCTION__, __LINE__, minor);
This function is better than the previous copy and paste approach.
If I naively read imx_uart_set_name() I think this function sets the name of
the UART. Instead this function returns an interrupt vector depending on a
magic number uart_name.
I would use two functions for this, one for the receive and one for the
transmit interrupt or use at least an enum instead of the int uart_name. Since
we already use assert(), you can replace the rtems_panic() (which is a very
heavy weight function) with an assert(0).
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
